Forums › General Discussion › LED TV power supply
Viewing 9 reply threads
    • #68108
      Folks, this is a request for help from the electronics experts in the group.
      I just found at HH Greg some combination 13″ ED TV/ DVD players with all the bells and whistles like PC input for $100. The power supply is a converter that provides 12v DC @ 3 amps. I’d like to power them off the boat batteries, but I’m a little worried that the charging voltage (14.4v) might be too high. Manufacturer (Curtis) was not helpful.
      Can someone tell me where to get or how to make a device that will limit DC power to 12 volts?
      Thanks!
    • #75860
      Quent,
      I made a voltage regulator from Radio Shack parts (<$5) back in the 80s.
      I’m not an electronics expert, so I used a circuit design in the 12V
      Doctor’s Project Book. I doubt that book is still in print, but you might
      be able to find it on eBay. That is the one of his books I do not have
      onboard. I must have loaned it to a “friend”. I checked on Amazon.com and
      they do not have it.
      The voltage regulator I built will do what you asked for, but it may not do
      everything you need. That is it will maintain 12v output as long as the
      input voltage is 12v or higher. When the input voltage drops below 12v so
      does the output. You might contact Lind Electronics to see if they have
      some thing that will work for you. They primarily make DC power adapters
      for laptops (e.g., 12v to 18v), but they might have something that just does
      12v-12v.
      There is always the option of running it off an inverter.
      group.
      power to 12 volts?
      Thanks!
    • #75862
      To my experience, the power bricks do not provide a high degree of
      regulation and where that higher degree of regulation is required, that
      regulation is provided within the TV. I run my LCD TV on the boat
      directly from the house 12V and have had no problem.
      Thanks!
    • #75864
      That’s probably good advice. If the voltage is too high, the power supply in the TV set might get hot. My guess is they’ve designed in enough margin to handle a higher voltage. Try it when your engine is running and your batteries are 14.4v. If the TV doesn’t get hot, you’re OK.
    • #75865
      Thanks, guys. You are all very helpful. I looked at 12 Volt Doctor book and as John suspected, the input voltage has to be 2 volts higher than the regulated voltage. I guess I could build one and connect it with a relay to a voltage sensing switch, but first I’ll just try the TV on 14 volts as Pete and Rich suggest. Besides, watching TV with the engine running would be unpleasant anyway. Might never happen.
    • #75866
    • #75867
      There are a lot of good instructions on how to build these on the
      internets.
      http://www.google.com/search?q=make+DC+voltage+regulator&btnG=Search&hl=en&rlz=1C1GGLS_enUS359US359&sa=2
      <http://www.google.com/search?q=make+DC+voltage+regulator&btnG=Search&hl=en&rlz=1C1GGLS_enUS359US359&sa=2>They
      look pretty easy and might be fun to do.
      Another alternative for “perfect” power is look into the DC to DC power
      supplies that the mobile auto computer kids are using:
      http://www.mini-box.com/s.nl/sc.8/category.13/.f
      http://store.mp3car.com/Power_Products_s/2.htm
      <http://www.mini-box.com/s.nl/sc.8/category.13/.f>
      On Thu, Aug 19, 2010 at 8:04 AM, John Stevenson <>wrote:
      Quent,
      does
      12v-12v.
      group.
      (14.4v)
      DC
      power to 12 volts?
      Thanks!
    • #75868
      Those 80 watt or larger dc-dc supplies would do the job. Very nice.
      Good find Patrick.
      Would want to check the RFI on these (put a handheld scanner next to it
      and see where it interferes).
      internets.
      On Thu, Aug 19, 2010 at 8:04 AM, John Stevenson<>wrote:
      Quent,
      does
      12v-12v.
      group.
      (14.4v)
      DC
      power to 12 volts?
      Thanks!
    • #75869
      I’ve been a doing a lot of low power fanless DC powered PC research to use a
      navigation and comm (hooked to the SSB) computer, that’s how I stumbled on
      that.
      On Thu, Aug 19, 2010 at 12:37 PM, Pete Dubler <> wrote:
      Those 80 watt or larger dc-dc supplies would do the job. Very nice. Good
      find Patrick.
      Would want to check the RFI on these (put a handheld scanner next to it and
      internets.
      They
      wrote:
      Quent,
      might
      and
      do
      so
      does
      12v-12v.
      group.
      (14.4v)
      DC
      power to 12 volts?
      Thanks!
    • #75870
      That book is kinda old. You can get “LDO” (low drop out) regulators
      today that are able to work with 0.3V or less of margin.
