Forums › General Discussion › Prop Strut = Bad Day
Viewing 7 reply threads
    • #68093
      Bill,
       I am trying to make plans to drive back to Va. to work on the boat. I know I can stay on my boat for a few days, but they discourage “living” on in while it’s on the hard. I am trying to search the Internet for a place to stay while I am there. It may be for a week or two, maybe 3.
      Do you know of any places in the area (short drive) where I can rent a room for while or an efficiency apt that  I can rent by the month? Something that won’t break the bank?
      thanks
      — On Sat, 6/19/10, <> wrote:
    • #75779
      Alan-
      Are you still looking for a prop shaft? I found one that might work.
      Quent Kinderman
      Edgewater, MD
      Clairebuoyant #132
    • #75780
      We haven’t removed the old one yet to determine if it’s actually bent. The strut is clearly bent. I have found a source to get a new strut cast. Will have to wait on the shaft.
      Is this shaft from a 424 or just a similar dia. and length?
      — On Fri, 8/6/10, quent <> wrote:
    • #75781
      It’s a bit longer than necessary, just needs to be cut to length and keyed which can be done easily here in Annapolis since our original shaft is in the basement.
      It’s from a 40+ foot Carver power yacht, used but in nice condition. Stainless aquamet 17. I don’t know why Pearson used 1-1/2″ shafts, way overkill for a 60 hp engine and low shaft speeds.
      I bought it as a spare, if you decide you can use it, $200.
    • #75782
      Great, thanks.
      I’ll keep that in mind. I’ll be heading down to Deltaville in the next few weeks to start yanking the engine out. I’ll keep that in mind.
    • #75783
      As a suggestion, take the thing down to a prop shop and have them check it before doing anything with it. You might be better off cutting the prop end rather than the coupling end.
      Odd that your strut is bent. I wouldn’t have expected that.
    • #75784
      I had the coupling off this winter so it “should” come right off.   I should be able to save the parts.
      As far as the strut is concerned…. 3 people have looked at and have come up with the same conclusion.
      — On Fri, 8/6/10, <> wrote:
    • #75789
      HI – I just read your email, as I Have not turned on my computer in the
      last 6 days. I am at “Treehouse”, as it is now known, very busy with the
      contractor, electricians, kitchen revisions, etc.
      I’m afraid I can’t be of too much help RE; your request, although I do
      recall a “motel” next door to the marina — ask
      Lew Grimm. I’ll be back in D’ville this weekend and will check in on you
      good luck.
      BILL
      ~~(__~~ (_~~~fair winds~~ (_~~
      Capt. William Tice, USCG Master, 100 Ton
      In a message dated 8/4/2010 10:12:59 A.M. Eastern Daylight Time,
      writes:
      Bill,
      thanks
