Forums › General Discussion › Parting out W58 – taking orders now
    • #67823
      I will be parting out my entire W-58 and all spares. Send me your
      requests and offers by email directly to me (not to the group)
      My engine uses an oversized sea water pump. This mounts on the side of
      the engine with a stainless bracket. I have two complete units and
      extra impellers. This is a great system because if I need to change the
      impeller, I just swap out the entire assembly and worry about it later.
      If you are interested, let me know and I will send pictures. One has
      zero hours since rebuild and one has less than 50 hours since rebuild.
      (You really want to take both).
      Also have decreased and stripped paint from engine. I will prime and
      repaint any parts before selling (as appropriate).
      5 injectors
      5 glow plugs (4 have less than 50 hours on them, one is brand new)
      all injection lines
      injection pump
      fuel filter/primer assembly
      coolers (all just recently boiled and tested)
      hoses (all those funky pre-bent and tapered ones)
      full gasket set (less base gasket from bottom of thermostat housing).
      freshwater pump (complete assembly with pulley)
      complete head with valve cover
      lots of extra gaskets, etc that I will list later
      engine mounting brackets (get spares… they do break)
      at least two starters (I have to dig for the third one)
      exhaust elbows
      any part you can imagine…
