Forums › General Discussion › Leaks and the eyebrow teak
- This topic has 5 replies, 3 voices, and was last updated 18 years, 6 months ago by
unabated.
April 11, 2008 at 2:30 am #66916
SpectatorI took the P424 I’m evaluating today out for a test sail. Originally I thought the portholes leaked and all needed replacing. Now I think the eyebrow teak along the cabin top may also be to be blame. It is loose in few places and definitely waterlogged in a couple as well.
I saw one P424 site where the owner had removed a stainless steel eyebrow, closed all the holes up and put a stripe over it all to keep the eyebrow look and hide the now non-matching gel-coat.
I’m curious if any of you have had leaks through the eyebrow and how you’ve dealt with it. I think I’d go the route of removing it completely. Am I correct in thinking what is under this is just a bunch of holes every few inches and a bunch of glue/caulking which needs to be removed?
-pOwners no more...
April 11, 2008 at 2:33 am #69474
SpectatorOne more question about the cabin top teak eyebrow and portholes. Are the vertical portions of the cabin top through which the portholes are mounted cored or is it solid fiberglass.
Thanks…
-pOwners no more...
April 11, 2008 at 10:16 am #69476
ParticipantI removed mine, sanded the wood, put on a couple coats
of Ceatol (ALL 6 SIDES) and put it back on. No leaks
since then. Just normal maintainance on a 30 year old
boat.
— Patrick_Seattle <> wrote:I took the P424 I’m evaluating today out for a test
couple as well.I saw one P424 site where the owner had removed a
and hide the now non-matching gel-coat.I’m curious if any of you have had leaks through the
needs to be removed?Thanks,
http://shipsrecord.com/blogs/patrick__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
April 11, 2008 at 11:48 am #69478
RichCarterParticipantThe teak trim along the coach top is a possible point for leaks. Pearson used silicone sealant for bedding the thing. Teak cleaners and age can cause the sealant to leak. There is no harm if water gets under the trim, but having it get through the screw holes and into the cabin is another story. I suggest removing the screws and rebedding them with proper caulking. If you do a few at a time, it is no big deal. There is no need to remove the trim. I’ve done this as leaks developed, but I’ve decided to rebed them all this summer to be sure that I get them all.
April 11, 2008 at 11:49 am #69479
RichCarterParticipantSolid
April 11, 2008 at 12:02 pm #69481
ParticipantI am almost postive mine are cored. I have one out now
to start replacing the ports with ones from
NewFoundMetals. I’ll be out there tomorrow. I’ll let
you know.
— wrote:Quote:Solid—
