Forums › General Discussion › Pumping out the fuel tank
Viewing 7 reply threads
    • #97718
      I need to pump out the 10-15 gallons of diesel from the tank before I remove it. Any suggestions on a good method?
      Many Thanks
      Keehi Lagoon, O’ahu
    • #97719
      In my case, I removed about 60 gallons. Straight into someone’s mobile fuel polishing system. And from there into my friends heating oil tank for his house. I heated it the whole winter so I get free showers when I am camping on the boat while she is on the hard.
    • #97720
      Dan
      I’d find someone in the marina who wants some diesel and make it his problem.  Alternatively, use a piece of metal tubing as a pick up at the tank.  You might want to move the tank forward before using a hand pump/siphon. Otherwise, bend the tube to get in, then bend it straight again after removing fill hose and tank fitting.
      Finally, don’t make my mistake.  Use a container small enough that you can lift it.
      Best regards,
      Ex-Clairebuoyant
      Frozen North, MD
    • #97721
      Ken Page
      I used a length of 1/4″ clear hose and set up my jug down in between the engine beds, well below the bottom of the fuel tank. Then I sucked on the hose till I saw the diesel far enough in the hose but not too close to my mouth and siphoned the bottom out. I never tasted the diesel, but I'd understand if that's not the way you want to do it. I'm just still a bit of a caveman.
    • #97722
      Hi Dan,
      If that’s all you have to pump out, why not just removed the sight gauge thru the cockpit sole viewing port, run a hose down to the forward (lowest) end of the tank, and sump out the fuel with practically any pump that can handle petroleum? When I bought Silverheels, I did that to pump out a couple of gallons from a fairly full tank just to be sure there wasn’t any water & sludge collected down there, since the boat has been sitting idle for a while. I used a $20 hand pump I bought at NAPA, I think, and pumped the fuel into a pail at first so I could see what was coming out. You’d need a few jerry jugs for 10-15 gallons.
      K.I.S.S.,
    • #97727
      Aloha Tor:  thanks for the tip.  Sometimes the answer to a complicated question is hiding right out in the open.
      Mahalo!
      Keehi Lagoon, O’ahu
    • #97729
      Aloha Quent:  thanks for the tips!  Hope the blizzard wasn’t too hard on y’all.  Come to think of it, I haven’t thrown a snowball in years.
      Best,
      Dan
    • #97744
      Go with Tor’s idea. Positively brilliant.
