Forums › General Discussion › New Cummins B3.3 65 HP Engines on Ebay for $2000
  • This topic has 3 replies, 3 voices, and was last updated 17 years ago by Anonymous.
Viewing 3 reply threads
    • #67730
      Paul,
      How is your Cummins engine working out?
      Paul Lefebvre wrote:
      Yes, there is a catch – they are not marinized yet. However, TAD is
      marinizing them, so it can be done. The hardest part about marinizing
      an engine is getting a wet exhaust manifold / exchanger for it. While
      Bowmann in the UK doesn’t make one for this engine, the one they make
      for the Perkins 4-154 (approx $750.) is pretty close and this appears
      to be what TAD uses. They use an adapter plate to convert the mounting
      holes to fit. The other hard part is the raw water pump. They use a
      Jabsco gear driven one off the flywheel.
      These engines first went on ebay in the spring for $2,600. However,
      they made the mistake of saying they had 20+ of them, so I knew I had
      lots of time. The price recently dropped to $2,165 and they accepted
      my $2000 offer. The price includes shipping. They also have the 85 HP
      turbo version available for a bit more.
      Mine arrived yesterday and it was in brand new condition. The
      manufacturing date was May /06. I am sure it is going to be an
      interesting challenge to complete this project. I thought I would
      mention it to the group in case anybody else is looking for a project
      this winter. Multiple people working on this would sure make things
      easier.
      http://cgi.ebay.com/Cummins-B3-3-Diesel-BC30023-65-hp-Brand-New-8NG10019_W0QQitemZ250489097149QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a52504bbd&_trksid=p3286.c0.m14#ht_2517wt_907
      <http://cgi.ebay.com/Cummins-B3-3-Diesel-BC30023-65-hp-Brand-New-8NG10019_W0QQitemZ250489097149QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a52504bbd&_trksid=p3286.c0.m14#ht_2517wt_907>
      http://cgi.ebay.com/Cummins-B3-3-TURBO-DIESEL-FR30203-85hp-FREE-USA-SHIP_W0QQitemZ250485775815QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a521d9dc7&_trksid=p3286.c0.m14#ht_2810wt_907
      <http://cgi.ebay.com/Cummins-B3-3-TURBO-DIESEL-FR30203-85hp-FREE-USA-SHIP_W0QQitemZ250485775815QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a521d9dc7&_trksid=p3286.c0.m14#ht_2810wt_907>
      Boundless #28
    • #73956
      Holy smokes that’s a good price. You’ll have to adapt the bell housing, add
      a heat exchanger, engine mounts, and water pump. Does the engine have
      engine mount brackets? I can’t tell from the photos, but I think not. As I
      recall the water pump goes on the PTO. You’ll need an exhaust riser and
      water injection elbow. I think you have to relocate the fuel filter too.
      This should be straightforward but would be simpler if TAD would sell the
      brackets. They even have an optional bracket set for a Balmar alternator.
      Even if you spend an additional $2k on accessories that’s a steal. Would
      TAD be willing to sell these parts separately, maybe a marinization kit?
      They guy isn’t the most friendly person I’ve ever done business with.
      There’s one thing to be cautions of. Marine diesels use a governor to set
      the throttle. When you move the throttle lever, what you are really doing
      is changing the governor setting. I’m not sure that an industrial engine
      uses the same fuel pump. A call to Cummins would resolve this. Also, is
      there a warranty from Cummins?
      I’m tempted to buy one just to play with, but I just spent $3.5k on a new
      dinghy today. My wife would kill me if a new engine showed up. Maybe I can
      convince her that its for the dinghy.
      If I still had a W60, I’d buy one and stash it away for the future. I think
      they are all gone though. It’s a close match for the engine pan. I think
      it could be reworked. I found modifying the engine pan to be
      straightforward. I think it took me one day. As I’ve said before, not
      including labor, the engine is less than half the cost of a full repower.
      This Cummins can use the same V-drive and running gear so you can refit the
      engine without doing the rest right away. There’s all the other stuff too
      like exhaust system, engine bed, and fuel tank. You could probably get away
      with around $5k..$6k for a minimal repower including the engine, assuming
      all you replace is the engine.
    • #73957
      “How is your Cummins engine working out?
      Pete:
      I am going to be inspecting a marinized one at the end of the month to confirm the parts I need and will start ordering them after that.
      It should keep me busy this winter (after I get back from sailing with Alan from Norfolk to St Martin for the month of November that is!!!)
      Rich:
      No, it doesn’t have any mounts. TAD was custom making them for each order I think. I am hoping I can get my local machine shop to make them up once I figure out what I need.
      Thanks for the throttle info. It looks like it has a standard linkage on top of the pump, but I will have a better idea once I see the finished product.
      I will be asking TAD if they sell a complete kit once I know what I need.
    • #73962
      Paul,
      Let us know what you learn from TAD and good luck!
      Pete:
      Rich:
      finished product.
