Forums › General Discussion › hatch sealant
Viewing 8 reply threads
    • #69042
      I know we’ve covered this in the past, but…
      What would a savvy owner use to seal the Lexan on the overhead
      aluminum-frame hatches? There seems to be a variety of Sikaflex
      sealants. Haven’t figured out yet whether one is better suited to
      hatch application, perhaps with UV deterrent in it. Anyone have
      some experience with something that works well?
    • #81998
      Dow Corning 795 is my sealant of choice as well as the people who make
      skyscrapers.
      On Jan 13, 2015 11:21 AM, “Silverheels via maillist” <
    • #81999
      Glad to have a second on that motion. Thanks, Skip.
    • #82000
      Thanks, Bob. That’s what I’ll use – on the boat hatches AND on my next skyscraper.
    • #82001
      I agree with Bob, Dow Corning 795. It’s what I used on my recent hatch replacement project. ( http://pagetwo88.blogspot.com/2014/09/bomar-cast-alluminum-hatch-rebuild.html )
      It “is” the product to use IMO. Easy to work with out of the tube, a real treat. I recommend you mask everything, all edges, and then use a plastic spatula type tool to smooth out, then pull the tape and refrain from screwing with it until it’s cured.
      You might be able to get a similar product off the shelf at a glass store but I found DC 795 for under $10 on line.
    • #82002
      Hey Ken,
      $6.39 on Amazon, but $12.38 total for one tube, with shipping.
      – How many tubes did you use on 3 hatches?
      – What paint did you use over the zinc chromate?
      – Where’d you get the new lens stock?
    • #82003
      Tor,
      I figured a tube a hatch. Just opened the third tube to finish.
      I’m a bit embarrassed about the paint I used, but it did the job, and it
      was cheap. I had half a qt on board that came with the boat so I just
      bought another. Rust-oleum, It sucked to work with, wouldn’t lay down and
      spread like tomato past. Use “anything” but that. So many opinions on
      paint, I think just a good oil base or polyurethane would be fine.
      The 1/4″ (actually .223) plastic lens stock came from a local glass company
      that sells everything to do with glass and mirrors. I had them cut the
      square to size (they were not super accurate and I ended up cutting them
      down more to give plenty of room for expansion. (1/8″ per ft.?) I think the
      three pieces cost $80 something.
      On Wed, Jan 14, 2015 at 8:40 AM, Silverheels via maillist <
      > wrote:
      Hey Ken,
    • #82004
      OK, thanks, Ken.
      I use Rustoleum sometimes without complaint. In fact, their “marine” paint lasted 6 or 7 years on Silverheels’ foredeck before I just recently put a fresh coat on. Can’s ask much more than that. Sounds like yours might’ve benefitted from a little thinning and maybe straining – or can paint just get too old? Anyway, I’m glad to know someone besides me doesn’t feel obliged to make these little projects into state-of-the-art rocket science. It’s just a boat.
      I’ve got a couple of projects ahead of the hatches, so I’ve time to think about it and gather the materials. I expect I’ll pretty much duplicate what you did, plus I need to fill & re-drill some thread-worn frame screw holes that no longer grab & hold their lens screws.
    • #82005
      Start of attached email. Subject: Re: hatch sealant
      I use krylon white gloss on my steering pedestal with gray results. Lasts in salt water and easy to touch up when scratched.
      Unabated
      On Jan 14, 2015, at 12:27 PM, Silverheels via maillist wrote:
      OK, thanks, Ken.
