Forums › General Discussion › HELP! I need the pedestal diameter!
Viewing 8 reply threads
    • #67023
      Hi All,
      Am dealing with problem with throttle shaft on pedestal. If someone could measure the diameter real quick, I'd be forever thankful!
    • #69981
      Bob,
      If you’re talking about the horizontal shaft sticking out of the side of the pedestal, the shaft to which the handle attaches), on my boat it’s 1/2″ stainless steel rod.
    • #69982
      Hi Tor,
      Thanks – I need the pedestal diameter – I think it's 6-7/8″. That's what Edson has on the paperwork from Pearson when the ordered the pedestals…
      Could you confirm that?
      Thanks!
      On Tue, May 27, 2008 at 6:42 AM, Silver Heels < ([email][/email])> wrote:
      Bob,
      If you're talking about the horizontal shaft sticking out of the side of the pedestal, the shaft to which the handle attaches), on my boat it's 1/2″ stainless steel rod.
    • #69983
      Sorry, Bob, I’m not understanding which measurement you need. To me a “pedestal” is the entire vertical structure in the cockpit to which is attached the steering wheel and engine controls, like a post with a compass on top. Mine has a variety of dimensions, depending upon which part you’re measuring. The base is about 10″ diameter, the main post looks to be about 3-1’4″, then it flares wide again at the top where the compass sits. Can you be more specific about which part of the pedestal you want measured?
    • #69984
      Bob:
      I measure my control housing at 6 7/8″ OD
      Boundless #28
    • #69985
      Hi Tor,
      Sorry – I should have said the binnacle diameter – where the compass sits. Paul came up with the magic number. You are, of course, correct. There are a bunch of diameters.
      On Tue, May 27, 2008 at 6:57 AM, Silver Heels < ([email][/email])> wrote:
      Sorry, Bob, I'm not understanding which measurement you need. To me a “pedestal” is the entire vertical structure in the cockpit to which is attached the steering wheel and engine controls, like a post with a compass on top. Mine has a variety of dimensions, depending upon which part you're measuring. The base is about 10″ diameter, the main post looks to be about 3-1'4″, then it flares wide again at the top where the compass sits. Can you be more specific about which part of the pedestal you want measured?
    • #69986
      Thanks Paul!
      That's the one!
      On Tue, May 27, 2008 at 7:06 AM, Paul Lefebvre < ([email][/email])> wrote:
      Bob:
      Boundless #28
    • #69989
      Edson maintenance guide for OEM unit attached.
      On 5/27/08, Robert Fine < ([email][/email])> wrote:
      Thanks Paul!
      That's the one!
    • #69990
      Wow! Thanks Chuck!
      Thanks Paul!
      That's the one!
