Forums › General Discussion › LED spreader lights
Viewing 13 reply threads
    • #68494
      I need to replace my spreader lights. Does anyone have a recommendation for
      an LED replacement?
      BlackSheep #47
    • #78091
      Go to yachtlights.com they have some nice spreader lights.
      for
      an LED replacement?
      BlackSheep #47
    • #78092
      I don’t know about LED’s, but when I replace my spreader lights I
      noticed the swivel mounts were a lot more expensive than solid mounts.
      So I got one of each and it worked out great. The fixed mount aims
      straight down and the swivel angles onto the foredeck.
    • #78093
      I am impressed with the Kimerlite
      Product line and am usi.g them for all the exterior lighting on our refit
      Sent from my Android phone which is programed to entertain you with creative spelling corrections.
      Subject: Re: LED spreader lights
    • #78106
      I have a pair of Dr LED’s spreader lights. Model name is KEVIN. LOVE them!
    • #78107
      Pete,
      Can you provide a URL for Kimerlite or a source. When I Google it I don’t
      get an LED supplier.
      creative
    • #78108
      John,
      I think the spelling was wrong and it is Kimberlite and they are part of the MISEA Group. I see they also bought SCAD.
      http://miseagroup.com/
    • #78109
      Thanks, Paul.
      10 years ago I installed Perko spreader lights. No exterior LEDs back
      then, or at least I wasn’t aware of any. The Perko lamps are very bright
      (35W Sealed Beam) and draw a lot of juice. However I don’t use the
      spreader lights often, and then only for a few minutes – so efficiency has
      never been an issue with these lights. The problem I’ve encountered is
      bulb longevity. So far I’ve had 4 bulbs burn out, even with the limited
      use. At $50 per bulb via WM, those $250 Signal Mate lights are looking
      comparatively economical, assuming a typical LED service life. I just
      bought my 4th Perko bulb, so I guess I won’t be changing the spreader
      lights for at least another year.
      On Thu, Jan 12, 2012 at 3:48 PM, Paul Lefebvre wrote:
      John,
    • #78110
      I got mine from Port Supply (WM) 5 years ago, some generic brand with no
      marking except “Made in Taiwan.” Don’t use them very often (and yes,
      they suck up the amps), but they do the job and haven’t failed yet.
    • #78111
      http://www.miseagroup.com/solutions/index.php?main_page=index&cPath=28
      On 1/12/2012 12:36 PM, John Stevenson wrote:
      Pete,
      creative
    • #78112
      Orca, SCADtech, and Kimberlite combined. I am not sure if they are
      still together as such but the addresses in the website are for the guys
      at Kimberlite.
      Pete (was the “D” in SCAD)
      On 1/12/2012 1:48 PM, Paul Lefebvre wrote:
      John,
    • #78113
      I have my spreader lights both on a timer and on a remote control so I
      can turn them on from the dinghy at a distance. I wrote an article on
      this once… I will see if I can find it again.
      On 1/12/2012 2:46 PM, John Stevenson wrote:
      Thanks, Paul.
      On Thu, Jan 12, 2012 at 3:48 PM, Paul Lefebvrewrote:
      John,
    • #78126
      I bought a pair of TACO LUMA LED deck lights. They may not be as fancy or
      as powerful as some of the other units but they were affordable ($60 ea) and
      look like they will servie my purpose. I measured less than 200ma at
      13.8vdc. This compares with about 5A each for the old spotlights.
    • #78127
      Impressive power consumption reduction! Next time I’ll go with LED, too.
