Forums › General Discussion › Manual Bilge Pump
Viewing 17 reply threads
    • #68496
      The rubber boot on my cockpit manual pump as given up the ghost. Does
      anyone know where to get a new one or a good replacement for the pump. I
      believe manufacture is out of business.
      Cada Grove
      Jubilee No. 100
    • #78095
      If it is a Whale/Henderson MK5, the kit is a Whale DP9905.
      Defender has it:
      http://www.defender.com/product.jsp?path=-1|51|299222|121271|316443&id=674029
      with a good picture. You might also want to rebuild the pump while you
      are at it. AK8050 is the kit for that.
      I paid about $20 and $32 respectively (but I have a boat builder
      accounts with some of the suppliers).
      Hope that helps.
      Cada Grove
      Jubilee No. 100
    • #78096
      Pump is either a whale or edson. Rebuild kits are available still. When I
      get a chance I’ll see if I can find it.
      Cada Grove
      Jubilee No. 100
    • #78097
      Henderson is a variant of Whale. What’s it say on it?
      Cada Grove
      Jubilee No. 100
    • #78101
      Cada
      I think I have one. Yours for the cost of shipping. Contact me if you want it.
    • #78105
      Rich, Let me know cost and I will send money…thanks for help. I do
      believe it is a Henderson – I am guessing Whaler now owns.
      Cada
      On Tue, Jan 10, 2012 at 8:52 AM, wrote:
      Cada
      want it.
    • #78114
      Cada
      I have the pump and would be happy to send it to you. It’s a Henderson.
      The rubber boot is broken. I think the rest of the pump is fine. I don’t
      have the handle though.
      Let me know if you want it.
    • #78115
      Adam
      Speaking of manual bilge pumps. Those of you who have installed manual pumps inside the cabin, which pump and what location have you chosen?
      Adam
    • #78116
      Hi Adam,
      I purchased a whale mk5 universal.
      Orignal plan was to mount it on starboard side under setee in the space aft of the starboard water tank. Pluming to the bilge from under the floor of setee and connected to the shower sump thru hull in the hanging locker. This plan would have allowed operation frm seated in the starboard setee.
      However a few things blew the plan – ports on the pump did not aligh in the right directoins for optimal pluming run, bulk head mount would have been a better option.
      What i wound up doing is mounting the pump to a board and attaching lengths of hose that woud feed to the bilge and out the hatch so it could be operated from any of several locations.
      Eric Lorentzon
      EFI Sales Development Manager
      412.352.1941
      Sent from my iPad
      Adam
    • #78117
      Aloha Eric: did you keep the one in the cockpit along with the new portable one? More back up/capacity is always better.
      Ko Olina, O’ahu
    • #78118
      Yes. Still have the cockpit manual. Was adding the interior manual pump to meet ISAF offshore regs.
      Eric Lorentzon
      412.352.1941
      Ko Olina, O’ahu
    • #78119
      When I left for my first big adventure, I set Pelican up to be SOLAS
      compatible. The fully operable bilge pump is a Whale Gusher installed in
      the bottom of the hanging locker below the midships companionway. I figure
      that if I’m below locked in, I’m going to be on the cabin sole pumping like
      a madman reconsidering my atheism.
      Eric Lorentzon
      412.352.1941
      Ko Olina, O’ahu
    • #78120
      I don’t have a manual bilge pump installed belowdecks (yet), but I agree
      it’s a good idea. I do have one mounted on a portable board, which I
      could bring into the cabin if needed and discharge it into the galley
      sink. Also have 2 manual pumps in the cockpit, one for the bilge and one
      for the holding tank pumpout. The holding tank pump could be quickly
      switched to a bilge intake hose via a Y-valve, giving me 2 manual bilge
      pumps in the cockpit. Not much help when I’m single-handing since
      they’re in opposite corners of the cockpit, but could be useful with
      crew. I also have 3 strong buckets and a powerful desire to stay afloat.
    • #78121
      Hi Tor,
      The portable pump on a board that can be operated entirely within the cabin
      is more than sufficient. In my case, through what could only be termed
      incredibly complicated piping, my internal pump can draw on the bilge
      (default) or the holding tank. It is in parallel with a macerator that is
      can draw on the bilge or holding tank as well. When single handing, I can
      usually take some time away from the helm in autopilot to pump stuff. When
      the helm is locked with me below cringing, not so much of a problem.
      On of the projects I MUST get to is to run my normal bilge pumps out the
      transom. They currently go through one through-hull with a standard gate
      valve (yuck) on the side of the hull. It’s a real kludge, and is, in any
      case, wrong and unsafe on a port tack when the discharge could be under
      water. Other than that, it’s fine…
    • #78122
      Hey Bob,
      My manual bilge pump discharges through the transom. It’s a long hose
      run, but I suppose it’s the way to go. My electric bilge pump originally
      discharged through an underwater seacock in the forward end of the
      starboard cockpit locker, the same outlet the starboard cockpit drain
      used. I re-routed the electric bilge pump to a multi-purpose thru-hull
      just above the waterline under the head sink. However, that bilge
      discharge hose first runs all the way up to the underside of the
      starboard cap rail outboard of the head sink, makes a vertical U-turn,
      and then quickly joins the scupper drain pipe up there for the straight
      vertical drop to the thru-hull. (Does that make any sense?)
      As part of my early campaign to reduce thru-hulls in the boat, that same
      thru-hull handles the midship scupper, electric bilge pump discharge,
      watermaker brine discharge, shower pan sump and head sink.
      The way my electric bilge pump discharge hose runs now, I’d have to bury
      the starboard rail to put its top U-turn below the waterline. Hasn’t
      happened yet in 5 years. Still, I intend to add a check valve near the
      base of that bilge hose next time I’m shopping back in the States,
      mainly to keep the hose-full of water from running back into the bilge
      when the pump shuts off.
    • #78123
      See, that’s why you make the big bucks. What a grand idea! I can do the
      same with my electric bilge pumps by ‘T’-ing into the deck drains. I was
      going to take them out of the underwater discharge and make them discharge
      about 4″ below the deck. That would remove 4 through-hulls which would
      make me happier. I could make the low-down pump discharge to starboard,
      the upper one to port, and move the stupid head overboard to one of the
      easier to access ones. Right now, the head discharge is so hard to get to
      I’ve been thinking of making an access through the head floor to get to
      it. What was Pearson thinking, I wonder?
      On another subject entirely, when I get finished with the current
      oversight/delivery job I’ll be buying a new Sailrite sewing machine. I’ve
      already got canvas jobs! Woohoo!
      The only caveat I have with the check valve thing is that it’s never
      recommended. In fact, most ‘experts’ think it provides a potential of
      jamming up rendering the pump useless. Having said that, I’ve never seen
      one jam closed – only open which would be no worse than the current set
      up. A vented loop would do to stop backflow. The only water coming back
      into the bilge would be the hose volume. I have check valves on my pumps
      because they both go out the same through-hull so to prevent one pumping
      backwards through the other I need them.
      I’ve seen people remove the sink forward and put storage in its place.
      I’ve thought of this since I never use the sink (and when I mistakenly hit
      the water faucet valves get the v-berth soaked before I figure out the
      problem) and I can ALWAYS use more storage, it’s a good idea.
      My water maker brine and dirty water discharges go to the galley sink.
      Speaking of that, I’ve been unhappy with my water tanks venting into the
      bilge (happier, of course, than them venting into my clothes and
      underwear), and would like to vent them into the sinks. Easy enough for
      the forward and port tank. Oh, wait, I can vent the starboard one into the
      head sink! Venting to the bilge does keep it clean and fresh smelling, but
      keeping it dry would do the same, probably.
      Well, having wandered around the point so successfully, it’s time to get
      myself together and make another cup of coffee.
      Fair and warm winds, rising tides my friend!
      On Sun, Jan 15, 2012 at 9:32 AM, Silverheels wrote:
      Hey Bob,
    • #78124
      Since my electric bilge discharge hose T’s into the scupper’s vertical
      PVC pipe about 8″ below the deck, a vent in the hose loop would be
      pointless. It can’t form a vacuum unless the scupper entry is
      underwater, and even then the scupper drain water will run down towards
      the thru-hull, not up through the bilge hose loop. At least, that’s my
      theory. No, the point of the check valve is just to prevent the hose
      volume water from returning to the bilge when the pump shuts off.
      Ooo, slick. Wish I had one… and the knowledge to use it.
      Been there, done that:
    • #78125
      You’re right – I was blindly doing the standard loop thing. But the real
      world requires real solutions, not textbook ones.
      Fortunately, the sewing machine foot doesn’t go high enough to get my
      fingers underneath while running…
