Forums › General Discussion › Pulling the mizzen
Viewing 16 reply threads
    • #68720
      I’m planning to pull the sticks for refinishing. The boat’s still on O’ahu and I’m back on the mainland and can’t visualize how the mizzen is fixed to the cockpit floor. Any guidance/advice out there so I can prepare before my trip back? Mahalo
      Keehi Lagoon, O’ahu
    • #79459
      Dan,
      The mizzen mast rests on a shoe screwed into the cockpit sole. It will
      lift off the shoe once the rigging and any electrical wires are
      disconnected.
      Keehi Lagoon, O’ahu
    • #79460
      It isn’t. It goes through the mizzen partners in the cockpit floor and is
      secured to the hull below.
    • #79462
      Mizzen is deck stepped because fuel tank is right below. Main is keel
      stepped through partners.
      On May 15, 2013 11:00 AM, “Thatcher A. Stone – Confidential Attorney
    • #79465
      Not on mine.
    • #79466
      Really? Where was the fuel tank?
      On Wed, May 15, 2013 at 12:30 PM, Thatcher A. Stone – Confidential Attorney
      Communication wrote:
      Not on mine.
    • #79467
      On the starboard side.
    • #79468
      This is really interesting, Thatcher, because I’ve been on over a dozen
      424s and the layout has been identical for that stuff – all fuel tanks
      under the cockpit sole, mizzens deck stepped. The keel stepped mizzen
      seems like an extravagance in boat building. Did you have a special
      layout? Like Rich Carter’s? I wonder if the previous owner had that done
      for long range cruising and because replacing the tank is such a pain in
      the patootie. It’s much easier to get it out than put it in. Where are
      your batteries? Also: what hull number do you have? I wonder if that was
      one of the last built.
      Just out of curiosity, how much does your fuel tank hold?
      Anyone else have a starboard fuel tank? Keel stepped mizzen?
      On Wed, May 15, 2013 at 1:04 PM, Thatcher A. Stone – Confidential Attorney
    • #79469
      This is a special layout. And just from a pure sailing theory point of view,
      the pressure from the mizzen would need to be laterally displaced by the
      keel to provide forward motion. Not sure the cockpit floor would convert the
      lateral wind pressure into forward moment. But then, I studied physics.
    • #79470
      I don’t remember if you purchased yours new or from a previous owner.
      It’s a good modification, but something like adding suspenders to your
      belt. Deck stepped masts of any sort have one serious downfall – namely if
      the rigging is compromised, the mast can jump the foot and become a
      hazard. It’s a good excuse to maintain your rigging. In your case, the
      mast could survive a windward upper shroud parting probably if the winds
      weren’t too great and the driver was quick on the helm. Ours might not and
      take out a lot more than just the mast. That’s why your tank is where it
      is, because it can’t be anywhere else.
      In our boats, there is a rather heavy athwart ships beam that transfers
      both the vertical and horizontal loads to the hull. Because the boat is
      essentially one box beam (in mechanical terms) whether the load is applied
      to the top or the bottom of the beam is of no difference (ignoring the
      torque that would tend to pitch the beam or wrack it). The mast foot in
      the cockpit does transfer the load quite nicely as a deck stepped main
      would also do. From a purely observational view, the boat does quite
      handily with mizzen and jib. It will sail with just the mizzen but not
      terribly well because it is so far from the center of lateral resistance.
      I studied physics, too, but have confirmed the deck stepped mizzen
      experimentally. 🙂
      On Wed, May 15, 2013 at 1:39 PM, Thatcher A. Stone – Confidential Attorney
      view,
      the
    • #79471
      Well some of the force might be lost if not stepped into the keel. It is
      after all the keel and not the hull that provides the displacement of
      motion. In any event, I’m sorry to learn others are not similarly equipped.
    • #79473
      For force to be lost, the mast has to move in relation to the hull or the
      hull has to deform to absorb it. Since it doesn’t, all force transmitted
      through the mast is transmitted to the boat as a whole regardless of
      mounting point.
      Anyway, it seems like a good arrangement, and if you have the same 80
      gallons of fuel, even better. It gives you a large storage area under the
      cockpit. And you have the potential, I guess, of putting another tank to
      port if that’s what’s needed.
      Very interesting. Thanks for your time describing this, Thatcher!
      On Wed, May 15, 2013 at 2:37 PM, Thatcher A. Stone – Confidential Attorney
    • #79476
      Thanks for the info. Learn something new about these boats every day.
      Jolly Lama #134
      Keehi Lagoon, O’ahu
    • #79483
      Not on my boat… it sits on a shoe on the cockpit floor.
      On 5/15/2013 8:00 AM, Thatcher A. Stone – Confidential Attorney
    • #79484
      Well there is a really hefty beam running laterally below the cockpit
      floor where the mizzen stands and that beam is supported by large
      vertical beams.
      On 5/15/2013 10:39 AM, Thatcher A. Stone – Confidential Attorney
    • #79485
      If the mizzen mast did not propel the boat, would it just sail off on
      its own or perhaps just be left behind?
      experimentally. 🙂
      view,
      the
    • #79487
      That’s correct, Pete. As long as force isn’t being dissipated though hull
      deformation, all force is transmitted to driving the hull one way or
      another. It doesn’t matter where the attachment is – although it does
      matter how it affects directional stability of the vessel. But you knew
      that. The farther away from the center of lateral resistance, the more the
      force tends to round the boat up. (Or, if it’s forward, force the boat off).
      On Wed, May 15, 2013 at 8:53 PM, Pete Dubler wrote:
      If the mizzen mast did not propel the boat, would it just sail off on its
      if
      and
      experimentally. 🙂
      Communication <thatcher@thatcher-stone-**legal.com>
      view,
      the
