Forums › General Discussion › Heaving To
- This topic has 12 replies, 5 voices, and was last updated 16 years, 6 months ago by
April 13, 2010 at 11:50 pm #67968
Syringa
ParticipantI have not taken the time when the weather is up to pratice heaving to. Has anyone out there done this manuever? Syringa is a cutter rigged ketch so I was wondering is it best to use the mizzen or the stay sail? or any combination? Thanks in advance for all your replys.
April 14, 2010 at 12:13 am #75141
Don,
I experimented with heaving-to aboard my double-headsail (a.k.a.
cutter-rigged) ketch one stormy night offshore when we were all just too
damned tired to keep bashing into it. In the end I settled on a deep-reefed
main sheeted in hard, with the helm adjusted and lashed to keep the boat
around 60? off the wind and seas. It worked, though I can’t say it was
perfectly comfortable. The seas were awfully short and steep. In theory you
should be able to use just the mizzen sheetedTor
April 14, 2010 at 12:16 am #75142
Don,
should be able to use just the mizzen sheeted in hard, but I found that
wasn’t enough that night.Tor
April 14, 2010 at 12:33 am #75143
On second thought, maybe the main was sheeted in almost but not quite hard.
April 14, 2010 at 1:14 am #75144
SpectatorGood article Jack mentions on Cruisers Forum a few years back:
http://www.bethandevans.com/pdf/heavingto.pdf-p
s/v Deep Playa | Pearson 424 Hull #152 | http://www.DeepPlaya.comOn Tue, Apr 13, 2010 at 5:33 PM, Silver Heels wrote:
Quote:On second thought, maybe the main was sheeted in almost but not quite hard.Tor
April 14, 2010 at 12:38 pm #75145
Pat,
Excellent article. Thanks! I stand corrected. Silver Heels was forereaching,
not hove to. I almost did add a back winded staysail that night, thus truly
heaving the boat to, but decided against it because I thought it might push
the bow off the wind more than I wanted (I was probably wrong about that),
and because I did not want the additional leeway stealing back our
hard-earned miles to windward (I was probably right about that).I suspect the way to properly heave-to a 424 is with the back winded
staysail, perhaps reefed, plus either the deep-reefed mainsail, a storm
trysail, or the mizzen, possibly reefed. I’ll have to experiment some more
next time the weather gets up.FYI, I once forereached through a 5-day tropical storm in mid-Atlantic on my
last cruising boat, a Crealock 37. Then I very much wanted to keep moving
towards the Azores, a more or less windward destination at the moment. I
flew just the reefed staysail and we made 1½ to 2 knots forward, with lots
of leeway, too.Tor
April 14, 2010 at 3:23 pm #75146
ParticipantI have used the reefed jib and mizzen in lighter air to park the boat for
the kids to go swimming. The boat just sat almost still and there was a
calm spot on the lee of the boat for the kids to play around in. It worked
well and I would think it would be better with a stay sail in heaver seas
with a reef in the mizzen.Linus
April 14, 2010 at 4:45 pm #75147
DavidParticipantPardeys in their 2nd edition of storm tactics cover almost every boat cofiguration. Their suggestions, in heavier air than I have been in, is mizzen only, and the completely rolled genny is enough to heave with.
They also address parahcute anchors. I wrote them and asked ther recomendation for my 424 ketch and they said no paranchor larger than 12 feet. Larger presnets BIGGER problems
Hope this helps
Dave and Nancy Buettell
S/V SAils Call #12 -
April 14, 2010 at 5:31 pm #75148
Well, the Pardey’s know what they’re talking about, that’s for sure.
However, that night I experimented with my boat offshore it was only blowing
25-35 knots. No big deal, we just needed a break. I tried heaving to with
just the mizzen sail first (with the genoa fully rolled up on the headstay).
I don’t exactly remember what was unsatisfactory about it – it was late &
rough and I was wet & tired and I didn’t take notes – but I believe it did
not hold the boat to the wind as I’d hoped. I think I then added the
deep-reefed mainsail, but that was too much canvas aft and the boat tended
to round up. So I doused the mizzen and settled for forereaching at a knot
or so with just the deep-reefed mainsail. It was acceptable in those
conditions.I have a video somewhere that the Pardey’s made, all about how to use a sea
anchor. It’s full of good information explained well. There was a lot I
didn’t know. In fact, the longer I mess around with boats, the more I
realize I don’t know. I think I liked it better when I was 25 and knew
everything.Tor
April 15, 2010 at 2:41 pm #75156
Syringa
ParticipantI used an old Ordnance Parachute I found at a Army Navy store in Lewiston Idaho for a sea anchor on my last boat. It was made to slow the drop torpedo from a bomer. It was made very very heavy mesh about the right size 9′ and best of all it only cost $50. I let it go when I sold the boat. So it you find one let me know.
April 15, 2010 at 4:06 pm #75157
I carried a fancy “marine” sea anchor on my last cruising boat for 6 years /
30k n. miles. Never used it once. In fact, I haven’t had occasion to use a
sea anchor ever, and that goes back a ways. Come to think of it, I don’t
know anyone who has ever had occasion to deploy a sea anchor, other than
Larry & Lin Pardey. I didn’t bother putting one aboard Silver Heels. If I
ever get into weather that atrocious, I’ll tow warps. (I have LOTS of spare
line aboard.)That said, the Pardey’s sea anchor instructional video is very good, showing
exactly how to use one effectively for heaving-to (as opposed to towing) in
extreme weather and/or to reduce leeway when hove-to. It nearly inspired me
to set one up. Nearly.Tor
April 17, 2010 at 1:14 pm #75164
I have practiced this a lot on Navasana – a standard rigged ketch.So far here is what I have found:In light air all sails up we backwind the genoa, let out the main a little and keep the mizzen all the way in. She stops dead and just sits there. Moderate will have main double reefed and genoa reefed and back winded.The strongest breeze we have played in was about 28 30kn with 6 – 8 ft seas had a working jib up fully reefed, sailing jib and jigger. We back winded the jib and had the mizzen reefed and tight in. We never fully hit Hove to status as we were just slightly making headway. I believe the jib being so far forward still drove the boat. It is pretty cool to see that slick the Pardey’s talk about form to windward and the boat quieted right down.My assumption is in the cutter rig if you used the staysail instead of the jib you could more easily come
fully hove to – guess I have to add a staysail to the wish list……
This season I hope to play with the drogue – but sailing in New England have to get far enough off shoe to clear all those lobster pots!
— On Wed, 4/14/10, Silver Heels wrote:Post generated from Pearson424 Forum using Mail2Forum
April 17, 2010 at 3:49 pm #75165
Eric,
You’re right, heaving to isn’t just for heavy weather. In light to moderate
conditions I also use the full, backed genoa plus main and/or mizzen. It’s a
great way to take a break in mid-sail for cooking, swimming, or just
thinking about whatever’s coming up. This is also what I call my Tor
overboard drill, which I show anyone who sails with me for more than a day.
If I fall overboard underway under sail, I don’t expect new crew to remember
how to sail a figure-8 or drop sails or whatever. Instead, I teach them to
simply turn the boat hard to windward until the headsail backwinds, and then
turn hard over the other way and lock the wheel. Presto! The boat stops,
hove to. Everything gets still and quiet. If we were sailing to windward (as
is too often the case) she drifts slowly back to where the overboard mark is
floating, creating a smooth lee to boot. The idiot captain who fell
overboard can swim to the boat and climb back aboard. I let new crew
practice this once or twice, and then every once in a while I’ll suddenly
call out, “Tor overboard drill! Now! Now!” to confirm they’ll really know
what to do if I ever do fall overboard.I added a staysail rig to Silver Heels because I was planning offshore
passages. Part of its function is, as you suggest, for heaving to in strong
weather. That’s the sail I could’ve added, back winded, to the deep reefed
main when I forereached through that blow a few months ago. Then I would’ve
really been hove to. The installation was a bit of a project, but seemed
worthwhile to me.Tor
