Forums › General Discussion › lucky breakdown
- This topic has 9 replies, 4 voices, and was last updated 13 years, 5 months ago by
May 15, 2013 at 9:03 pm #68722
Silverheels cast off at 0700 hrs. today, bound for St. Maarten, possibly by
way of Bermuda. The voyage lasted nearly 4 minutes. We’re now dockside again
waiting for a new Shaft-Lok to replace the one that self-destructed as we
left the dock this morning. (The main shaft bearing came apart with a great
grinding and gnashing of teeth.) Hoping we’ll be Ready for Sea (again) by
tomorrow afternoon, thanks to USPS overnight delivery. Feeling very
fortunate that the equipment failure occurred where and when it did rather
than 600 miles at sea.I’ve used some of this extra shore leave to download and complete the
Bermuda clearance form, as advised by John, Frank and others. Thanks for
that heads-up.Would the powers that be please remove me from receiving this group’s
emails, beginning this Friday until I request reinstatement (when I’ll
download the correspondences I’ve missed)? Thanks!Tor
May 15, 2013 at 9:07 pm #79477
john stevensonParticipantTor,
I think you can unsubscribe from this link:
https://pearson424.org/mailman/listinfo/maillist_pearson424.orgIt’s at the bottom on each email on the list.
again
May 15, 2013 at 10:55 pm #79479
ModeratorLet me see what I can do – fair winds, my friend – just email me and I’ll
re-instate you.Bob
On Wed, May 15, 2013 at 5:06 PM, John Stevenson wrote:
Tor,
by
again
left the dock this morning. (The main shaft bearing came apart with agreat
fortunate that the equipment failure occurred where and when it didrather
May 15, 2013 at 10:58 pm #79480
ModeratorDone and done.
re-instate you.Bob
Tor,
wrote:Silverheels cast off at 0700 hrs. today, bound for St. Maarten,
possibly by
again
waiting for a new Shaft-Lok to replace the one that self-destructed aswe
great
by
http://thesailinglife.blogspot.com—
May 16, 2013 at 12:59 am #79486
ParticipantTor,
Sorry to hear, but as you say, fortunate that it happened close to the dock.
Where is the main shaft bearing.
May 16, 2013 at 1:39 am #79488
Hi Pete,
“> Where is the main shaft bearing.”
I’m no mechanic, so I’ll describe it in my own terms: I have a Paragon
transmission. They don’t lock the prop shaft under sail, even if you put
them in gear. So the prop free-wheels. The Paragon also doesn’t pump oil to
its internal parts when the engine is shut off, so when the prop is
freewheeling the tranny suffers wear and tear that (I am told) will
eventually cause significant harm. Also, I don’t like the noise of a
freewheeling prop under sail. Ergo, I installed a Shaft-Lok on the drive
shaft (or “jack shaft”), the short shaft connecting the transmission to the
V-drive. The Shaft-Lok embraces the shaft with a bearing – ball bearings in
a ring, held by retainers and a retaining ring. That bearing is what
self-destructed this morning. The retainer ring broke apart and the bearing
ball retainer clips (if that’s what they are) jammed against the drive
shaft. Hence the horrendous grinding noise and subsequent gnashing of teeth.Clear as mud?
May 16, 2013 at 3:24 am #79489
ParticipantCrystal clear. Â The bearing is partof your shaft brake. Â Got it. Â No bearings in the brake on mine. Â It used that on with the go cart brake pads.
Have a great sail!
Sent from my Samsung smartphone on AT&TSilverheels wrote:Hi Pete,
I’m no mechanic, so I’ll describe it in my own terms:Â I have a Paragon
May 16, 2013 at 12:38 pm #79490
Pete,
I’d like to know about your shaft brake. Can you describe it and/or send me photos or literature (or a URL)?
May 16, 2013 at 9:08 pm #79494
ParticipantTor,
I don’t believe it is still made. Â it used a disc like used on car disc brakes. Â A small hydraulic cylinder slides a carriage that spreads the brake pads when the engine is running a the granny fluid is pressurized. Â The carriage is cleverly designed so that the pads a pulled tighter if the prop sound the shaft while the brake is engaged. Â It’s property much a set and forget system as it automatically engaged whenever the engine is off and releases when the granny is spinning (forward, rev, on neutral).
Go to this link to see the provide manual   http://www.dublerfamily.com/Regina_oceani/Manuals/Drive%20Train%20and%20Fuel%20System/PropLock/
Sent from my Samsung smartphone on AT&TSilverheels wrote:Pete,
May 17, 2013 at 12:03 am #79495
Thanks, Pete.
