Forums › General Discussion › OIL & TRANS COOLERS
- This topic has 14 replies, 1 voice, and was last updated 11 years, 5 months ago by
May 27, 2015 at 11:34 am #69075
Start of attached email. Subject: OIL & TRANS COOLERS
GOOD MORNING, ALL~
As a matter of general maintenance on my W-60, I intend to
swap out both the oil and transmission coolers. I as I recall, there was a
discussion last Winter regarding this issue, and someone volunteered a
source for these parts. If any knows of this source, or can contribute any
thoughts, please advise, thanks, BILL~~~ ~ (_~~ (_~ ~ ~ fair winds ~ ~ (_
Capt Bill Tice, aboard s/v CHARISMAIn a message dated 12/11/2014 11:20:45 A.M. Eastern Daylight Time,
writes:Joe,
The wooden block you reference – is that the support the rudder shaft
passes through just above the stuffing box (
http://www.svsarah.com/Sarah/Images/PlasticBushing.JPG)? There should be a
plastic bushing that keeps the shaft from wobbling. As you can see in my
picture that bushing tends to ride up out of the hole in the support. It
just needs to be pushed down periodically. At least one owner used a hose
clamp on the shaft to hold the bushing in place.
With regard to the stuffing box, have you tried to tighten it? I had a
persistent leak from the stuffing box. Initially the leak was stopped by
tightening the stuffing box, but eventually I had to repack it. If you
don’t have anything installed in the aft lazarette that shouldn’t be a
difficult task. I have a Northern LIghts genset in the lazarette and I
have to hire a boatyard munchin for any and all service on the stuffing
box.Regards,
Sarah’s Blog <http://www.sailblogs.com/member/svsarah/>On Thu, Dec 11, 2014 at 9:22 AM, Skip MacElhannon via maillist <
> wrote:If I recall correctly, the bottom of the rudder post sits in a bearing at
the bottom of the skeg. You should be able to disassemble everything on
the top of the rudder and let it sit on the lower bearing. I’ll be outat
my boat later this evening and look at it a little more closely to
confirm
Quote:how it’s set up.This does also assume the skeg or bottom bearing on your boat hasn’t come
loose and is ready to fall off.Skip
Quote:________________________________
May 27, 2015 at 11:42 am #82209
Hi Bill,
Leno coolers in Long Island City, NY I think, is the cooler supplier. It’s
definitely Lenco, possibly LIC. http://Www.lencocoolers.comBob
On May 27, 2015 7:34 AM, “Boat1stlady— via maillist” <
> wrote:Quote:_______________________________________________
Forwarded message
May 27, 2015 at 11:47 am #82210
Start of attached email. Subject: Re: OIL & TRANS COOLERS
Capt Bill Tice, aboard s/v CHARISMAIn a message dated 5/27/2015 7:42:39 A.M. Eastern Daylight Time,
writes:Hi Bill,
Forwarded message
May 27, 2015 at 11:47 am #82211
THANKS, Bob – hope all is well with you.~~~ ~ (_~~ (_~ ~ ~ fair winds ~ ~ (_
writes:Hi Bill,
Forwarded message
May 27, 2015 at 12:08 pm #82212
I hate auto spell. That’s Lenco coolers.
On May 27, 2015 7:47 AM, “Boat1stlady— via maillist” <
Forwarded message
May 27, 2015 at 12:10 pm #82213
Thank you, Bill. They are. In St. Augustine on a delivery. How bad could
that be?Bob
On May 27, 2015 8:08 AM, “Robert Fine” wrote:Quote:I hate auto spell. That’s Lenco coolers.Bob
Forwarded message
May 27, 2015 at 12:39 pm #82214
Hey Bob,
I’m just down the road (or up the river, depending) in Green Cove Springs,
but flying out tomorrow morning for CT.Tor
May 27, 2015 at 12:42 pm #82215
I know. Working on boat today. How long will you be in CT?
On May 27, 2015 8:39 AM, “Silverheels via maillist”
wrote:Quote:Hey Bob,I’m just down the road (or up the river, depending) in Green Cove Springs,
May 27, 2015 at 12:42 pm #82216
Also, no car.
May 27, 2015 at 4:38 pm #82217
hate auto spell?? not sure I understand. ALSO, LENCO does not do
transmission coolers, or if they do they do not advertise it.~~~ ~ (_~~ (_~ ~ ~ fair winds ~ ~ (_
Capt Bill Tice, aboard s/v CHARISMAIn a message dated 5/27/2015 8:08:37 A.M. Eastern Daylight Time,
writes:I hate auto spell. That’s Lenco coolers.
Forwarded message
May 27, 2015 at 5:42 pm #82218
We had pulled into Titusville just before Christmas,1998 and I checked the trans fluid level. The color was milky pink–water in the trans! There was a machine shop in, I think it was Ft. Lauderdale, that provided a wide variety of coolers for different purposes. Their machinists built coolers from off the shelf parts. I called their shop manager and as I thought about it later, I sensed he had not understood exactly what we needed for Easy Reach’s W60. I made  a machine drawing of the cooler and faxed it to him. On our subsequent phone conversation he said that had misunderstood and would assemble one following my drawing. I don’t remember how I found out about that shop and my source left me with the impression that it was the only source where I could get a cooler. We had to wait two weeks because the machinists were off for the holidays. We had not further problems with water leakage into the trans.
Norris Larson
ÂPost generated from Pearson424 Forum using Mail2Forum
May 27, 2015 at 5:45 pm #82219
The original cooler on my W60 was manufactured for Westerbeke by Sen-dure. They offered a replacement on an exchange basis.
May 27, 2015 at 5:47 pm #82220
Sendure. That’s the shop I got the cooler for Easy Reach from.
Norris Larson
May 27, 2015 at 7:09 pm #82221
Bill,
When my transmission cooler failed in the Exumas a few years ago, I
contacted the guy who had rebuilt Silverheels’ transmission back in 2007:Cass’s Transmission-Marine Service
4451 Sunbeam Rd, #1, Jacksonville, FL 32257
(904) 731-0060He got one from some outfit in Fort Lauderdale and shipped it to me at Black
Point Settlement. Cass has specialized in marine transmissions for decades.
That’s all he does. He’ll know where to get what you need.Tor
May 27, 2015 at 8:14 pm #82222
I can second Cass for Velvet Drive service. That is, if he is still in
business. When he re-built my VD in 2011 (due to damper plate failure) he
was semi-retired and pushing 80 years old (my guess). Since he did an
excellent job on my VD, I’ve had no reason to contact him since then.Regards,
Sarah’s BlogOn Wed, May 27, 2015 at 2:49 PM, Silverheels via maillist <
> wrote:Bill,
Black
