Forums › General Discussion › Mast pulpits
Viewing 21 reply threads
    • #67560
      This from Railmakers:
      Mr. Kinderman, I have two pairs left. One pair with the lower foot rail $525.00 pair, and one pair with out $425.00 pair. The foot rail could be added if wanted. Pricing does not include shipping and handling. I’ll need several days to polish and package rails. I can also make another pair if needed there are two more emails regarding the same mast pulpits. Thank you, Dave.
      First come, first served.
    • #72963
      Do these have the “lower foot rail” or is there a design with more bars than in this photo?
      https://www.pearson424.org/gallery/Pelican-Mast-Rails/IMG_0403
    • #72965
      Pat,
      Yes, the mast pulpit in that photo has the optional, lower step rail. That’s all there is.
      I almost didn’t order mine with that option, but I did and it turns out I use it a lot more than I ever expected.
    • #72966
      Can someone tell me how tall (approx.) the pulpits are, and are they mounted entirely aft of the forward side of the mast? I have a jib sheet track just forward of the mast I must clear.
    • #72967
      For those of you with pulpits: How did you mount them? Did you install a backing plate? Any “unique” problems locating them on a ketch? I plan to purchase a set (my last cartoon style move to the forward deck off of Koko Head cinched my decision).
      Lady Leanne II (#135)
      Honolulu
    • #72969
      Hi Dan,
      They come with backing plates.  The only caveat is that you'll have to chop up some of the plywood cleats under the coach roof to do the job properly.
      Honolulu
      Hull #8
    • #72973
      Quent,
      Attached is my final-final drawing for these pulpits, from which Railmakers made them all, though I seem to recall they made the top railing curve a bit shallower due to the limits of their tooling.
      I mounted mine asymmetrically to accommodate my right-handedness – the center of the port rail just about exactly even with the athwartships centerline of the mast; the starboard rail offset aft about 6″ from that centerline. The way to find your best fit is to prop up the rails with lines or whatever BEFORE doing any mount drilling. Then stand in them and go through the motions of the various things you do up there – cranking the halyard winch(es), fussing with the reef cringles & lines, and so on. I did this over a period of several days, adjusting the rails’ position in relation to the athwartships centerline, and also the distance outboard from the side of the mast, until I had them exactly where they seemed most efficient and comfortable for me. As for your jib sheet track, if you send a photo or two showing its position in relation to the mast I could give you an opinion (just an opinion!) of whether I think it’ll be a problem.
    • #72974
      Dan,
      As Bob said, the mast pulpits come with a set of pre-drilled, circular stainless steel backing plates. There are no mounting issues intrinsic to the ketch rig. The minor PIA part of the installation is taking down the headliner panels in the salon to gain access to the underside of the coachhouse, and (also as Bob said) you may have to cut away parts of the cleats under there, the strips of plywood glued to the underside of the coachhouse to which the salon overhead panels and their teak trim attach. It’s not a real big deal, though.
    • #72976
      Hi Tor-
      Thanks for the offer. I’ll get a pic next time I’m at the boat. Actually, I’m going to go ahead and order them. You did a really fine job with the design. They really look good in the pictures.
      We have a Hood furling main which cranks from the front of the mast, but the sefety problem is winching in the outhaul a few feet aft of the gooseneck location. One hand for the winch, one to tail the outhaul, and none to hold on. It will be nice to be able to wedge my butt in the pulpit.
      Regarding the air conditioning, you’re preaching to the choir. We had enough A/C in out last boat to frost the cabin and a genset to run it anywhere. Used it about eight hours over five years.
    • #72977
      patn
      Open message to those who have not yet installed these and who are on
      the fence
      First of all, (for better or worse) I am the helmsman on our boat. On
      more than one occassion over the past ~10 yrs of owning our boat, it has
      terrified me to have David on deck while I tried to hold the boat
      “steady” as he was trying to reduce sail (too late – of course). We
      have never had an accident in these situations but I have always felt
      it was only a matter of time. The pulpits have taking a huge load off.
      Dave finds them comfortable to work in. They are solid. They are tall
      enough for him (6′ 7″) and not uncomfortable for me (5 ‘6″). I love the
      middle rung.
      Installing them took a wkend. We drilled out appropriate sized holes,
      filled the holes with solid epoxy and then installed the pulpits the
      next day.
      I originally hesitated because it was yet another $500+. I now think
      they were a bargain.
      – pat
    • #72978
      Pat-
      I really identify with what you said. Of course, it goes without saying that a pulpit is no substitute for a harness and teather. Years ago, I caught a jibing boom with my head, and almost went over the lifelines. A double reefed main wrapped on the boom and dumb luck saved my life.
      We weren’t off shore either. We were in the sheltered waters of the Chester River, east of Baltimore so I wasn’t wearing a lifejacket, or a teather. No way Claire would have made it back in time. Live and learn, I say. Perhaps more accurately, If you live, you learn.
    • #72979
      james bartch
      Aloha to All
      We have mast pulpits installed on island muse and love them. Tors details are spot on. if were to make a reccommendation it would be to add eye lets at the base connections. its a great location to pin your haylards so they stop clanking on the mast. Dan you are welcome to stop by and have a look I am at Da Store! (fuel dock). Ours has backing plates under the coach roof and the bolts go clear thru the roof liner, not sure i like that but (no leaks yet). The liner does not appear to be indented form the backing plates so i am assuming that we have a spacer backing for the gap between the deck and liner.
      the thru bolting appears to be solid as a rock, but as i said i am a little unsure of the potential for leaks???
      that’s my 2 cents, i can send out pics if someone is interested.
      jb
    • #72980
      I just ordered some for Deep Playa as well. He said he’d have to make them up since some of you bought the last two he had laying around. He gave the same price as for the others.
      ________________________________________
    • #72982
      To all with installed mast pulpits:
      What size bolts/nuts did you use to correctly mount the pulpits? With a potential Matson shipping strike, Home Depot’s stock might be running thin. I don’t want to spend an afternoon wandering around O’ahu trying to find a simple fastener so I hope to buy them before I go on island.
      Honolulu
    • #72987
      I spoke to the guy at Railmakers today (seems like he made about $1500 today off us this week) and he said they holes were drilled to 1/4″. This is also confirmed on the spec in the drawing Tor sent out earlier as well.
    • #73003
      All this talk is pulling me into another project. Is railmakers.com the correct web site?
    • #73007
      yep
    • #73008
      I am purchasing a set of mast pulpits and the guy at Railmakers said he would throw in the fasteners, but needed to know what length bolts to include. For those of you who have installed the pulpits, what length fastener would you recommend. I would obviously like to keep the fittings behind the coach house ceiling panels if possible.
      Lady Leanne (#135)
      Honolulu
    • #73013
      Get longer. Put in with backing plate the ceiling, then fender washer,
      lockwasher, nut and acorn or nylock nut for a finished look. after nuts
      are in place, trim just long enough to leave thread for acorn nut. I
      used dremel tool with parting disk. You guys did read my article on
      this right?
      Lady Leanne (#135)
      Honolulu
    • #73018
      For those of you who don't want acorn nuts showing, use barrel nuts – 1/4-20 available at West Marine for an ungodly amount of $5.00 each.  It means you drill the hole to fit them, not the bolts (I think 5/16th inch) and the bolts only have to be 1″ long or so – measure first.  When putting them in the cleats, either remove the cleat or make the bolts 1-1/2″ long.
      If you remove the cleat, and if you don't want to deal with barrel nuts, then get 1-1/2″ long bolts and use a fender washer and nylon insert locknut.  This is the easiest and least expensive way.  Because of the cleats you have 1/2″ behind the overhead to hide nuts and bolts.
      On Sat, Jun 27, 2009 at 5:01 PM, Pete Dubler < ([email][/email])> wrote:
      Get longer.  Put in with backing plate the ceiling, then fender washer, lockwasher, nut and acorn or nylock nut for a finished look.  after nuts are in place, trim just long enough to leave thread for acorn nut.  I used dremel tool with parting disk.  You guys did read my article on this right?
      Lady Leanne (#135)
      Honolulu
      Hull #8
    • #73019
      Seems to me that the problem here is that the pulpits are pretty high, 36″, and need to stand the weight of crew against the top. That is a lot of leverage on the fasteners in compression/tension cycles. Combined with the fact that the coach roof is a really bad place for deck leaks, the priority becomes attaching the pulpits so that nothing loosens up.
      So, IMHO, you should take out plugs with a hole saw through the outside skin and plyood core, one for each fastener, fill the cavity with epoxy and high density filler. I’d use backing plates that conform to the inside conture of the coach roof and are both large and inflexible. Otherwise, the plywood core will compress, and water will get into the core.
      I’d use fender washers and nylock nuts inside, above the headliner. If you use acorn nuts or barrel nuts, you can’t tighten the fasteners without shortening the bolts.
      A couple other tricks; drill the fastener holes a tiny bit undersized when the epoxy is still green, but has set up. The fastener (or a tap) will cut threads in the epoxy for a tighter fit. Also, when you bed the pulpit base, leave the fasteners slack until the caulk sets. This way it doesn’t all just squeeze out, and you have some gasket effect.
      Quent.
    • #73025
      If you use a much longer bolt and cut it off, you get the benefit of being able to do the whole job with one person working from below…. you can hold the blot from turning by grabbing the longer bolt with a pair of vice-grip pliers while you tighten the nut. Also, a nylock nut locks an awful lot like an acorn nut, but is easy to find and often cheaper.
      See this page for acorn nuts of different sorts. about 73 cents each in 18-8 from McMaster: http://www.mcmaster.com/#stainless-steel-acorn-nuts/=2ihyzc
      Robert Fine wrote:
      For those of you who don’t want acorn nuts showing, use barrel nuts – 1/4-20 available at West Marine for an ungodly amount of $5.00 each. It means you drill the hole to fit them, not the bolts (I think 5/16th inch) and the bolts only have to be 1″ long or so – measure first. When putting them in the cleats, either remove the cleat or make the bolts 1-1/2″ long.
      If you remove the cleat, and if you don’t want to deal with barrel nuts, then get 1-1/2″ long bolts and use a fender washer and nylon insert locknut. This is the easiest and least expensive way. Because of the cleats you have 1/2″ behind the overhead to hide nuts and bolts.
      Lady Leanne (#135)
      Honolulu
      Hull #8
