Forums › General Discussion › Miss Kathleen Hard Dodger Update
Viewing 10 reply threads
    • #69022
      Miss Kathleen
      All,
      Finally – the dodger was collected from the paint shop and is in place.
      Next item is to get the windows installed. Plan is for glass rather than plexi-glass.
      https://plus.google.com/u/0/photos/117161376876600674340/albums/6062945667079974257
      Dennis
    • #81821
      It looks great! If I can offer this: get safety glass rather than
      tempered glass.
      On Tue, Nov 18, 2014 at 2:15 PM, Miss Kathleen via maillist <
      > wrote:
      All,
      plexi-glass.
      Dennis
    • #81822
      Miss Kathleen
      Thanks Bob.
      The window man will be sorting templates first. I will confirm on the glass type.
      I was surprized when he said that they bend the glass to fit the shape, depending on whether the profile is within the bendable range. If the bend is excessive then we will have to use plexi-glass. The sides, being flat, will be easily achievable with glass.
      Cheers
      Dennis
    • #81823
      The front windows are curved? That’s expensive…
      On Tue, Nov 18, 2014 at 2:58 PM, Miss Kathleen via maillist <
      > wrote:
      Thanks Bob.
      glass type.
      Cheers
      Dennis
    • #81824
      Dennis,
      That’s a fine looking hard dodger. It complements the boat
      perfectly.
      You know, one of the very first modifications I made to my 424
      when I bought her, before I even had a spray dodger in place, was
      to move the primary winches aft to outboard of the wheel
      binnacle. This opened up the passageway between the cockpit and
      the side decks, which was sorely needed for safe sailing in my
      opinion. It also put the winches within reach of the helmsperson,
      so that a he/she could tack the boat without an experienced crew
      in the cockpit to handle the genoa sheets. (They’re still
      accessible to crew, too.) The change was an immediately obvious
      no-brainer to me. I still wonder what Shaw/Pearson were thinking
      when they placed them where they did.
      Looking at your photos, I was reminded just how bad that original
      winch placement was, only it’s amplified by your beautiful new
      dodger. It’s going to be challenging, if not downright dangerous,
      to step through there in lively conditions.
      Just a thought.
    • #81825
      Miss Kathleen
      Tor,
      Seeing some of the changes on other 424’s, the relocation of the winches is next.
      Currently the support for the bimini is where the winches will go.
      I have just started making a hard-top bimini which will have supports rising from the stern and along the backstays.
      By the way, the original spray dodger really protruded into the passageway. The new dodger is a vast improvement.
      Cheers
      Dennis
    • #81879
      Miss Kathleen
      Hi All,
      Dodger is 99% complete. Windows are in! A hand-hold or and we are done.
      Have since relocated the winches further aft.
      See link below;
      Dennis
    • #81881
      Lookin’ sharp! Well done.
    • #81882
      Start of attached email. Subject: Re: Miss Kathleen Hard Dodger Update
      Will you be adding a bimini top also? If so ,pls take a picture of the final set up with the bimini-it looks great.
    • #81883
      Dennis,
      Does the center front window open?
    • #81884
      Miss Kathleen
      Hi Guys,
      Tor, the front window does not open. being curved it would have been a real challenge. The sides are real glass. The front is plexi-glass.
      Joe, I dumped the normal bimini and constructed two frames that will support a hard-top bimini. This is a WIP and hopefully will be completed soon. Need this before we go off for Christmas as it supports two solar panels. I will post some pics once done.
      Cheers
      Dennis
