Forums › General Discussion › Pulling the fuel tank
Viewing 17 reply threads
    • #68413
      So I got the tank loose and I’m trying to decide the right next step as it’s
      not sliding out due to the wires in the mizzen step and the engine pan, as
      well as the Racor laterally. Those of you who slid it out, what all had to
      be removed. I should mention I have removed the front of the box holding in
      the tank and the angled ramp is what I’m riding on, not the flat section in
      the front of the box, i.e., the tank has slid down several inches already.
      – p
      Taken by deepplaya http://www.flickr.com/photos/26558453@N03/6130015395
    • #77606
      I had to cut off the fill fitting to make it easier to slide under the mizzen brace.
      – p
    • #77607
      Patrick,
      My mechanic had to bevel the forward edge of the mizzen brace. Of course
      that was after removing all of the engine wiring and fuel lines.
      That soft fuel tank is sounding better and better. I think some of those
      designs from the company Quent identified look pretty substantial (most
      likely substantially priced as well).
      If you are going to replace the tank and not the engine, this sounds like
      a job for a sawzall.
      mizzen brace.
      On Sep 9, 2011, at 12:13 PM, “Patrick “Peaboy” Walters” <
      it’s
      as
      to
      in
      in
      already.
      – p
    • #77609
      Definitely pull the Racor and those old motor mounts. I seem to remember trimming a bit off the aft end of the engine bed as well. Re the mizzen wires, one more reason I’m glad we have a sloop.
    • #77610
      Herbc
      I thank my lucky stars our tank did not leak this summer. Thanks (tanks?) for the great photo. The more I study the replacement issue, the more I’m resigned to lose a few gallons.
      Are you getting a new tank fabbed. Or thinking about a repair of the old. Can the old tank be made to cradle bladders? Cut yours off short and put a shorter new tank back in? Then maybe add small bladder to add capacity.
      Just thinking out loud, sorry I don’t have the answer, the whole fuel tank issue makes me thirsty, now where is that rum. BTW saw a pic with Pat and about 7 empty glasses, allegedly they once held 7 flavors of rum.
    • #77611
      One thing I considered was to have the bottom cut off and a new one welded on since the rest of the tank was fine. However, my welder wouldn’t work on a used tank even after I power washed it. Ergo, the epoxy and fiberglass repair.
      I did have a pinhole leak on a welded seam repaired on an aluminum tank on a previous boat. That welder simply filled the tank with nitrogen first.
    • #77612
      I pulled the racor off… not hard.
      I also cut the end of the engine tray a bit, that thing is massively thick
      I’m sure I didn’t weaken it at all.
      I’m also getting new motor mounts for those playing a long at home the
      original part number DF-2206-2 is now DF-2207-2 by Bushings Inc. Shouldbe
      about $40-50 each.
      The tank did not have a big obvious hole in and we could have had a repair
      made, but the estimate is $500 for a new tank so since everything was out
      I’m going to go with the new tank.
      While the engine is out we’re going to clean it up a bit and try to spray
      some engine paint on it.
      Along with that we’re going to upgrade the alternator to a
      Leece-Neville 8MR2401UA100Amp
      Alternator ($250), and a Balmar MC-614 external regulator (with
      temperature sensors). We’ll keep the 65amp as a spare and the 8MR2401UA has
      a built-in regulator as a backup to the external. I think I’m also going to
      put in a dedicated 12V starting battery and move the 2 6v batteries on bank
      two to be in bank one adding an additional 220 Amp Hours to that bank.
      Anyway, we’ve been cranking here for three solid days and tomorrow we’re
      going to take the bus in from Charleston (where local weather phenomenon
      makes it always foggy) and see some sun and walk around and not work on the
      boat.
      LOTS of pics on Flickr – http://www.flickr.com/photos/deepplaya/
      Video of flying engine to come.
      repair.
    • #77613
      I recall having to remove the elbows on the top of the tank.
      – p
    • #77614
      Yes, I wasn’t specific enough. I had to remove the elbow from the
      draw, return lines, vent and had to cut off the nylon elbow for the
      fill. The fuel draw is two pieces, and you can’t pull the ~2′ draw
      tube until the tank is out, but you do need to remove the elbow.
      – p
    • #77615
      Are you going to do a rebuild? Or plug in another power plant?
      Jolly Lama (#135)
      Ko Olina, O’ahu
    • #77616
      Nope, putting back the engine, just going to knock of the corrosion on the
      bottom and spray on some engine paint.
      -=p
      Jolly Lama (#135)
      Ko Olina, O’ahu
    • #77617
      Yup, that’s what I said… then when I pulled the oil pan and
      plastigaged the bearings… it was clear that it was time for a new
      engine…
      -=p
      Jolly Lama (#135)
      Ko Olina, O’ahu
    • #77618
      IMHO
      While you have the beast out…. check the by-pass hose on the bottom the thermostat housing. If it looks”original” I’d replace it now. It’s a b****h  to get at while the engine is in place.
      — On Sat, 9/10/11, Pete Dubler wrote:
    • #77619
      That is a good suggestion… I’m curious about those hoses with the bends in
      them. I can see a PN for them in my manual, but of course they can’t be
      found online. Are they a generic thing I should be able to find or replace
      with an off the shelf hose?
      I have a new exhaust elbow and the extension pipe to which it mounts (came
      with the boat) and the old one is cracked. I’m going to have the yard get
      that pipe off for me as I’m afraid I’ll break something. They need to heat
      it up I’m sure.
      Anyway, I just spent the morning cleaning up the engine as much as I could
      (felt a bit like polishing a turd) and then put a can of engine paint on.
      I’ll do another can this afternoon, after the Seahawks game. I’m not sure
      how much I’m actually protecting anything, but the engine looks a lot
      better.
      On Sun, Sep 11, 2011 at 5:09 AM, Alan wrote:
      IMHO
    • #77622
      Really advise pulling the pan and doing some measurements. Paint can’t fix the stuff you might find. Plastigage the main and rod bearings and check the oil pump tolerances. A new oil pan gasket can be hand cut from sheet cork gasket stock instead of paying $75 for one
      it up I’m sure.
      better.
      IMHO
    • #77623
      I took my hoses to the local autoparts store and purchased ones that had the correct bend and Cut them down to fit.
      Eric Lorentzon
      EFI Sales Development Manager
      412.352.1941
      it up I’m sure.
      better.
      IMHO
    • #77625
      Hansen Marine has the hose and most of the other W58 parts.
      — On Sun, 9/11/11, wrote:
    • #77624
      Check all the metal tubing in the cooling system while the beast is out. I had some pinholes and had to do a replacement in situ (I think I can join the circus now).
      These tubes are not available now and you’ll have to have them fabricated. I have a great source in Wisconsin that can handle the diameter needed at very reasonable prices (no one on the island had gear to make one in the right diameter). I sent them the old one as a reference and they did a quick turn around. Let me know if you need source info.
      Jolly Lama (#135)
      Ko Olina, O’ahu
