Forums › General Discussion › Mizzen mast t-track
Viewing 2 reply threads
    • #68004
      I need to replace the t-rack on the mizzen mast that my boom rides on. Anyone know who makes the inset that slides up the mast for mounting / supporting the t-track?Mast are out now and splash is this friday!!!running out of time and boat units –
      Eric NavasanaKittery Maine
    • #75330
      You can make them yourself with a bit of bar stock 3/4″ wide and 3/16″ thick
      with a drill and tap. I think the screws are 1/4″ – 20. Like Tor said, it
      should only take a day to do. I carry all the tools so for me it would take
      less. All the backing plate does is clamp the track to the internal track.
      I hope that helps.
    • #75335
      What Bob said… that is exactly my plan as well!
      If you can’t find the metal locally try http://www.onlinemetals.com
      thick
      take
      I hope that helps.
      friday!!!running
