Forums › General Discussion › Nfm ports
Viewing 12 reply threads
    • #68152
      Call Michael lux this aft 360-821-1228
      He’ll set up a quote with you.
      – pat
      Sent from my Verizon Wireless Phone
    • #76094
      Phil Fontaine
      Hi Pat,
      I also am considering the NFM SS ports and called Michael Lux as you
      suggested to Joe. The boat show price I received for six 5×12 ports was
      $1529.10 which he said was a $37 per port saving. The $1529.10 price works
      out to be $254.85 each. Just curious about the source of the $230 price you
      mentioned in your earlier message.? Second question concerns cabin wall
      thickness. Do you (or anyone else) know what that is? Alternatively, can
      someone who has purchased these tell me whether teak spacers were required
      to make up the correct thickness? Michael Lux mentioned needing somewhere
      around 3/4 inch thickness. I’d be surprized if our cabins are that thick.
      Phil fontaine – Aurora
    • #76095
      We’re finding that using the teak rings on the inside is making things
      line up better, with just the thickness of the hull and the interior
      wood I think we’re right on the minimum in terms of thickness.
      – pat
    • #76096
      You just missed my ealier reply.
      When we did out initial replacement we added 1/4″ plywood to the
      interior to cover teak damage. The holes we drilled to allow the outer
      frame to sit flush to the exterior of the hull went through the hull
      and the original 1/4″ teak plywood. So your original thickness is
      approximately 1-1/2″
      I would use the teak spacers and we go back and redo what had already
      done (they leaked and our choice to not use marine grade plywood was
      revealed as penny wise and a ton foolish) we are using the spacers and
      it’s going very well where we used them in the head.
      On Thu, Oct 7, 2010 at 1:55 PM, Philippe Fontaine <> wrote:
      Hi Pat,
    • #76097
       I used the teak spacers. the cabin thickness is  around an 1/8″, if that.. So you need to purchase the spacers
      — On Thu, 10/7/10, Philippe Fontaine <> wrote:
    • #76098
      patn
      Hmmm. i got price from the list I was looking at. As for the spacers,
      I think they would be a necessity given that I recall our cabin top as
      quite thin.
      We will be here for one more day. I’ll check tomorrow regarding prices
      for 6 with spacers and whatever else might be needed.
      – pat
      On 10/7/10, Philippe Fontaine <> wrote:
      Hi Pat,
    • #76099
      patn
      The ss window is 229.95 + spacer @ 39.95 + screen min 24.95. Boat show
      price for all 3 is 254.85.
      ( my friend bought 4 so we dissected his receipt )
      – pat
      Hi Pat,
    • #76101
      Phil Fontaine
      Pat, Patrick & Allen
      Thank you all for your replies.
      Phil
    • #76102
      Lots of pics:
      http://www.flickr.com/photos/deepplaya/tags/portlight/
      Blog Posts:
      http://deepplaya.com/post/New-Portlights.aspx
      http://deepplaya.com/post/Evolution-of-a-Porthole.aspx
      http://deepplaya.com/post/Setbacks-and-Problems.aspx
      Phil
    • #76103
      joe shimkonis
      the $230  price is on the NFM website for the 5  by 12’s.
      Joe Shimkonis
    • #76104
      joe shimkonis
      bought 6!- NFMetal ports~~-$1529.10 includes s s screens and spacers- Micheal
      says HI to the group and thanks –
      he’s at the show!!I ‘ve waiyed 6 months for the discount-    woo hoooo!!!
      Micheal says if we ever want a group discount on the larger ones -to assemble an
      order- base price 500 plus each-too much for me right now- I need sails!!
      Joe Shimkonis
    • #76105
      The cabin wall thickness is 1/4” and not thick enough for most new ports. We had 1/2″ teak rings made up and epoxied to the wall in order to mount new ports. We used Newfound Metals ports which are terrific. Get a quote from them. They are all stainless with stainless screens. Jim 424 No.219(1983)
      — wrote:
    • #76106
      joe shimkonis
      Joe Shimkonis
