Forums › General Discussion › Lazy jacks
Viewing 17 reply threads
    • #68398
      I need to install a system as my new sail does not have the Dutchman buttons installed ( Dave, my sailmaker, was adamant about not putting more holes in “his” sail).
      Any one have a layout they are happy with?
      Eric Lorentzon
      EFI Sales Development Manager
      412.352.1941
    • #77501
      I have always had strong feelings against lazy jacks. Although convenient
      when into the wind, they don’t allow setting or dousing sails off the wind.
      A favorite trick of mine is to lower the main behind the jib, in other
      words, let the main out far enough to back wind and then drop it. Big no-no
      with lazy jacks.
      They create wear on the sail, they’re only useful when the sail is down,
      they are a constant source of irritation (to me) when dealing with the main
      halyard, more things to wear out. I’m sure given enough time I could come
      up with more.
      But for every reason I don’t like lazy jacks there is someone on the list
      absolutely loves them.
      Eric Lorentzon
      412.352.1941
    • #77502
      I like the Doyle Stackpack a lot. You can pull the lines forward to the
      mast so they don’t wear on the sail and no more holes in the sail. Plus
      you get a great sail cover in the deal.
      Eric Lorentzon
      412.352.1941
    • #77503
      Any lazy jack system should definitely be retractable. There are many
      drawings on the web which should help in designing.
      On Aug 15, 2011, at 4:09 PM, Pete Dubler wrote:
      I like the Doyle Stackpack a lot. You can pull the lines forward to the mast so they don’t wear on the sail and no more holes in the sail. Plus you get a great sail cover in the deal.
      Eric Lorentzon
      412.352.1941
    • #77504
      Phil Fontaine
      Hi Eric and Bob,
      I installed EZ-JAX http://www.ezjax.com/ on both main ($185) and mizzen
      ($135) in 1997and have been happy with the system. The only maintenance has
      been to replace, a couple of times, the shock cord that holds them when
      stowed. Seems to me that they solve most of the things Bob objects to.
      Phil
      Aurora
    • #77505
      Phil Fontaine
      PS – The prices noted are the old prices. The current prices on the web site
      are more like $420 and $250.
      Phil
    • #77509
      Eric,
      I’ve had lazy jacks on all my cruising sailboats since the ’70’s.
      Wouldn’t sail without ’em. Cheap, simple to make, quick to retract and
      necessary for keeping the mainsail under control when dousing it, which,
      of course, stack-packs also do. On the downside, lazy jacks create some
      extra windage when it’s blowing hard, and can snag on battens when
      raising the mainsail on a broad reach, but as I said they’re quick to
      retract to the mast if they’re in the way – as when setting a boom
      awning.
      Contrary to some claims otherwise (Bob), lazy jacks do not prevent
      dropping the main off the wind. I do it whenever it suits me. You just
      need to tug at the sail’s leech and it’ll drop right down into the
      loving arms of the lazy jack lines. In fact, that’s when you want lazy
      jacks most, to contain the sail and keep it from flogging out over the
      decks. They do not create wear on the sail and a set will last for years
      if not decades.
      Attached is the plan I drew up for Silverheels’ lazy jacks. I don’t have
      a good photo of those lines, but you can just make them out in the
      attached snapshot.
      I’m not near the boat right now to check, but I think I used 3/8″ line.
      The upper ends of the main (hypotenuse) lines pass through small padeyes
      (blocks really aren’t necessary) under the spreaders, a foot outboard of
      the mast sides to prevent slatting and give the sail a little more room,
      and then run down to small cleats seized to the shrounds. Leave enough
      extra line so you can lower the lazy jacks from those shroud cleats.
      Also, do not make the aftermost vertical loop continuous under the boom
      as are the others). Instead, make that last verticle loop two separate
      halves, which tie together beneath the boom to form the loop. This way
      you can untie them and slide the entire assembly forward to the mast
      (without lowering it), i.e., quick to retract.
      Have fun,
    • #77510
      I think, Tor, that your solution of placing the hypotenuse out on the
      spreader is the biggest innovation for these things. The only problem I can
      see with that is that heavily or shock loading the lazy jacks can pull the
      spreader down and out of its proper alignment. You can do that with flag
      halyards as well. The spreaders should NOT be level, but should bisect the
      angle between the lower part of the shroud and the upper part. Usually they
      end up level because it ‘looks better’ but the stress of the shrouds is not
      directly centered on the spreader but offset. Will this cause a rig
      failure? Clearly not, but in a situation where the mast might pump it could
      work the spreader down and release the shroud.
      Other than that, I’ve found the sails to be small enough to easily handled
      even off wind. They might not end up prettily flaked but there’s always
      time for that in port.
      2011/8/16 Silverheels
      Eric,
      awning.
      if not decades.
      attached snapshot.
      Have fun,
    • #77522
      Hey Bob,
      I didn’t mean you had to use lazy jacks. What works for you is right for
      you. My point to Eric was that if he wants a mainsail containment
      system, he could keep it inexpensive and simple by using lazy jacks.
      Now, I suppose if someone climbed up on them and did gymnastics for a
      while they could pull the spreaders down. Or the rig could be struck by
      a meteor. I guess I’ve been lucky. That hasn’t happened to me in the 35
      years I’ve been using them.
      And you’re absolutely right about the correct spreader angle. I’d say
      maybe 25% of the boats I see get it right.
    • #77527
      Hey, Tor!
      I understand that. I suppose I get a little argumentative. My bad. If
      sailing teaches us anything at all it’s that those of us that survive to
      sail another day find our own ways of doing things. Lazy jacks or no,
      whatever works.
      I had forgotten about yours mounted to the spreaders. I remember thinking
      then (and still do) that it was the thing that made lazy jacks really
      workable. If I weren’t lazy Bob, I’d probably try lazy jacks.
      On Wed, Aug 17, 2011 at 10:11 AM, Silverheels wrote:
      Hey Bob,
    • #77528
      Argumentative is the nature of Captains, amigo. Anyway, I sort of threw
      the first jab. My bad.
      I think they’re called “lazy jacks” because they suit a lazy sailor, a
      “lazy Jack,” by making the job of handing sails easier. I got used to
      them on my early gaff-riggers and carried the idea from boat to boat
      ever since. An added bonus is that lazy jacks confuse landlubbers by
      adding a bunch more lines to the rig, making it appear even more
      complicated.
    • #77529
      Thanks all for the input.
      Tor I am doing a hybrid of your system. Will see if it works….
      By the way – on the spreader tips I am testing a system I designed that play two roles – keeps the spreaders fixed at the proper angle and reduces chafe on any headsail that my come in contact with the spreaders.
      May be looking for a couple beta testers.
      Eric Lorentzon
      412.352.1941
      complicated.
    • #77530
      Eric,
      There are any number of lazy jacks designs, all of which do pretty much
      the same thing. No doubt there are articles galore on the subject in the
      various sailng magazine archives online. Just be sure yours are easily
      retractable to clear the way for a deck awning, etc.
      Have fun. I’m heading back into the forests of north-central Idaho again
      aboard my VW campervan, “SilverWheels.”
    • #77579
      Herbc
      Just yesterday I installed LJs using small 1/8 dacron cord as 3 verticals threaded about 12 inches into the hollow of 7/64 amsteel. wrapped approx 10 inches from mast on the spreaders and then back towards the forward bail. Looks great and today I will raise and lower to test with no wind dockside. Will tweak some under sail, this is a simple low cost system with no blocks and very little chaff oppurtunity. Later after it all settles in will remove the knots from the verticals and let the “chinese finger” effect hold the cord in the amsteel. The fellow helping me has this on his main and removed his topping lift, I’m not ready for that but it is a possibility. Our life aboard will be MUCH easier and the main will get much more use. Up next the mizzen LJs.
    • #77580
      Herb
      Could you post a pic. I may try to do lazy jacks after hurricane season.
      Coastal living has a cost I guess.
    • #77581
      Herbc
      https://picasaweb.google.com/105734688941948806936/LazyJacks
      try the link above. Will be trimming and seizing to get a finnished product.
    • #77582
      Herb
    • #77608
      Herbc
      with the main up and pulled in hard, per my friends advice, I retied the verticals to lightly touch the leeward side of the main with no pressure to affect sail shape. Seems to work great and even lowered on a dead downwind the other day. Now I have to trim the excess cord and take the amsteel off the forward bail or maybe just cut in the middle and secure to the forward bail up near the bolt running thru the boom. Something like that.
