Forums › General Discussion › House Batteries
Viewing 10 reply threads
    • #68371
      I am trying to determine what changes were made to Wavemaker before acquisition.
      Where did Pearson put the house batteries if there was installed an inverter in the port cockpit lazarette?
      Many thanks.
      Sent from my BlackBerry® wireless handheld
    • #77389
      On my 1978 there were two batteries on the starboard side in battery boxes under the starboard laz. My inverter / charger was on the port bulkhead under the port laz.
      I have since added a dedicated start battery on the shelf aft if the nav station in the hanging locker (starboard).
      Eric Lorentzon
      EFI Sales Development Manager
      412.352.1941
      Many thanks.
    • #77390
      Phil Fontaine
      Aurora is a 1980 ketch and also has the house batteries (two size 8D) in the
      stbd lazarette. I added two size 24 starting batteries in the same locker,
      just aft of the house bank. No charger/inverter.
      Phil
    • #77391
      Pelican came with two 4D batteries in the Stbd lazerette. I replaced them
      with 2 AGM batteries and added a third behind the water heater for the main
      bank. The second bank is 2 group 31 AGMs for emergencies.
      Then I added a Xantrex Freedom 2000 charger/ inverter plus 2 135 watt solar
      panels. When sailing link offshore passages, I hook up my shaft generator.
      the
      Phil
    • #77392
      Deep Playa have 6 batteries of the following spec:
      *Interstate Deep Cycle/Cranking – 6 Volt*BCI Grp #Interstate TypeAmp Hours
      @ 20 hrs.RC
      (Min.)Warranty (Mo.)Hrs. at Ampere Load*Dimensions (in.)*
      L | W | HWeight
      (lbs)Terminal@ 25A@ 75A5 amps15 ampsGC-2U2200232474122654.514.010-1/4 7-1/8
      11-1/4622 options: threaded stud over auto post OR auto post w/ hole
      They are in two banks, stored in stacked battery boxes in the starboard
      lazarette.
      We plan to combine them into one large house bank and add a dedicated
      starting battery at some point, most likely when the batteries need
      replacing.
      acquisition.
      Many thanks.
    • #77393
      Thatcher’s question was, “Where did Pearson put the house batteries if
      there was installed an inverter in the port cockpit lazarette?” I don’t
      know, but I’d also be curious to know the answer if anyone has it.
    • #77394
      Wait a minute. Thatcher, did you mean if Pearson installed an inverter
      in the port cockpit locker or in the starboard locker? If Pearson
      installed an inverter on the port side cockpit locker of your boat, I’d
      imagine they would’ve installed the batteries in the starboard side
      battery box as usual. Is there a reason you suspect otherwise?
    • #77395
    • #77396
      Phil
      Why do you have 2 starting batteries?
      Did you have cranking issues that were resolved by 2 batteries?
      Eclipse
      On Tue, Jul 5, 2011 at 12:03 PM, Philippe Fontaine wrote:
      the stbd lazarette. I added two size 24 starting batteries in the same
      locker, just aft of the house bank. No charger/inverter.
      Phil
    • #77397
      Phil Fontaine
      Rick,
      At the time I was upgrading the electrical system (1999) and had decided to
      install a dedicated engine cranking source I had difficulty finding
      battery sizing information for the W 60. My Westerbeke manual wasn’t of much
      help. I knew that others had installed a single battery (of size and
      effectiveness unknown to me), so, since I had room for two batteries, I
      decided to err in the overkill direction. Redundant batteries also appealed
      to me. Having all the batteries in close proximity to each other also seemed
      to simplify
      the wiring to the three switches (one of which permits both banks to be
      hooked up in parallel should the need arise).
      I know that the practice is usually discouraged but, I use dual chemistry.
      The house batteries are gel and the cranking batteries are flooded. I have a
      dual output alternator which is regulated by the needs of the house
      batteries and safe for the cranking batteries. So far so good.
      Phil
      —- Original Message
    • #77398
      I think my boat was as close to factory when I purchased her. She had inverter in port laz. There were 2 batteries in starboard laz.
      So I believe the answer is starboard laz.
      Eric Lorentzon
      412.352.1941
