Forums › General Discussion › Play in prop shaft
Viewing 3 reply threads
    • #68009
      Seeking advice,
      I pulled my V-drive and took it to Jersey City for a rebuild. The lower seal (to the prop shaft) was passing oil even when not running. After removing the drive, I noticed the prop shaft moved up and down about a quarter of an inch and tiny bit side-to-side. Is this normal or does the bearing surface through the hull need some repair?
      The cutllass bearing was replaced two years ago and I was not paying attention to play in the shaft at the time. Easy Reach, hull #206, is also equipped with a PYI dripless box.
      Norris Larson
    • #75345
      Hi Norris,
      The shaft, especially with a dripless seal, can move quite a bit. The
      V-drive coupling is what keeps it in line with the cutlass bearing.
      Remember, once you disconnect one end of a shaft it will move – I would
      actually tie it up so that it doesn’t put undue stress on the cutlass
      bearing and strut. It’s heavy and provides quite a bit of leverage on the
      strut it wasn’t designed to take.
      On Tue, May 11, 2010 at 11:26 AM, norris larson <>wrote:
      Seeking advice,
      Norris Larson
    • #75350
      With the coupling disconnected from the V-drive, it is normal to have some play in the prop shaft, as much as an inch or more.
      Rich BlackSheep
    • #75366
      Supporting prop shaft:
      I did suport the shaft with a line and now have a bllock of wood underneath it resting on the V-drive containment basin. But thanks for the tip.
      Norris
      — On Tue, 5/11/10, Robert Fine <> wrote:
