Forums › General Discussion › midship cleat
Viewing 13 reply threads
    • #68357
      allantereshko
      Just curious to find out what the options are for a midship cleat to hold a springline. Has anyone installed a cleat on the bulkwark or is a track cleat the best way to go. My docking situation requires a waist cleat and I wonder about relying on a cleat of the sail track. Did a search before I asked and nothing came up.
    • #77320
      I use the Scheafer track cleats about $75 each.
      On Jun 12, 2011 9:31 PM, “allantereshko”
    • #77321
      Schaefer 70-75 is what I use as well.
      http://schaeferhardware.com/detail.aspx?ID=1010
    • #77322
      Don’t let the price scare you. You can get them for much less.
      On Jun 13, 2011 1:18 AM, “Patrick “Peaboy” Walters”
      On Jun 12, 2011 9:31 PM, “allantereshko” <
      hold
      I
    • #77323
      I use 2 of the Schaffer movable cleats on each sail track. One on each end. Gives you a lot of flexibility when moving around and doing  different docking situations on frequent basis.
      The sail track is certainly mounted well enough to handle it……Although in a TS or hurricane situation….. but then you’d have other issues as well…… but for normal docking… go for it.
      — On Sun, 6/12/11, allantereshko wrote:
    • #77324
      allantereshko
      The cheapest I’m finding the 70-75 is Jamestown Dist. for $99. anyone find a better deal. I like the idea of having one on each end,does create more options. Thanks Allan #206 Now “Curve of Time”
    • #77325
      I also use two per track. Try West Marine with Port Supply if you can.
      On Jun 13, 2011 7:52 AM, “allantereshko”
    • #77326
      My boat came with a cleat just forward of the gennoa track on the toe-rail. I don’t know if it came from the factory that way or if the first owner installed it. I put a short piece of stainless half-round on the edge of the toe-rail because the lines wear the woodwork. I put a similar piece of half-round for the bow-cleats. There’s nothing special about the cleat. Its the same type and size as the stern cleats. I don’t recommend using a cleat on the track for a boat the size of the 424.
      I also put small cleats on three of the stanchions on each side to hang fenders. These work well.
    • #77327
      Check Garhauer MCS-2 midship cleats. 50.00 on their website.
      Eric Lorentzon
      EFI Sales Development Manager
      412.352.1941
    • #77329
      I use the Garhauer track cleats. As with everything Garhauer they are nicely done
    • #77330
      Garhauers was also well-priced
      hold
      I
    • #77331
      Ditto. I have Garhauer midship cleats. Good value
      Sent from my droid….
      nicely done
      hold
      I
    • #77337
      I have used track cleats for 28 years and they work fine. Jim-Revery
      — wrote:
    • #77352
      allantereshko
      Thanks to all for the suggestions. Decided to go with 4 Garhauer chocks/cleats. One on each end of the Genoa Track. Allan #206 Curve of Time
