Forums › General Discussion › maillist Digest, Vol 45, Issue 9
Viewing 1 reply thread
    • #68770
      I glassed in 5x 1/8″ strips to form vertical “plywood” ribs. Then screwed polyurethaned teak plywood battens with chromed bronze oval head screws. The ribs prevent oilcanning. The teak looks awesome. Spaced with a penny, but I’d use a #10 washer next time. And 3/8″ plywood or solid battens instead of 1/4″.
      How’s it going with those drill holes?
      (212) 233 4995
      (212) 227-2687 (fax)
      Confidentiality Notice: The information contained in this message and any attachments is privileged and confidential information, intended only for the use of the individual or company named above. If the reader of this message is not the intended recipient, you must not review, retransmit, convert to hard copy, use or disseminate this e-mail mesage or any attachments. If you have received this e-mail in error, please immediately notify the sender by return e-mail or telephone.
      On Aug 10, 2013, at 1:00 PM, wrote:
      Send maillist mailing list submissions to
      To subscribe or unsubscribe via the World Wide Web, visit
      or, via email, send a message with subject or body ‘help’ to
      You can reach the person managing the list at
      When replying, please edit your Subject line so it is more specific
      than “Re: Contents of maillist digest…”
      Today’s Topics:
      1. Re: Hull Thickness and ports (Page Two)
      2. Re: Hull Thickness and ports (Silverheels)
      3. Re: Hull Thickness and ports (Page Two)
      4. Re: Hull Thickness and ports (Silverheels)
      5. Re: Hull Thickness and ports (quent)
      6. Re: Hull Thickness and ports (kalinowski)
    • #80016
      That sounds good Adam. If that is my approach, I personally would use solid strips of stock instead of ply to laminate those ribs (much better holding for the ceiling). Then with solid stock ceiling as you mention, I think painted 3/8″ mahogany, properly fastened and spaced for good ventilation, will look and perform just fine. I happen to have tons of leftover mahogany from a job I recently completed using only rough mahogany stock 8/4 to 12/4. Here’s a video of the first two phases, the bar, and then the pool table room. I’ve just recently completed adding another 1500 bf to this basement, dining and paneled exercise room, etc. He wanted yacht quality and the feel of it. The only plywood is the bar cabinet bases.
