Forums › General Discussion › Lazy jacks -spreader droop
- This topic has 4 replies, 3 voices, and was last updated 15 years, 2 months ago by
August 17, 2011 at 1:48 pm #68402
RichCarterParticipantI’m pretty sure we all have the same spreaders. I found that mine would slide down the upper shroud below even 90 degrees. I put a small cable clamp on the shroud so they can’t slide down. I wish the hardware on the mast were a little more robust.
August 17, 2011 at 2:18 pm #77523
Hi Rich,
Yes, spreader tips can slip, often on the leeward side when beating hard
(because the upper leeward shrouds lose some tension). Like you, I used
cable clamps to support Silverheels’ spreader tips, but I’ve used
stainless wire seizing in the past with equal success.Tor
August 17, 2011 at 3:42 pm #77524
ParticipantGents-
I too use ss seizing wire . then a nice robust rubber spreader tip cover
along with fresh tape and this seems to work well. Never had a problem with
the tip sliding down.Rodd
Windseeker
August 17, 2011 at 5:23 pm #77525
RichCarterParticipantSo what do you do with the seizing wire? Just wrap it around the shroud and spreader tip?
August 17, 2011 at 6:45 pm #77526
Basically, yes. I believe in the past I’ve wrapped a layer of rigging
tape around the shroud first, to give the wire more bite. The wire
shouldn’t have to support any great downward force on the spreader tip.
It’s just to keep it from slipping along the shroud. Seems like a cable
clamp will provide stronger tip support.Tor
