Forums › General Discussion › heat exchanger
- This topic has 16 replies, 7 voices, and was last updated 15 years, 6 months ago by
quent.
April 1, 2011 at 8:31 pm #68297
Well, at least it happened here instead of down in the Bahamas
somewhere… I need a new heat exchanger for my W-60. One is available thru Westerbeke
for $900, but if any one has any ideas, a “spare”, or a parts link, please
let me know, thanks,
BILL~~~ ~ (_~~ (_~ ~ ~ fair winds ~ ~ (_
April 1, 2011 at 9:06 pm #76969
ModeratorHi Bill,
Just out of curiosity, why do you need a new one? I ask because I’ve often
wondered if they are repairable if it’s a leaking tube (if only one, you can
safely plug it. Actually, I’ve seen engines run quite happily with almost
50% plugged) If more than that, can it be re-tubed? It would be a long and
tedious process involving a drill, solder (or brazing), bronze tubing, and a
lot of patience. On the W58, I think repair would be possible.I don’t know where you’d get one, frankly, except Westerbeke, but I’d sure
like a whack at fixing it if you’re going to throw the old one away.Bob
thru Westerbeke
April 1, 2011 at 10:25 pm #76973
Hey, Bob, thanks for getting back. The news came via phone today from my
Deltaville mechanic–I am 4 hours away at my Smith Mt Lake home, so I have
not seen it yet. I had been leaking coolant through both freeze plugs in the
H2O reservoir which he had fixed and pressure tested. But in reassembling
and testing he discover that my fresh mix is seeping into my raw H2O loop.
This solved the mystery of why I had been losing fluid in the reservoir.
I am going to the boat tomorrow and will be talking to him. Knowing Henry,
If it were at all possible to repair, he would. As for me doing it? HA!
Thanks again for the comeback, and if I don’t hang on to this exchanger,
it’s yours.
Capt Bill Tice, aboard s/v CHARISMAIn a message dated 4/1/2011 5:06:27 P.M. Eastern Daylight Time,
writes:Hi Bill,
can
and
a
thru Westerbeke
for $900, but if any one has any ideas, a “spare”, or a parts link,please
April 1, 2011 at 11:28 pm #76977
ParticipantBill
Search Westerbeke 21903 on Google.
http://www.aaamarine.com/servlet/the-672/21903-Westerbeke-2729-dsh-3-dsh-5-marine/Detail
Here’s one for $425. Really!
April 1, 2011 at 11:54 pm #76978
QUENT — What a find! Thanks for doing the leg work for me.
MY God – whatever did we do before the Internet and duct tape?~~~ ~ (_~~ (_~ ~ ~ fair winds ~ ~ (_
Capt Bill Tice, aboard s/v CHARISMAIn a message dated 4/1/2011 7:28:57 P.M. Eastern Daylight Time,
writes:Bill
arine/Detail
m2f
Read this topic online here:
https://www.pearson424.org/bb2forum/viewtopic.php?p=9371#9371
m2f
April 1, 2011 at 11:58 pm #76979
ParticipantBill:
As Quent pointed out, Sen-dure makes these exchangers. Just a matter of shopping around to see who will sell it to you for the least.
April 2, 2011 at 3:04 pm #76981
RichCarterParticipantThe heat exchanger is made by sen-dure. They can build you a new one on an exchange basis.
Sent from my iPad
it’s yours.
writes:Hi Bill,
can
and
a
thru Westerbeke
April 2, 2011 at 5:47 pm #76983
john stevensonParticipantRich’s post reminds me that the W60 Heat exchanger body is a custom
casting. The mounts for the W60 are not standard. If you need to replace
that or the whole thing you will need to send the body to Sendure so they
can cast a new one. I don’t think anyone will have one in stock, except
Walter (aka Seawater). If he hasn’t used it for parts himself, he has the
one on my W60, which was new in 2003 or 4. I think the cost was a little
exchange basis.Rich
Sent from my iPad
Deltaville mechanic–I am 4 hours away at my Smith Mt Lake home, so Ihave
the
reassembling
loop.
I am going to the boat tomorrow and will be talking to him. KnowingHenry,
it’s yours.
writes:Hi Bill,
often
can
safely plug it. Actually, I’ve seen engines run quite happily withalmost
and
tedious process involving a drill, solder (or brazing), bronze tubing,and
a
sure
thru Westerbeke
April 2, 2011 at 6:51 pm #76984
Phil Fontaine
ParticipantHi Bill.
I would suggest you contact Sen-Dur, the original manufacturer for advice.
800 394-5112.
When I replaced my hx in the Spring of 1999 they gave me the following
information:Westerbeke P/N 21903 = Sen-Dure P/N 2729-3-5 (material is copper)
They would need my old hx so that they could reuse the bronze castings that
connect the hx to the manifold. They also offered a copper-nickel unit under
P/N 2729-3-7. They suggested that I deal with them through one of the marine
equipmant suppliers in order to save about 20% off the Sen-Dure list prices
and provided the following estimated prices:
2729-3-5 estimated price $309.60 (list $383)
2729-3-7 estimated price $387.00 (list $484)
I elected to order through Defencder in Connecticut and got the -7 for
$377.52 plus $5.65 for shipping of the old unit to Sen-Dure. Total time from
delivery of old unit to Defender to pick-up of new was one month.I noticed that Quent found a -5 unit on the web for $425, with no mention of
having to return an old one. So that might be more attractive given that my
price info is 12 years old. But, it wouldn’t hurt to check both, especially
if you are interested in going with copper-nickel.
Good luck.
Phil Fontaine
April 2, 2011 at 7:51 pm #76985
john stevensonParticipantThanks, Quent – another parts source to bookmark
They don’t say so in the page your reference, but on the page that links to
that one they state that you must send the old unit for the casting. So
this source is probably not much different from dealing Defender or other
suppliers Sen-Dure might recommend.On Sat, Apr 2, 2011 at 2:50 PM, Philippe Fontaine wrote:
Quote:Hi Bill.
I would suggest you contact Sen-Dur, the original manufacturer for advice. 800
394-5112.
of having to return an old one. So that might be more attractive given that
my price info is 12 years old. But, it wouldn’t hurt to check both,
especially if you are interested in going with copper-nickel.
Good luck.
Phil Fontaine
April 2, 2011 at 8:16 pm #76986
ParticipantHere’s one for $317. Possibly made by Seakamp.
http://www.halemarine.com/index.php?main_page=product_info&cPath=4_160&products_id=1844&zenid=3d0cf3c708c87265d88ee36d289e23e2
April 2, 2011 at 8:19 pm #76987
ParticipantOops, sorry, that was for W-58!
April 2, 2011 at 8:44 pm #76988
john stevensonParticipantThanks again, Quent. One more bookmark
Browsing this site I found I could have bought a new VD tranny and oil
cooler for only a few $100s more than it cost me to rebuild mine. I didn’t
spend a lot of time looking back in November, but the best deal I found on a
April 3, 2011 at 12:34 am #76989
OPPS! But I take it the sites you linked yesterday WERE for a W-60, prt
#21903?? I’m away fr the boat & don’t have my parts numbers….~~~ ~ (_~~ (_~ ~ ~ fair winds ~ ~ (_
Capt Bill Tice, aboard s/v CHARISMAIn a message dated 4/2/2011 4:19:07 P.M. Eastern Daylight Time,
writes:Oops, sorry, that was for W-58!
m2f
https://www.pearson424.org/bb2forum/viewtopic.php?p=9383#9383
m2f
April 3, 2011 at 12:38 am #76990
THANKS, Phil, will follow through.
Capt Bill Tice, aboard s/v CHARISMAIn a message dated 4/2/2011 3:51:31 P.M. Eastern Daylight Time,
writes:Thanks, Quent – another parts source to bookmark
wrote:Hi Bill.
I would suggest you contact Sen-Dur, the original manufacturer foradvice. 800
394-5112.
They would need my old hx so that they could reuse the bronze castingsthat
under
marine
prices
$377.52 plus $5.65 for shipping of the old unit to Sen-Dure. Total timefrom
of having to return an old one. So that might be more attractive giventhat
Quote:my price info is 12 years old. But, it wouldn’t hurt to check both,
Good luck.
Phil Fontaine
April 3, 2011 at 12:48 am #76991
WILCO – Thanks, John
Capt Bill Tice, aboard s/v CHARISMAIn a message dated 4/2/2011 1:47:09 P.M. Eastern Daylight Time,
writes:Rich’s post reminds me that the W60 Heat exchanger body is a custom
an
exchange basis.
Sent from my iPad
my
have
in
the
reassembling
loop.
reservoir.
Henry,
HA!
exchanger,
it’s yours.
writes:Hi Bill,
often
you
can
long
and
a
sure
somewhere… I need a new heat exchanger for my W-60. One isavailable
thru Westerbeke
April 3, 2011 at 11:42 am #76993
ParticipantFirst post was for W-60. I just Googled Westerbeke followed by part number. There were multiple sites, so look at all for good price and someone trustworthy.
There are also some sources on Ebay.
