Forums › General Discussion › pearson 424 group
Viewing 4 reply threads
    • #68016
      I just returned from 19 months sailing from Trinidad to Australia on a friends Oyster 485 and six months sailing on my 424(Revery) in the Caribbean. Can anyone tell me what make traveller was used on 1983 424’s? I have a crack in the pin that holds the shackle to the piece that connects to the traveller car. This was picked up on a recent survey. On the same survey the steel mast step had a lot of corrosion and must be replaced. I plan on using aluminum to replace it. I also am replacing the Awlgrip finish on the mast for the second time-last in 1998. Please put me back on the 424 email list. Jim Roberts, #219-cutter
    • #75420
      Jim,
      Not sure how much Pearson changed things between 1978 to 1983. I believe on
      my 1978 ketch the traveler track and car are Nicro. The blocks are
      Shaefer. I don’t have a pin or shackle on my traveler car so maybe things
      did change. I did have the machine screw that attaches one block to the car
      pullout on the way to the Azores in 2005. I drilled and taped a new hole
      for the screw and it has held every since.
      Most people I know who replaced the traveler went with Garhauer.
      That must have been a sweet ride on the Oyster.
    • #75421
      James,
      Our 1982 (#178) also used Nicro-Fico traveler. Rig-Rite, if you can get
      a hold of them, stocks parts.
      Dave & Pat
      Doris E.
    • #75422
      Just to clarify things here is a picture of my traveler car with the fix
      performed in 2005:
      http://www.svsarah.com/Sailing/AtlanticCircle/Images/Traveller%20Repair%202.JPG
      On Sun, May 16, 2010 at 4:08 PM, dave jones <> wrote:
      James,
      Our 1982 (#178) also used Nicro-Fico traveler. Rig-Rite, if you can get a
      Dave & Pat
      Doris E.
    • #75424
      Jim, fabricate a mast step out of G10/Garolite. Won’t corrode. The mast
      will always have some sort of leakage into the bilge. Makes no sense to put
      something back down there that will react to water, salt or fresh.
