Forums › General Discussion › how to get mast tang bolt out?
Viewing 1 reply thread
    • #68281
      I have managed to get all the hardware off my masts except for the bolt
      that holds the lower shroud tangs. The bolt will not come out. It will
      turn, but so far I have not been able to drive it out.
      It appears the bolt is stepped at the threaded end to keep the mast from
      being compressed. Is that actually a stepped bolt or is there a metal
      sleeve on the bolt that is stuck in place. If so, how have others
      gotten this out? As you can see, I have been bathing the bolt in PB
      Blaster (from both sides), so far without any results. (Also as you can
      see, from the picture, I got rained out today).
      Picture: http://www.dublerfamily.com/Regina_oceani/tang_bolt.JPG
    • #76877
      It’s a stepped bolt. The yard cut one end off to get it out. I went with a
      sleeve over a bolt on rebuild.
      sleeve on the bolt that is stuck in place. If so, how have others gotten
      this out? As you can see, I have been bathing the bolt in PB Blaster (from
      both sides), so far without any results. (Also as you can see, from the
