Most of the inside hull surface of our 1979 424 is lined with a thin layer of foam insulation coated with a kind of rough brown vinyl-like surface. I’m assuming it’s original equipment.
Anyone else out there have that? And have you come up with a reasonably efficient way to remove it?
My first attempt to remove a small section of it involved a lot of scraping and sanding and way more time than seemed like should be necessary.
