Forums › General Discussion › Plugged W58 coolant passage
Viewing 20 reply threads
    • #68102
      I think I’ve finally chased down the reason the engine has been excessively hot in places. I’ve checked out the engine temp in several places with an infrared gun and found uneven temps. I pulled one of the hoses and sludge came out. I assume that this is keeping the water circ less than desirable. Can anyone recommend a good cleaner so that I can douche out the cooling system? I’ve heard of some type of acid as well as a less volatile options, but I haven’t chased down anything specific yet.
      Lady Leanne II (#135)
      Honolulu
    • #75817
      You can go to an automotive store and get the stuff they use – radiator
      flush.
      Honolulu
    • #75819
      Jack Clarke
      There is a product that is sold at West Marine as well as other places
      called salt away, or something like that. It’s used to flush out outboard
      engines. If you draw it through your strainer and let it sit over night, it
      will help clean out a lot of salt deposits in the heat exchanger and
      increase flow through the system.
      Jack
      Xanadu
      Honolulu
    • #75820
      Is this the fresh water side or raw?
      it
      Jack
      Xanadu
      excessively
      desirable.
      options,
      Honolulu
    • #75823
      Jack Clarke
      Sorry Guys, This is the fresh water side. You just close the sea cock,
      disconnect the hose , dip it into a bucket and pour the stuff in and start
      up the engine until you see it coming out the exhaust. Keep the fluid level
      up so that you have enough fluid going into the engine. Just the same as
      winterizing an engine in cold climates. Not that too many of you would know
      about cold climates. Just kidding.
      Jack
      Xanadu
      it
      Jack
      Xanadu
      excessively
      an
      sludge
      desirable.
      options,
      Honolulu
    • #75824
      Jack Clarke
      I’m sorry again, it’s the raw water side.
      Jack
      Xanadu
      outboard
      it
      Jack
      Xanadu
      excessively
      an
      sludge
      desirable.
      cooling
      options,
      Honolulu
    • #75825
      Dan-
      I think that there is a strong possibility that the sludge is corroded aluminum, perhaps from the thermostat housing and the watercooled exhaust manifold. If it’s like the W-58 I took apart in the garage, the crud is mostly in the t-stat housing and the freshwater circulation pump, and maybe clogging the freshwater side of the heat exchanger.
      If you use some chemicals, be sure they are safe with aluminum.
    • #75827
      Indulgence
      Hello,
      I too have noticed that my engine is running hotter as I head south…I
      worked through the system and noticed that my heat exchanger had some sea
      grass and a build up of scale. I’ll try the West Marine stuff and see how
      that works.
      I recall a similar conversation some time back and someone recommended
      boiling the heat exchanger in muric acid. If adding this West Marine stuff
      this is an easier solution, then it beats having to remove the exchanger
      (and drain all the coolant). After cleaning out the gunk…things seam to
      be better. We have long motor sail to the Cape Cod canal tomorrow…that
      will be the test. I will have to remove the scale at some point, as I am
      heading towards warmer waters and I’ll need a more efficient heat exchanger.
      Thanks for the tips.
      John Sommer
      Indulgence #179
      Portland, ME
    • #75828
      My problem is in the fresh water side. I had the heat exchanger cleaned, put in a new water pump (needed), added a new thermostat and sender unit. The engine still slowly heats up to 200+ after about 30 minutes. I finally pulled a hose and checked and out oozed some sludge. The raw water side works great. I am wondering if someone might have a recommendation on a good fresh water system cleaner.
      Honolulu
    • #75830
      When I was on the delivery of the 54′ Betram last month, we found oil in the
      coolant when stopped for a 50 hour service on a rebuilt engine. The Detroit
      Diesel solution to flush system was Calgon. This emulsified the oil and
      dissolved deposits in the system. Of course this was an 850 HP V-12 not a
      54 HP 4 cylinder engine.
      Still this might be the cheaper alternative to Salt Away.
      John,
      Was Indulgence the 424 I saw on a mooring in Belfast a few weeks ago?
      That is a long trip to Cape Code from Maine. On that Bertram we made it in
      about 12 hours, but that was throttled back to 13 kts to save the owner a
      little on fuel costs.
      On Mon, Aug 16, 2010 at 10:53 PM, John Sommer <> wrote:
      Hello,
      that works.
      John Sommer
      Indulgence #179
      Portland, ME
    • #75832
      Here’s what I’ve found with the heat exchangers both on Pelican and other
      boats I’m working on: The dissolved zincs end up plugging the tubes. A
      small threaded rod makes a very nice cleaning tool that can do what removal
      and boiling can or flushing or whatever quickly and efficiently. Just be
      gentle.
      It only takes a few minutes.
      Hello,
      that works.
      John Sommer
      Indulgence #179
      Portland, ME
    • #75833
      Any flush from an auto parts store.
      Honolulu
    • #75834
      Indulgence
      John,
      Boat you saw was “Bead Game” out of the Bronx. They were in Belfast around
      the same time. We met up with them at the SSCA Gam in Isleboro. I ran into
      another 424 while cruising Maine, Juno. This used to be Veritas…It is now
      owned by a Sweedish couple (he is a yacht designer is Sweeden). They cruise
      New England every summer.
      Bob,
      Thanks for the tip…any suggestion on the Rod? The passages are very
      small….I don’t want use a piece of coat hanger as I am sure the passages
      are pretty thin copper.
    • #75835
      Hi John,
      I used 6-32 rod from Home Depot – just be careful. Don’t force anything.
      But that’s for the raw water side. The freshwater side needs flushing
      agents.
      On Tue, Aug 17, 2010 at 7:57 AM, John Sommer <> wrote:
      John,
      Bob,
    • #75838
      If you clean out your V-drive cooling jacket, flakes of crud can find their way into the heat exchanger unless you are very careful. Routine service of the heat exchanger is suggested, every decade or so it should go out to be cleaned and checked. If you have an oil-cooler or transmission cooler, it should go out too. If they are on the freshwater side, service can be less frequent.
      Watch for broken water pump impeller vanes in the cooling system. They occasionally break off and can wedge in there somewhere causing a water flow problem.
    • #75845
      Dan-
      When you replaced the thermostat, did you use a Westerbeke part? It has a special disk on the bottom to close the recirculation passage and route coolant to the heat exchanger.
      Clairebuoyant #132
    • #75884
      Indulgence
      Turns out my “hot” running engine was due to stuck thermometer….I picked
      up a NAPA #139….the boat is now running 180.
      John Sommer
      Indulgence #179
      Portland, ME
    • #75885
      You gotta love the easy fixes!
      On Aug 21, 2010, at 13:53, “John Sommer” <> wrote:
      Turns out my “hot” running engine was due to stuck thermometer….I picked up a NAPA #139….the boat is now running 180.
      John Sommer
      Indulgence #179
      Portland, ME
    • #75886
      Indulgence
      Too bad it required me to pull apart my raw water side (pump, heat
      exchanger, etc) first…..
    • #75887
      Quent: I had previously replaced the thermostat with a NAPA one and she ran great (170-180). The uneven cooling started after that. I wonder if it might be zinc sludge. When I pulled the heat exchanger for cleaning, the zinc that was in there was half gone. My engine guy mentioned something about a powerful cleaner that can unclog the passage. I will share the brand name once I find out what he’s going to use.
      Honolulu
    • #75888
      The NAPA #139 sure looks like the right thermostat. Here is a picture of it on a Brit web site.
      http://www.britishcarforum.com/bcforum/ubbthreads.php/topics/585475/Pulling_an_MGC_s_head cat
      I guess this is more evidence that the base engine is by Perkins.
      Could be zinc pieces, parts from old water pump impellers,or just misc. debris in the heat exchanger tubes. Harbor Freight has some tube brushes ideal for cleaning them out. I took off the ends then pulled the brush through with a piece of ss siezing wire. Be careful of the end parts of the heat exchanger. The original bolts were brass and dependent on the zinc to stay intact. Inspect them carefully before you reuse them. The ends seal with round gaskets and o-rings around the bolt. Don’t tighten the bolts too much or the end covers will crack.
