Forums › General Discussion › Maximum Halyard Size in Original Sheaves
Viewing 12 reply threads
    • #66921
      Has anyone tried using 1/2″ Sta-Set X in the original wire/rope sheaves. I
      may be able to get some 1/2″ for less than 7/16″ It looks like it should
      fit, but I thought I would check.
      Paul #28
    • #69498
      I believe I have 1/2 inch…. it works, the sta-set-x
      sucks….The coiled up sections that don’t get used
      much (furled genny) get hard as a rock…..
      Just my observation.
      a
      Paul #28
    • #69499
      Paul,
      When I purchased Sarah one of the first things I did was replace the wire/rope halyards with all rope with the origina sheaves. I went with 9/16″ Sta Set X thinking it would fit the sheaves. It did, but the eye splice was too large to go onto the sheave and I couldn't get a full hoist on the main. I lived with it (used a Cunnigham to tension the luff) until I swapped out the sheaves and went to 1/2″ and 7/16″.
      So I can say that 1/2″ would fit easily on the original sheaves, but the eye splice may not. A lot depends how clean and tapered a splice you put on the halyard and how full the hoist is for your main. If main hoists below the black band you shouldn't have any trouble, however since I never tried 1/2″ on the old sheaves I can say for sure.
      FWIW, I prefer the 7/16″ Sta Set X to the 1/2″. Sta Set X is very stiff rope. Even after 5 years my 1/2' halyards are fairly stiff. 7/16″ is more flexible and fits the halyard cleats better.
      On Mon, Apr 14, 2008 at 11:10 AM, Paul Lefebvre < ([email][/email])> wrote:
      Has anyone tried using 1/2″ Sta-Set X in the original wire/rope sheaves. I may be able to get some 1/2″ for less than 7/16″ It looks like it should fit, but I thought I would check.
      Paul #28
    • #69505
      John / Alan:
      Thanks for the info. Concerning the stiff ropes, are there any other
      alternatives. I assume that any halyards suitable for this application (low
      stretch) would have similar properties, but maybe some are better than
      others.
    • #69506
      I re-rigged with 7/16″ Sta-Set X, but if/when I come across a decent wire winch I think I’m going to switch to an all
      wire genoa halyard. Since it’s on a roller furling unit, the jenny gets raised once and then tends to stay up pretty
      much all the time. So, rather than have that big coil of unused Sta-Set X hanging around at the base of the mast year
      after year, I’d have a neat, self-contained winch-full of (non-stretch) wire. Seems more practical to me. Any thoughts
      out there as to why this would not be a good idea?
    • #69509
      Hi Tor,
      The only caveat I can offer is this: There is a reason (actually many) why wire winches aren't used anymore – things like broken wrists, radius or ulna, pinched fingers and the odd pinched fingers. Wire winches are not all that safe.
      Other than that, you're good.
      But as you know, it's only my humble opinion.
      On Mon, Apr 14, 2008 at 12:56 PM, Silver Heels < ([email][/email])> wrote:
      I re-rigged with 7/16″ Sta-Set X, but if/when I come across a decent wire winch I think I'm going to switch to an all
      wire genoa halyard. Since it's on a roller furling unit, the jenny gets raised once and then tends to stay up pretty
      after year, I'd have a neat, self-contained winch-full of (non-stretch) wire. Seems more practical to me. Any thoughts
    • #69510
      Bob,
      Humble opinions are welcomed. Really, those are good, valid points.
      I had a steel Finisterre yawl many years ago with wire halyards & winches, which were an inconvenience and, yes, a potential wrist-breaker that I nevertheless managed to survive. I would not use them by choice today on any regular basis, but I think I can handle operating one once every few years. That’s about as often as I tend to take down my roller furling genoa when I’m cruising. Anyway, changing over is not a priority project at the moment. Just something on a might-do eventually list.
      Thanks for your input.
    • #69511
      Hi John,
      Well, and everyone else, too. Why do you want such large halyards? The hoist on the main is actually shorter than my Ericson 34 which was perfectly happy with 3/8″ line. I'd say, use the smallest possible rather than the largest, but perhaps there's something I don't understand yet about the 424.
      That said, I almost never use an eye splice for the halyard – it wastes too much hoist. Believe it or not, there is a special knot whose sole purpose is to attach a shackle to a halyard. It's called the buntline hitch (http://www.the-sailors-place.com/special_knots.htm)
      It allows a full hoist, is easy to make, difficult to break, and easy to shorten the halyard when there's a reason due to chafe. It can be done in a seaway (and if you've ever had to do that on a halyard when tossing about, this is important), and it's not a bowline.
      You may say, “But Bob, the knot is weaker than the splice!” Why, yes. Yes it is. Let's look at this: The working load for 7/16″ (11mm) Stayset X is 7,400 lbs (Stayset X is recommended by New England Ropes for our size boat). A 50% reduction in strength allowed for the knot and safe working loads works out to 3,700 lbs, or the hoisting of a Subaru Impreza Sportwagon with 4 passengers up your mast.
      The truth of the matter is that the science and technology of cordage is so advanced now that you could very easily have no more than 3/8″ line safely.
      The only reason I can see for larger line is the hand of the line.
      Again, only my two cents.
      On Mon, Apr 14, 2008 at 11:26 AM, John Stevenson < ([email][/email])> wrote:
      Paul,
      Paul #28
    • #69512
      Hi Tor,
      I'm smiling, actually laughing here – I am obviously raising and lowering my headsail way too frequently!
      On Mon, Apr 14, 2008 at 1:52 PM, Silver Heels < ([email][/email])> wrote:
      Bob,
      I had a steel Finisterre yawl many years ago with wire halyards & winches, which were an inconvenience and, yes, a potential wrist-breaker that I nevertheless managed to survive. I would not use them by choice today on any regular basis, but I think I can handle operating one once every few years. That's about as often as I tend to take down my roller furling genoa when I'm cruising. Anyway, changing over is not a priority project at the moment. Just something on a might-do eventually list.
    • #69514
      Speaking of line, what length are you planning on
      buying. I need to purchase a line for my Solent Stay
      Halyard / Pole Topping lift. Probably close to the
      same length…. I wanted to order it before I go back
      out to the boat next weekend.
      — Robert Fine <> wrote:
      Hi John,
      large halyards? The
      happy with 3/8″ line. I’d say, use the smallest
      largest, but perhaps there’s something I don’t
      is to attach a shackle to a halyard. It’s called the
      buntline hitch (
      shorten the halyard when there’s a reason due to
      seaway (and if you’ve ever had to do that on a
      this is important), and it’s not a bowline.
      it is. Let’s look at this: The working load for
      Ropes for our size
      hand of the line.
      wrote:
      Paul,
      did was replace the
      It did, but the eye
      couldn’t get a full hoist
      7/16″.
      the black band you shouldn’t have any trouble,
      rope. Even after 5 years my 1/2′ halyards are
      Paul #28
    • #70397
      I was doing a search for halyard relacemnts in the forum and found this thread.I did a rough measure of my jib halyard by raising a tape up the furler (42′ to the deck) and then measuring the tail of the existing wirerope halyard to be 52′ from the splice to the bitter end. that comes out to be 94′ or close enough to 100′ to just call it 100′ for me.
      Just wanted to check if that sounded about right to all of you.
      -patrick
    • #70398
      That's what I used, Patrick. I used 100' Stayset X with the paralay core size: 7/16 inch. I didn't splice the halyard shackle in – I used a halyard knot (like an inside out clove hitch). Works like a charm.
      On Sun, Aug 3, 2008 at 6:56 PM, Patrick_Seattle < ([email][/email])> wrote:
      I was doing a search for halyard relacemnts in the forum and found this thread.I did a rough measure of my jib halyard by raising a tape up the furler (42' to the deck) and then measuring the tail of the existing wirerope halyard to be 52' from the splice to the bitter end. that comes out to be 94' or close enough to 100' to just call it 100' for me.
      -patrick
      Deep Playa, #152 http://www.DeepPlaya.com
      Patrick's Sailing Blog: http://shipsrecord.com/blogs/patrick
    • #70422
      Thanks for the reply, it’s good to know I wasn’t way off!
      As an FYI for all you lurkers who need the same thing, 7/16 stayset-X is on sale for $.97 a foot at west marine right now.
      s/v Deep Playa – Pearson 424 #152 | http://www.DeepPlaya.com
