Forums › General Discussion › Mast Climbing Steps (how far apart?)
Viewing 7 reply threads
    • #68955
      I’m getting ready to install mast climbing steps and am looking for advice from those who have them as to what is a comfortable distance apart. I watched a guy climbing steps once from my dingy, although I don’t know how far apart his were but he seemed to be having to stretch an awful lot to climb. My gut tells me 18″. I base that on the height of our cockpit lockers which are about 16″ from the sole. Some manufacturers say 12″ but shit….they just want to sell product. My second choice says 16″ which is only one more step from the spreaders down using 18″ and one more above.
      I got the Seadog folding steps, (50) 3/4″ 1/4-20 FH and (50) 1/2″ 1/4-20 stainless screws and a tub of Lanacote. The different length screws because on each step the two upper screws need to be at least 3/4″ and the two lower only need 1/2″
      This will be a long, tedious and hot job sitting in a bosens chair drilling and tapping with Florida’s summer sun beating me mercilessly about the body while I’ll be demanding my trusting crew to be at my beck and call to lower and raise. She’s not to excited, but “I” kind of am.
    • #81276
      Ken,
      16″ on Silverheels’ (32″ on one side). That’s a
      comfortable stretch for me, and at 5’7″ I am a
      veritable giant among men. The spreaders count as a
      step, as can mainmast halyard winches and mast pulpits
      if you have them. You want an opposite pair at the top
      to stand on while servicing the masthead, and of course
      they need to be at a comfortable distance below the
      masthead for that.
      My steps, the stirrup style, were already mounted with
      aluminum rivets when I bought this boat. I believe if I
      were going to install them myself, especially from a
      bosun’s chair but even with the mast down, I’d skip the
      tapping and Lanacote and go with rivets. It’s not like
      you’re ever going to take them down again. Then all you
      need is a starter punch, some sharp drill bits and the
      gun, probably a day’s job once you get going. A lot
      less fuss, the same result, IMHO. Just remember to
      measure twice, maybe starting at the spreaders both up
      and down because you can fudge the bottom according to
      whatever hardware is already there, and as mentioned
      the top ends with a pair in any case.
      Have fun!
    • #81277
      Thanks Tor,
      I’m at 5-8, last time I checked (15 years, 20 years?) and shrinking fast so I’ll go with that…16″. I can’t do rivets with these because they are countersunk ready for flat head and I’d never trust a rivet completely setting in a tapered countersunk hole. If there was a flat surface, I would consider it, because 4 rivets should be well enough holding power for many a year.
      Could you do me a favor and count your steps, total including the double on top. I’m considering adding a double at the spreaders for light maintenance. My mast be a tad taller than yours, as I recently found out at a railroad bridge.
    • #81278
      Ken,
      25 stirrup steps plus a fold-away step lowest down; 12
      (including the folding step) below the spreaders, 13
      (including the top pair) above. If I didn’t have
      winches or mast pulpits as footholds to get started I’d
      probably want one more step at the beginning, but I
      have so I don’t. I also don’t have a double-set below
      the spreaders as you’re contemplating. I doubt they’d
      see much service “for light maintenance,” but might be
      a welcome comfort for anyone up there reading tricky
      waters – reefs, coral heads and shoals – underway.
    • #81281
      Ken,
      I believe that should be 25 stirrup steps plus a
      fold-away step lowest down; 12 (including the folding
      step) below the spreaders, 14 (including the top pair)
      above.
    • #81282
      Thanks Tor…it appears I have bought the right amount, 25!
    • #81283
      That would be ideal, Ken. But my mast, which you say is
      shorter than yours, employs 26 including the one
      fold-away at the bottom. And if you add the 2nd,
      opposite step that you have in mind just below the
      spreaders, which Silverheels doesn’t have, you might
      need as many as 27 or even 28 (for the greater mast
      length). I guess you’ll know once you get aloft with a
      measuring tape. In any case, I’m sure it will work out
      to your satisfaction, and you’ll be glad to have those
      steps from time to time.
    • #81284
      I found 18″ to work just fine on Easy Reach. And I strongly recommend them. One thing to watch for is fouling lines around the steps when you need them to be free. At the same time, I found that weaving lines between the steps in port or at anchor prevented mast slapping.
      Norris Larson
      On Sat, 7/12/14, Page Two via maillist wrote:
      Subject: Mast Climbing Steps (how far apart?)
      To: ,
      Date: Saturday, July 12, 2014, 2:18 PM
      more above.
      1/2″
      Ken and Vicky # 91……Writing a New Chapter Page by Page
      in an Old Book.
