Forums › General Discussion › Prop shaft removal
Viewing 1 reply thread
    • #67918
      By accident I found a quick and effective way of removing the prop shaft from the coupling.
       DO NOT TRY THIS AT HOME.
      Attach a  50 foot 5/8 dock line to your forward stb cleat.
      Let it drag in the the water until you start the engine
      Put engine in fwd gear and rev up to 2000 rpm.
      As the line wraps around the prop shaft between the prop and the strut it will quickly pull the shaft out of the coupling (it acts as a screw as the line is wrapped around the shaft)
      no muss – no fuss – don’t even have to get your hands dirty
      Add 20 knots of wind and coral reefs on either side of you and it makes for a complete afternoon.
      Thanks to Walt P ( Madness Hull #1) for the assistance in getting it back together.
      UNABATED
      http://www.sailblogs.com/member/unabated/
    • #74913
      patn
      Oops
      Glad you are all okay.
      – pat
      from the coupling.
      together.
      UNABATED
      Sent from my mobile device
