Forums › General Discussion › Mizzen back stays
- This topic has 7 replies, 4 voices, and was last updated 16 years, 1 month ago by
Herbc.
September 28, 2010 at 12:04 am #68143
Herbc
ParticipantNew “kid” here
Today is our 1 month anni, and we still can’t get the silly grin off, not even trying of course.
Would the group please comment on the pic of the mizzen stays. Is this the standard and why would I want to adjust, slack or tighten the mizzen mast. These lines are well worn, green is the standard color here in the NW. Should it not be all wire?Thanks,
Herbc[/url]
September 28, 2010 at 12:05 am #76054
Herbc
Participantsorry could not get pic to post, but i did get a bunch of warnings
September 28, 2010 at 12:12 am #76055
john stevensonParticipantherb,
Replacing the running backstay lines is a minor cost (easy for me to say).
Maybe I need to see that pic, but you only want wire from the mizzen mast
head to the backstay blocks. Actually if I were to replace that wire today
it would be with low stretch rope. I did replace the original blocks and
rope in the first year I owned Sarah. Pics at:
http://www.svsarah.com/Sarah/ewUpgradeDeckRig.htm#Running_Rigging_-_Mizzen_MastOn Mon, Sep 27, 2010 at 8:05 PM, Herbc wrote:
September 28, 2010 at 12:30 am #76056
Herbc
Participanthttp://lh6.ggpht.com/_7DS5GQgVv2U/TKE2GjqWawI/AAAAAAAALeg/4FOIc9fjsS0/s512/mizzen%20backstay.jpg
does that work for a pic, sorry,
anyway I have never had an adjustable back stay, understood it to rake the mast for better pointing, but that would surprise me for a cruising ketch.
Must confess my ignorance, am i adjusting the tension on the mizzen to get to the main mast?
September 28, 2010 at 12:59 am #76057
Herbc,
Welcome to the Home of the Elite. Those “adjustable” backstays on the P424’s
mizzen are called “running backstays.” Basically, you leave the leeward stay
loose and keep the windward stay pulled as tight as you can by hand using
the double-purchase blocks provided. The taught “running back” keeps the
mizzen mast from toppling forward in a blow. The slack leeward running
backstay allows the mizzen boom to swing out on the leeward side as far as
it needs to for that tack. As you tack you let the taught running backstay
run free and pull the other one tight so that on the new tack you once again
have the windward running backstay taught and the leeward one loose.Personally I’d have preferred it if Pearson/Shaw had come up with a less
demanding system back there. Most mizzen masts are simply fix-stayed so
they’re self-tending when tacking. Not so with the P424.Reef early,
Silverheels, P-424, #17
September 28, 2010 at 3:31 am #76058
SpectatorHe, something I can answer….
As part of my re-rig I replaced the wire pendants, existing blocks and lines
as follows:26′ standing pendants of 3/16″ Amsteel with eye splices in each with a SS
thimble on both ends.
Bottom end of the pendant has a Garhauer 25-14US Single Block with Becket
The fiddle blockes were replaced with Garhauer 25-05US Fiddle with cam cleat
and snap shackleI dont’ have the lengths for my running part of the stays in my spreadsheet,
but I used 3/8″ XLS Yacht braid with an eye splice in one end to attach it
to the becket on the end of the pendant.I wish I made my pendants a little shorter as the thimbles touch my bimini
structure. I’ll probably shorten them up when I’m bored some day and the
clinking is driving me crazy.-p
s/v Deep Playa | Pearson 424 Hull #152 | http://www.DeepPlaya.comOn Mon, Sep 27, 2010 at 5:59 PM, SilverHeels wrote:
Quote:Herbc,Welcome to the Home of the Elite. Those “adjustable” backstays on the
P424’s
stay
again
September 28, 2010 at 3:33 am #76059
SpectatorPic of the splices with the thimbles.
http://www.flickr.com/photos/deepplaya/4638382720/-p
s/v Deep Playa | Pearson 424 Hull #152 | http://www.DeepPlaya.comOn Mon, Sep 27, 2010 at 8:31 PM, Patrick “Peaboy” Walters <
> wrote:Quote:He, something I can answer….As part of my re-rig I replaced the wire pendants, existing blocks and
lines as follows:26′ standing pendants of 3/16″ Amsteel with eye splices in each with a SS
cleat and snap shackleI dont’ have the lengths for my running part of the stays in my
spreadsheet, but I used 3/8″ XLS Yacht braid with an eye splice in one end
to attach it to the becket on the end of the pendant.I wish I made my pendants a little shorter as the thimbles touch my bimini
P424’s
stay
again
September 28, 2010 at 4:35 am #76060
Herbc
Participantjust got back from mnf and my team did not win, dang!
thanks for the lesson. While on a broad reach, coming down from Port Townsend we had the mizzen and the genny working for us and moving along on a fair day at 5 n 6 knots it was our first day with the engine off and wee were happy happy. I kept thinking the blocks on the mizzen were there for something but after letting out the mizzen and noticing the backstay was in the way I said no worries cause the genny was doing all the work anyway.
good info and I appreciate the info,
