Forums › General Discussion › Kubota Generator
  • This topic has 14 replies, 4 voices, and was last updated 17 years ago by Anonymous.
Viewing 14 reply threads
    • #67702
      Alan,
      How do you plan to cool the engine?
      Lee
    • #73746
      SEZ right there he got a heat exchanger. Am I missing something???
      On 9/25/09 5:53 PM, Lee Yonkers wrote :
      Alan,
      Lee
    • #73747
      Ah! But the devil is in the details. I have pretty much the same setup. . . a Kubota engine, turning a 150 amp alternator, a heat exchanger keeping everything cool. Where I am having trouble with my setup is the raw water pump that feeds the heat exchanger. I want a continuous duty 12 volt pump that is self priming and will last more than two years. The raw water pump I installed two years ago, a Flo-Jet, gave up the ghost and I doubt it had more than 20 hours on it. I don’t believe the pump needs to move more than 2 gallons per hour.
      Lee
    • #73748
      Hi Lee,
      You definitely need more than 2 gallons per hour.  Try this:  http://groban.com/Pumps_Water_Jabsco_Pump_1673-001.html I purchased two of these as spare water pumps for a W58.  It is self priming up to 10 feet, I think, and your generator is well within that distance to seawater. You may have to drill holes in the feet and change the fittings for bronze, but for $89, you could screw one up and still purchase two more for less than an Oberdorfer.
      PS, you'll probably waste a lot of time browsing through the Groban site because there is a lot of neat stuff…
      On Sat, Sep 26, 2009 at 5:19 AM, Lee Yonkers < ([email][/email])> wrote:
      Ah! But the devil is in the details. I have pretty much the same setup. . . a Kubota engine, turning a 150 amp alternator, a heat exchanger keeping everything cool. Where I am having trouble with my setup is the raw water pump that feeds the heat exchanger. I want a continuous duty 12 volt pump that is self priming and will last more than two years. The raw water pump I installed two years ago, a Flo-Jet, gave up the ghost and I doubt it had more than 20 hours on it. I don't believe the pump needs to move more than 2 gallons per hour.
      Lee
    • #73749
      Bob,
      I would like to power the pump using the Kubota, but I just don’t see any practical way of mounting the pump up there. Do you believe a small 12V DC motor would suffice? My experience base with DC motors stops with starter motors.
      Lee
    • #73985
      Robert,
      WOW! what a find! I paid a lot more than that for the pump I used. Here is a photo of how I mounted it. The “oil pan” of the Kubota is replaced by a 3/8 thick aluminum sheet (which I home anodized after machining). There is a slight slot milled on the pump side of that plate, two screw slots, and counter slots for the heads of the bolts on the other side. The pump bracket, just a thick angle of aluminum, then can slide up and down a little in the slot to allow for the tensioning of the belt. I used a kevlar/poly belt.
      Robert Fine wrote:
      Hi Lee,
      PS, you’ll probably waste a lot of time browsing through the Groban site because there is a lot of neat stuff…
      Lee
    • #73750
      Hi Lee,
      There are definitely 12v continuous duty pumps for corrosive
      environments. Look at Graingers, McMaster-Carr, or Tractor Supply
      (used for fertilizer and herbicide/pesticide applications). There are
      also a/c pumps for marine use that are not self priming, but are
      continuous duty and can be mounted in the bilge.
      I can get model numbers, but so can you…
      On 9/26/09, Lee Yonkers <> wrote:
      Bob,
      motors.
      Lee
    • #73751
      Lee:
      Alan had asked the same question on the SSCA DB. Here is the thread:
      http://www.ssca.org/phpBB3/viewtopic.php?f=4&t=8747
      http://www.ssca.org/phpBB3/viewtopic.php?f=4&t=8747Paul
      Date: Sat, 26 Sep 2009 12:05:41 -0400
    • #73752
      Pete,
      Your solution will solve my problem perfectly. I checked my Kubota and where your engine driven drive is located I seem to have a plug of some sort. I stuck me finger in the hole and I felt a machined plug. Can you give me any more information on how you got the – for the lack of a better term – power take off to work? I appreciate any help/information you can give me.
      Lee
    • #73753
      My Kubota had a provision for a hand crank. I used a disk
      grinder/parting disk to cut away the housing around that shaft. Then I
      sawed off and ground smooth the pins on that shaft where the hand crank
      would have gone. I understand that there are versions of this engine
      that do not have a shaft emerging from the case here but rather have the
      hole plugged where the shaft seal would have gone. If your shaft does
      not not emerge from the case, you might be able to swap out this shaft,
      but that would involve a pretty extensive teardown of the engine.
      Lee Yonkers wrote:
      Pete,
      Lee
    • #73754
      The missing shaft is gear driven from the inside. If you did find the shaft, to install it you’d have to tear the engine apart.
      My solution is to use a 12v water puppy for cooling. I’ll have it come on after the engine starts up ( oil pressure switch). I ve been working on it as I travel down the Hudson river.
      I’ll let you know how I make out.
      — On Sat, 9/26/09, Pete Dubler <> wrote:
    • #73755
      Hi Alan,
      If the shaft you have is what I think you have then there is an
      Obedorfer pump with the proper shaft to slip directly into that hole
      and engage the shaft. There should also be two bolt holes near that
      hole to mount the pump.
      Any Universal dealer will have the pump, but a Kubota dealer might,
      too. Also, a Beta Marine dealer. It is as expensive as any marine raw
      water pump (Panda Generators use that engine, too as does some other
      generator manufacturer_)
    • #73798
      Sorry for the long delay in responding. Ive been traveling down the Hudson River and internet is spotty at best. I am in NYC now and have a good connection.
      Some models of the E300 have that shaft and some model don’t. If you have the shaft than the pump you have suggested will work. If you don’t have that shaft, then the case will need to be opened and the shaft installed. It depends on which model you have.
      Mine does not have the shaft. Just a hole with a plug in it. I have the shop manual.
      Somehow Ive lost most of this thread. Who else besides Pete and I have been fooling around with a Kubota.
      — On Sun, 9/27/09, Robert Fine <> wrote:
    • #73804
      Alan,
      I have been trying to figure out how to cool my Kubota. I much prefer using an engine driven pump rather than a 12 V driven one. I would love to have a copy of the shop manual.
      I pretty much have given up on the engine driven pump for this season. I called Depco pumps and told them what I needed from a 12V pump and they recommended one for me. It should be here this week and I’ll install it. Next summer I’d like to either add the shaft or try to see if I can get Phasor Marine to help me convert to their system.
      Are you going to Annapolis?
      Lee
    • #73811
      I”ll be Annapolis for the boat show if the weather clears up here in NYC.
      Would love to get together.
      I have the shop manual but no way to copy it for now.
      — On Tue, 9/29/09, Lee Yonkers <> wrote:
