Forums › General Discussion › LinkPro Installation
Viewing 13 reply threads
    • #68446
      I was just talking to the Xantrex folks and they don’t seem to understand
      the wiring I have.
      My batteries have various LOADs using the negative posts instead of a
      busterminal strip. No real problem there in my current installation.
      My alternator is NOT case grounded. It has it’s own Negative wire back to
      the batteries.
      I also have a wire that goes form Negative to my engine block.
      When I install the shunt for the LinkPro, all of the LOADS (in or out)
      Negative wires need to go on one post of the shunt and the battery Negative
      on the other post.
      So the question is, what is that wire that goes to my engine block? Seems
      like’s part of the NEG of my system and my bonding as well. Because when we
      had the engine out, if I didn’t hok that wire to the bonding wire to the
      post on the prop strut under the engine I could not run any DC loads.
      So, given that should that wire go on the Load side of the shunt?
      I love when I call tech support and they don’t have any clue either. 😉
      Thanks!
    • #77855
      Hi Pat, there is something very wrong going on here. You need a grounding
      buss that all your loads go to, including the engine ground. From there, one
      wire to the shunt and one wire from the shunt to the batteries.
      Normally, alternator cases are grounded by the bolts that hold them in
      place, and no wire goes separately to the battery grounds. If it does in
      your case, put it to the buss bar I mentioned earlier.
      One thing that may be confusing the issue here is that a connection anywhere
      on a wire is the same as anywhere else. That may help you simplify what
      you’re trying to see in your head.
      On Oct 12, 2011 1:43 PM, “Patrick "Peaboy" Walters” <
      the wiring I have.
      the batteries.
      on the other post.
      Thanks!
    • #77856
      Very simply stated…. if you want the LinkPro to measure battery usage, it must go through the shunt. If the particular object does not go through the shunt, but is directly connected to the battery, it will work, but it’s current usage will not be registered by the LinkPro.
      So, things like the starter and fuel solenoid, which are case grounded, use the grounding wire (BIG black cable). In your case, if that big cable is not connected to the shunt. They will continue to operate, but their current usage will not be shown on the LinkPro.
      Thats my understanding. YMMV
    • #77857
      Well said, Alan. True, dat. Also, I am concerned that you have to connect to
      a bonding point for stuff to work. That’s absolutely wrong.
    • #77858
      My alternator had a separate grounding terminal, but it’s for the voltage regulator ground.  The alternator is indeed case grounded, else you would need a grounding cable as big as the positive cable…… and this grounding terminal is only for a  small gauge wire.
      — On Wed, 10/12/11, Robert Fine wrote:
    • #77859
      Ok, then as long as the engine ground goes to the shunt, you’re good to go.
    • #77860
      I agree also, the bonding (and most of mine is disconnected, that discussion is akin to anchors ) should not be used to run anything.
      Just a hint to the future, make sure your bonding is clean (noise wise) else you will have difficulties down the road with a SSB installation.
    • #77861
      Shunt or battery will still work.  A much cleaner  install would be for it to go to the shunt. One less connection to the batteries. That way when you crank your starter for 30 minutes trying to start your engine all those little amps will be subtracted from the reading on your LinkPro.
      Patrick must have another issue with the bonding thing
    • #77862
      I do believe though when I had my engine out, the bonding wire for the strut is connected to the same bolt on the port side of the engine block as the grounding cable. On the Stb side of the engine, the bottom starter mounting bolt, is the continuation of the bonding to the strainer and other devices.
      — On Wed, 10/12/11, Patrick “Peaboy” Walters wrote:
    • #77864
      I had the Link 2000 which can monitor two banks of batteries and has a
      double shunt, one for each bank. I had the starter battery on one and
      the house batteries on the other. I found very little value in
      measuring the amps in/out of the starter battery, though having the
      voltage is a bit useful. All that said, you need to decide what data is
      most useful to you. I would proffer that monitoring the house battery
      in/out is most valuable.
    • #77866
      Very true Pete. I have the link 20 which has 2 banks also. It does not have the VR like the 2000. Very little knowledge comes from the start bank, but monitoring the voltage is a good thing.
      After a while you get a sense of  your daily usage of amps and can tell right away when something has gone awry.  So I tend to put everything though the shunt.
      — On Wed, 10/12/11, Pete Dubler wrote:
    • #77875
      On my engine on the port side one of the bolts to the starter goes to the
      bonding wire to the prop strut.
      On the starboard side, above the Temp Switch there is a bonding wire and a
      NEG wire that goes to the battery NEG.
      That is probably because my old Alternator was case grounded (i.e. NEG went
      through the foot to the block) so it had to get back to the battery somehow.
      So in the old system the NEG and the Bonding were connected.
      Because of this, or maybe because of ignorance, My PO just used the bonding
      terminals in the electrical panel as NEG.
      Since we plan on leaving Monterey tomorrow and head around Pt Concepcion,
      I’m going to leave everything as-is for now and the Link Pro will stay in
      the box. Its obvious I have a larger wiring project on my hands. I did make
      the change to hook the alternator directly to the House bank and now the
      starting battery is charged through the Blue Sea ACR.
      Not being able to install the LinkPro is kind of sad because I just dropped
      in 6 new Interstate GC2-XHD-S which are the replacements for the U2200 which
      came with the boat. They are also a tiny bit larger at 239 Ah vs
      220Ah. Interstate was great do deal with. They came by in their delivery
      truck, dropped the new batteries off on the deck and took away the old cores
      for $100.95 per battery. That was a great deal because when I talked to the
      guy on the phone, I thought they were $195. 😉
      Wish us luck as we head South again. We’ll get this wiring cleaned up and
      LinkPro installed in either San Diego or Mexico after the Baja Ha-Ha!
      Viva Mexico!
      devices.
      wrote:
    • #77876
      “My PO just used the bonding
      terminals in the electrical panel as NEG.”
      True, because of that, the bonding wire does have a NEG potential (respect to POS or +12), but they are not supposed to be used as NEG RETURNS.
      Not sure what kind of alternator you have, but if it’s NOT case grounded, your NEG cable on the alternator should be as big as the POS cable. Is it?
    • #77877
      Yep, All the wires to/from my alternator are 2/0 as is the wire to the
      starter from the starting battery and all of my battery cables for
      that matter.
