Forums › General Discussion › Mysterious orange light
Viewing 20 reply threads
    • #68099
      Ok too lazy to look this up. Just got to Anacortes, WA for the Lats N Atts party, hooked up to the shore power and we’ve got blinky orange with zero load only the ac main is on. Polarity check is fine.
    • #75800
      Patrick,
      Can’t say what this light indicates, but yours must have gotten a little
      more sun light than mine over the years. The plastic cover should be green,
      at least it is on my panel.
      Mine comes on and blinks as your describe on occasion. This happens most
      often when the genset is running, although not always. The fixture is
      connected across the neutral and hot AC leads at the back of the AC
      Voltmeter, so it may flash when the shore power voltage is not within some
      limit. However I’ve never noticed a meaningful correlation there.
      Marinetics is long gone, although I think there is a small outfit (someone’s
      garage?) in So Ca that does some sort of the electrical fabrication.
      I did not find a description of the Marinetics panel in the my (also long
      gone) owners manual. Just a very generalized schematic that did not include
      the meters.
      My advice: Enjoy the party and forget about the light.
    • #75801
      Looks to me like someone added a lamp for some reason. Maybe inverter on?
    • #75802
      Shortly thereafter the light went off, so we’re still clueless. I’ll look
      how it’s wired in next time I have the panel down. Too lazy enjoying the
      first 80F+ days in Puget sound this year. Lats N Atts party is a good time,
      if you like drunken pirates. 😉
      On Sat, Aug 14, 2010 at 6:01 PM, Rich Carter wrote:
    • #75803
      The light (on my panel) is wired to the shore power and presumably should
      come one whenever the shore power is connected. There is a small stalk at
      the base of the light (behind the panel), but I find it hard to believe that
      in the late 1970s they could have miniaturized sophisticated electrical
      circuits in that space. So I assume it was just a light to indicate that AC
      power (generator/inverter/shore) was available and after 30 years it only
      comes on intermittently.
      On Sat, Aug 14, 2010 at 9:01 PM, Rich Carter wrote:
    • #75818
      One possibility. Do both you and the shore power have GFIs? shore power in Nove Scotia and Cape Breton does. When I plugged in to one of their docks, a shore side circuit breaker blew. Maybe there is some other effect at your dock related to this issue.
      Norris Larson, Easy Reach, #216, on the market.
      — On Fri, 8/13/10, Patrick wrote:
    • #75821
      I added GFI outlets on board, but they were not even in the circuit when the
      light was on; all individual breakers were off.
      My working theory is the light should always be on and that it’s just
      flakey.
    • #75822
      Could it be a sun spot detector?
      flakey.
    • #75826
      It might be a bad attitude detector. I was a bit grumpy at the time. 😉
      the
      flakey.
      On Mon, Aug 16, 2010 at 2:59 PM, norris larson<
      wrote:
      in
      docks, a
    • #75829
      Clearly a non-asymmetrical hyperbolic phase imbalance inducing a wizz
      bang super eight inductive field current.
      the
      flakey.
      wrote:
      in
      docks, a
    • #75831
      That would make the light a super-wham-o-dyne doodah.
      On Mon, Aug 16, 2010 at 11:18 PM, Pete Dubler wrote:
      Clearly a non-asymmetrical hyperbolic phase imbalance inducing a wizz bang
      the
      flakey.
      wrote:
      in
      docks, a
      your
    • #75840
      Syringa
      Patrick
      Did you trace the wires? if so let me know and I will try to help.
    • #75844
      I’ve not dug into it yet, I’ve been thinking about my windlass all day more
      on that to come as I’d welcome your collective advice.
      -=p
      On Tue, Aug 17, 2010 at 9:38 AM, Syringa wrote:
      Patrick
      Don Gardner
      S/V Syringa #124
    • #75846
      What about your windlass are you thinking?
      On Tue, Aug 17, 2010 at 3:35 PM, Patrick “Peaboy” Walters <
      -=p
      Patrick
      Don Gardner
      S/V Syringa #124
    • #76027
      I finally looked into that light on my AC Panel. Here’s a pic of how it’s wired on the back: http://www.flickr.com/photos/deepplaya/5010553633/
      Looks to me like it really should be on all the time as I orignally pondered and some of you concurred.
    • #76028
      Looks like someone added it to show that shore power is on. Since all the boat interior lights are 12v, you might not otherwise realize that the power was off until the batteries got low or the hot water got cold.
    • #76029
      I suspect that the original green light went bad and there was a replacement
      with the orange one. My panel from 1978 or so has a green light that
      flickers as well, and other 424 panels I’ve seen have the same light. The
      light on Patrick’s panel looks to be of a different generation than the
      panel – more modern.
      But without carbon dating, I can’t tell.
      PS, I added pilot lights to all my 12v breakers so I could tell the circuits
      are on. If you’re going to do this, use regular LEDs. I purchased mine
      from http://www.plasmaled.com with the theory that if an LED is good, then a plasma
      LED would be much better. Needless to say, you can see my power panel from
      two miles away at night through the port light over the aft bunk. You can
      read a paper or chart at night with the panel. Sometimes, more power is not
      necessarily better. I think I’ll try adding a resistor to the lights to see
      if I can dim them some.
    • #76030
      My light goes on when the inverter is on and there is insufficient voltage
      to attain 110. That is I often attain only 105. I think of the light as a
      caution. For example, if I am trying to charge a battery and the voltage is less
      than 110, I get a poorly charged battery.
      I’ve yet to see it go on when I’m on good shore power.
      I have to admit that I find it confusing since it comes on sometimes and not
      other times, inconsistantly and not predictably.
      Joe,
    • #76031
      Hi Joe,
      Is it wired the same as Patrick’s? It sounds like it was repurposed to see
      the inverter voltage rather than the shore power voltage.
      less
      not
      Joe,
    • #76032
      I can not tell if my wiring is the same right now..the boat is in Trinidad. But
      I do have another light on the Heart which tells me I have shore power on, so
      perhaps you are right. Though my gut says the light is orange to show the
      current is weak.
    • #76033
      I would believe that if it was wired to the inverter, or if there were some
      circuitry associated that knew there was AC but the voltage was below a
      certain point (not difficult, but should be obvious). Also, the light could
      be connected to the inverter itself or to the batteries to indicate low
      charge.
      Or, it could be PFM. A light that doesn’t do anything but sometimes appears
      to be indicating something. I love stuff like that…
      On Tue, Sep 21, 2010 at 11:05 AM, Joseph Steiner wrote:
      But
      so
      current is weak.
