Forums › General Discussion › maillist Digest, Vol 13, Issue 16
Viewing 5 reply threads
    • #68199
      Hi everyone,
      Patrick and I were out this weekend…yes we left the dock finally for a
      nice weekend sail to Blake Island where we met 30 knot gusts and 3 inches of
      downpouring rain over night. While we were tied to the dock in Blake, Deep
      Playa sprung massive leaks (all above the water line) and now we have a
      substantial leak in the starboard companionway that wasn’t there before. I
      know that others have rebedded and properly sealed theirs previously. Did
      anyone also try to seal up the gaps that are left even while the
      companionway is closed? And if so, what did you use?
      PS: we had an awesome down wind sail home and were cruising at 6.5 kts
      flying just the jib. 🙂
      Dawn
      s/v Deep Playa
      On Sat, Dec 11, 2010 at 10:00 AM, <> wrote:
      Send maillist mailing list submissions to
      To subscribe or unsubscribe via the World Wide Web, visit
      or, via email, send a message with subject or body ‘help’ to
      You can reach the person managing the list at
      When replying, please edit your Subject line so it is more specific
      than “Re: Contents of maillist digest…”
      Today’s Topics:
      1. Re: 424 For Sale in Australia (Patrick “Peaboy” Walters)
      2. Larger portlights- [4]- SS- what size and what brands are
      suggested? (joe shimkonis)
      3. Re: Larger portlights- [4]- SS- what size and what brands are
      su (Chuck Ruble)
      4. scans of earlier newsletters (Pete Dubler)
      5. Re: scans of earlier newsletters (Patrick “Peaboy” Walters)
      6. Re: Larger portlights- [4]- SS- what size and what brands are
      su (Joe Shimkonis)
      7. Re: Larger portlights- [4]- SS- what size and what brands are
      su (Patrick “Peaboy” Walters)
      8. Re: Larger portlights- [4]- SS- what size and what brands are
      su (joe shimkonis)
      9. Re: scans of earlier newsletters (Pete Dubler)
      Message: 1
      Date: Fri, 10 Dec 2010 10:03:10 -0800
    • #76388
      Phil Fontaine
      Hi Dawn,
      A couple of years ago I applied some white plastic weather strips to the
      sides of the sliding hatch to close the space between the bottom enge of the
      hatch and the cabin top. This seems to have worked for me in keeping water
      from sloshing up under the hatch and getting in. The strips I bought (at a
      hardware store) are about an inch or inch and a quarter wide by about an
      eighth of an inch thick with an adhesive strip on one side. Very easy to
      apply and they look fine.
      Good luck.
      Phil Fontaine – Aurora.
    • #76392
      Do you have a sunbrella cover fitted over that hatch?
      — On Mon, 12/13/10, Dawn Rodney <> wrote:
    • #76395
      see
      http://www.richardcarter.net/boat/deckRot/
    • #76396
      I had the same deck rot problem as Rich and fixed in the same manner. I
      also added the weather striping described by Phillipe (got the idea from Hal
      Sutphen). At the same time I removed the hatch and re-bedded all of the
      runner supports. No leaks for nearly 8 years. Started to get some leaks in
      2009 and did a quick fix (just re-bedded the teak piece at the aft end of
      the hatch). Started to leak again this fall. So it looks like I have
      another winter project to once again remove the hatch and re-bed everything,
      then replace the 9 year old weather striping.
      Most of leaks in this hatch come from its placement at the side of the coach
      roof. The crown of the coach roof means water collects on the inboard side
      of the hatch and then has plenty of time to find any gaps in the bedding or
      (in a heavy downpour) pour over the inboard runner and collect in the trim
      pieces and headliner. The weather striping prevents the later leak from
      happening.
      On Tue, Dec 14, 2010 at 10:12 AM, <> wrote:
      see
    • #76397
      There should be weep holes on the upper and lower runners. Make sure you
      keep them clear and water won’t sit there.
      I’m not being short. This is from my mobile.
      Hal
      everything,
      coach
      or
      happening.
      see
