Forums › General Discussion › Poly X Sanitation Hose
Viewing 8 reply threads
    • #68014
      Does anyone have any experience with Poly X sanitation hose? Is it very flexible? I’m about ready to wrestle with the head-to-tank hose and replace it. This is supposed to be the best out there, but at $18.69/ft (West) is it all it’s “pumped” up to be?
      Lady Leanne II (#135)
      Honolulu
    • #75413
      Dan, This sounds to me like it’s a very high grade product, maybe overkill, but excellent. I think you can use regular saitation hose for a lt less $$$cost.
      Joe,
      Shields Poly X is considered the ultimate sanitation hose. Easy to slip over most fittings, Poly X combines the flexibility of a rubber hose with the permeation resistance of polyurethane, making it one of the most versatile and durable sanitation hoses on the market.
      It is made of smooth white neoprene with two textile fabric plies and features a glossy cover of polyurethane that is abrasion resistant and easy to clean. The Poly X can operate at temperatures ranging from -22 degrees +195 degrees F and comes with Shields’ lifetime warranty against odor permeation.
      Available in 12″ lengths with internal diameter of 1″ as well as 12′ and 50′ lengths with internal diameter of 1-1/2″.
      Product Number Dimensions O.D
      SHI-1051004 1in x 12-1/2ft 1-21/64in
      SHI-1051124 1-1/2in x 12-1/2ft 1-27/32in
      SHI1051120 1-1/2in x 50ft 1-27/32in
      BRAND: Shields
      Type: Sanitation Hose
        SHI-1051004
      SANITATION HOSE 1^ X 12-1/2
      $141.25 / ea for 1 ea and more
        qty.
        SHI-1051124
      $166.69 / ea for 1 ea and more
        qty.
        SHI-1051120
      SANITATION HOSE 1-1/2^ X 50
      $667.23 / rl for 1 rl and more
        qty.
      How to’s
      * Keeping the Holding Tank Clean
      REVIEW SNAPSHOT®by PowerReviews
      Not yet rated. Be the first to Write a Review
      close
      Select a product:
        SHI-1051004 SHI-1051124 SHI-1051120
      1 ea and more
      Only  $141.25 / ea
         qty.
      Users Also Bought:
      Shields Premium Rubber Sanitation Hose
      Shields Sanitation Hose Fittings
    • #75414
      We use Sea Land Odor safe with excellent results. I’ve replaced runs of
      Shields that were about 5 years old due to permeation. This wasn’t
      necessarily an issue with the hose but more with the design of the system
      that allowed waste to stand in the hose.
      Any place you can put schedule 40 PVC instead of hose makes a world of
      difference.
      Honolulu
    • #75415
      I agree with Chuck, regular DWV hose ( pipe ) is fine. Make sure you specify regular schedule 40 and NOT cell cored schedule 40 PVC as it’s brittle.  If you heat it to above 140 degrees you can soften it enough to bend it somewhat.
      Joe,
    • #75418
      world of difference.
      Not recommended if there is any chance of freezing. I’ve had the stuff
      split open on me. Might work well in warm climates though.
    • #75419
      Was there water in your PVC pipes that split open, or did empty pipes simply
      crack from the cold? Isn’t PVC used in home construction in northern
      climates?
    • #75423
      Water backed up in the pipe. This is pretty easy to happen if water settles
      in the pipe. I used PVC many years ago to replace a cocpit drain hose (not
      a Pearson). I went out sailing one day to find water running into my bilge
      when the boat heeled over. The drain hose was shattered above the water
      line.
      Yes, PVC pipe is used in home construction, but the homes are heated. A
      cold night here in the northeast can freeze standing water here in the
      northeast unless your boat is heated.
      Fresh-water would be more of a problem.
    • #75425
      The suggestion for PVC was associated with head plumbing. If you don’t
      winterize your head yes you could split a PVC pipe, as well as a holding
      tank, head pump, flexible plumbing….
      The only product that should be installed on a sea cock below the water line
      or a thru hull that has the potential to sink the boat is J2006E rated hose.
      line.
    • #75427
      Thanks Chuck
      My comment was just a caution about using plastic pipe. Having water flood
      the bilge scared the poop out of me. No sanitation hose needed.
