Forums › General Discussion › MAX PROP
Viewing 9 reply threads
    • #67566
      calicojack
      Hi Guys:
      I’ve found a used max prop for sale by an individual. It came off a 38 Packet. Anybody know what shaft size/pitch is needed for our 424s? Anybody using a Max? Was it a big improvement, especially in the “backing up “catagory? Thanks
      Calico Jack
    • #73001
      One and one half inches in diameter. Left hand rotation. I have no experience with Max-prop. We have a fixed prop 18″ diameter, 12″ pitch, three blade that seems to work well with the W-58.
    • #73004
      Syringa
      You lucky dog! 1 1/2″ shaft 18″D LH Pitched to 13″ should work very well.
    • #73005
      I have a 20″ Maxprop, which did improve reverse and used to feather under sail.  Now with the Velvet Drive it takes a long time before the prop shaft stops rotating under sail.  PYI can give you the recommended pitch setting for your engine and displacement.  Then it may need to be adjusted after a sea trial.  There is one version of the MaxProp that can be adjusted in the water, otherwise it is a short haul.
    • #73006
      When setting the pitch, be sure to consider if you will be mostly in
      salt water or in brackish water. PYI will advise you.
      haul.
      http://www.svsarah.com <http://www.svsarah.com>
    • #73040
      Double check the direction of rotation before you buy anything. Most props are righ handed. The 424 is left handed because it has no gear reduction in the transmission.
    • #73066
      FYI for all who are looking for a new fixed prop. I’ve found a place that manufactures them: West by North Enterprises (604.506.2032). They produce the Campbell Sailor propeller, a 3 blade LH, 17″ diameter, 10″ pitch for a 1.5″ shaft. They state that this size is recommended to have good cruising rpm and still have reserve for head wind and seas. Price $680 + shipping. They state that it has been successfully used on other 424’s with a 58 Westie.
      I will be replacing a LH 18″ dia, 12″ pitch for a 1.5″ shaft which the PO let dissolve.
      Lady Leanne II (#135)
      Honolulu
    • #73079
      A 17-10 will run at higher rpms for the same speed than an 18-12.  Moreover, the fuel usage curve for the w58 shows using nearly double the fuel at 2200 rpm as it does at 1900 rpm.  I do not subscribe to the school that a diesel has to be run at 80% of max rpm to last.  A diesel has to run loaded but is perfectly capable of running at a lower speed for extended periods of time.  Look at 1800 rpm gensets. Whenever you have spinning and reciprocating machinery combined the faster the spin the more energy is wasted in inertia of pistons.  I run my w58 perfectly happily at 1800-2000 rpm and burn 1 gal or less per hour.  At 2200, it's 2 gal or more.
      But that's just my humble opinion.
      On Mon, Jun 29, 2009 at 4:07 PM, kalinowski < ([email][/email])> wrote:
      FYI for all who are looking for a new fixed prop. I've found a place that manufactures them: West by North Enterprises (604.506.2032). They produce the Campbell Sailor propeller, a 3 blade LH, 17″ diameter, 10″ pitch for a 1.5″ shaft. They state that this size is recommended to have good cruising rpm and still have reserve for head wind and seas. Price $680 + shipping. They state that it has been successfully used on other 424's with a 58 Westie.
      Honolulu
      Hull #8
    • #73081
      joe shimkonis
      ayone know walter v drive ratio-I’m about to buy a Campell prop from West -thanks- 2 to 1 ???
      Joe Shimkonis
    • #73082
      If you have a Westerbeke 58, you most likely have a direct drive Warner Velvet drive transmission and a Walter 2:1 reduction RV-20 V-drive.
      A friend of ours has a Campbell prop on his Pearson 36-2, and is very happy with it.
      However for a P-424, I can’t see how a prop smaller that the original Michigan Wheel 18 by 12 in size and also smaller in blade area would be optimal.
      We went to Bahamas and back at about 1800 rpm, 6.5-7 knots, and the Westerbeke was very happy all the way. Our buddy boat, a Caliber 40 with a Yanmar, ran about 2600 rpm to pace us. Their fuel consumption was about the same as ours, about 0.8 gallon per hour.
      At full throttle, the boat does about one knot faster, and consumes a lot more fuel. A considerable amount of that fuel ends up as soot on the
      transom.
