Forums › General Discussion › Raw water screen
Viewing 22 reply threads
    • #68756
      Last weekend, my raw-water cooling system got clogged again. This seems to happen about once each year. It only seems to happen when the boat is not moving as when the engine is idling at the mooring or just started. A clump of seaweed gets stuck in the through-hull. There are only two reliable ways to unclog the through-hull, either dive under the boat and pull the weed out or back-flush it with a water hose. I’ve tried using the shower hose to back-flush but it doesn’t seem to have enough flow. I need to bring the boat to a dock and use a garden-hose. Here in the northeast, the water is typically cold and I’m reluctant to dive to pull the weed, so backflushing is the beast solution. I bought a sink drain snake but I haven’t tried it yet. My guess is that simply pushing the clog out an inch or two will only result in the weed getting sucked right back in.
      I’m thinking of adding an external screen to the outside of the hull. I’m not sure that this will cure the problem however. The weed might just as easily get stuck on the screen. Has anyone installed one of these and have comments?
      http://www.defender.com/product.jsp?path=-1|311|314196&id=673926
      BlackSheep #47
    • #79840
      Unabated had a screen like that when I purchased her. Never had an issue and sodus bay is very weedy esp. at the dock.
      BlackSheep #47
    • #79841
      I was advised against using a scoop type screen on my engine intake
      thru-hull by Deatons Yard in Oriental, NC. The reasoning was that the
      scoop (mine was a slightly larger Groco), when sailing, could force water
      through the system and eventually get water into the exhaust system and
      into the cylinders.
      I was skeptical of this reasoning, but unwilling test it so I left the
      strainer off the engine intake, and just put one on the intake for the
      frig, A/C and galley faucet. That intake was the one that was causing me
      trouble on the Chesapeake. I ran the frig whenever dockside and it would
      usually clog with sea nettles once a week. Since installing the scoop
      screen I have not had a single clog.
      I left the engine intake without a screen and have never had a clog, but I
      also use a 1-1/2″ thru-hull and strainer. That intake serves both the
      Yanmar 4JH4-AE and the Northern Lights M642 generator, which I rarely run
      simultaneously.
      This is the screen I intended to use on my engine intake:
      http://www.defender.com/product.jsp?path=-1|51|2234255|2234259&id=1806778
      I think Tor put something similar on his engine intake, and has apparently
      had no problems after 1,000s of miles of sailing. If that is so, the
      advice I got is probably baseless.
      comments?
      BlackSheep #47
    • #79842
      As originally built, my 424 had the strainer attached directly to the top of the sea-cock with a bronze elbow. Sea-grass would get caught at the elbow. When I repowered, I removed the elbow and installed a new strainer. Power boats running through shallow water cut gobs of the stuff which floats along the channels. Grass doesn’t seem to cause problems anymore. I find it in the strainer which is easy to clean out. It’s the seaweed that has bulbs on it that gets stuck in the through-hull. Local fishing boats drag the bottom and pull up the stuff.
      I always thought the elbow mount used by Pearson was a bad idea. The strainer hangs on the pipe fitting. If this fails, the boat will flood. Even if the fitting never fails, it’s a natural place for stuff to get caught.
      http://www.richardcarter.net/boat/pix/vdrivePan.JPG
    • #79843
      Thanks John,
      I see two types of screens, one is round and the other is scooped. I see no mounting instructions so I don’t know which way the scoop is supposed to face. If I put the round type on, I don’t see how it could force water into the system. I’m not convinced that it won’t still get weed caught in it and eventually clog. Unlike the raw-water strainer, there is no convenient way to clean it however. Draggers pull up great clumps of weed. This sometimes finds its way into our mooring area. These are big clumps of weed. If I sucked one into even a 1.5 inch intake, I think it might clog though I might be able to pull the weed through.
    • #79844
      I agree, going with the round (no scoop) screen would not force water into
      the system. The yard also said if I put the scoop on backwards (facing
      aft) I would not have a problem, but that would defeat the purpose of the
      scoop. For now I have left the engine intake un-screened. Again that
      advice on the scoop screen may be baseless.
      I sized the screen such that even when half the screen was clogged by
      debris I would still have full flow into my 1-1/2″ thru-hull. I recommend
      doing the same with the round screen.
      I think you will find that most of the debris that might collect on the
      screen will be brushed off once you are underway.
      I don’t know which is worse for clogging seawater systems, weeds or sea
      nettles, but I am sure the sea nettles are worse to remove. My frig would
      suck in 2 or 3 then they would die and turn into super glue. Often they
      didn’t get to the strainer and just die in the hose from the valve. With
      the screen on this intake I’ve never had a sea nettle clog the system.
      On Tue, Jul 16, 2013 at 1:31 PM, wrote:
      Thanks John,
    • #79846
      The whole ‘forcing water into the engine’ thing is, in my mind, bs. The
      amount of pressure required to force water through the whole system
      including the raw water pump is ridiculously high. By that I mean 10s of
      pounds per square inch – far more than you could ever generate moving at 8
      knots through the water. There are boats that use speed through the water
      to cool engines but they move very fast and have very large scoops.
      But I could be wrong.
      On Tue, Jul 16, 2013 at 1:56 PM, John Stevenson wrote:
      Thanks John,
      to
      in
      weed.
      clumps
    • #79847
      Silverheels had no thru-hull screens when I got her. I installed a big one
      over the engine intake. It may be what you’re calling a scoop. (The wifi
      where I’m anchored right now is too weak to visit the URL’s you guys are
      providing as illustrations.) My bronze screen cover is shaped like a wedge
      of cheese and perforated all over with small holes. I mounted it with the
      tapered end facing forward. Perhaps this provides some scooping effect, but
      it has not caused any problems in 6 years that I know of, and nothing has
      ever clogged that intake. I put a half-round bronze screen cover over
      Silverheels only other intake thru-hull, which feeds the seawater intake
      manifold that services everything that uses seawater besides the engine.
      Nothing has ever clogged that, either.
      I don’t sail with nettles or masses of weeds, but the ocean contains of all
      kinds of debris including plastic. I’ve always thought some kind of screen
      is necessary over intake thru-hulls.
    • #79848
      Bob,
      I’m at least skeptical. However I noticed that MainSail (Compass Marine)
      posted the same warning on a forum a few years ago (
      http://www.cruisersforum.com/forums/f115/external-raw-water-strainer-65505.html).
      This guy is pretty knowledgeable, and generally not an alarmist.
      On Tue, Jul 16, 2013 at 1:56 PM, John Stevenson <
      wrote:
      into
      recommend
      would
      Thanks John,
      see
      supposed
      to
      in
      weed.
      clumps
    • #79850
      I agree, in order to force water through the engine you’d have to push past the water pump impellers.
      On Jul 16, 2013, at 3:43 PM, John Stevenson wrote:
      Bob,
      wrote:
      into
      recommend
      would
      Thanks John,
      see
      supposed
      to
      in
      weed.
      clumps
    • #79851
      Tor’s experience convinces me that the warnings are overblown, but I think
      if I ever put a screen on the engine intake it be a round one that is
      over-sized and can be opened to clean the thru-hull. No sense in tempting
      fate.
      wrote:
      Bob,
      of
      at 8
      water
      wrote:
      into
      the
      recommend
      would
      they
      With
      Thanks John,
      see
      supposed
      to
      water
      caught
      in
      weed.
      clumps
      might
    • #79852
      A lot of boats here on chesapeake have these big round strainers over genset intake thru hulls to prevent sea nettle jellyfish from stopping water flow. I think they work by dispersing the flow sufficiently that the jellyfish aren’t held against the thru hull.
      Might want to bear in mind that barnicles love to grow inside the strainers and they might need periodically to be cleaned. I seem to remember seeing one that was hinged for this purpose.
    • #79853
      No need to hinge a screen. They’re usually held to the hull by several
      screws. Easy enough to unscrew them during haul-out and clean things up
      inside. I’ve found that spraying bronze – screens, props, shafts, etc – with
      Petit Barnacle Barrier, a spray-on zinc product, not only serves as an
      anode, but also acts like a primer and enables copper-based bottom paint to
      stick to the bronze fittings long-term – even on the propeller! So my
      screens are anti-fouled and don’t tend to fill up with critters.
    • #79855
      Tor, are you saying that you apply bottom paint over the Pettit Zinc Coat Barnacle Barrier 1792 ? The description through Jamestown Distr. says not to, but I’d take your word on it if it has been sticking for you. I’ve always painted inside and out of my bronze clam shell shaped strainers and never had problems, other than I remember a few barnacles always finding it comfy. Never enough to make it a problem between haul outs.
    • #79856
      I hadn’t seen that Jamestown warning about painting over the zinc spray. So,
      yes, I put copper-based antifouling over it and was amazed at how well the
      bottom paint stuck, even (as I said) on the prop blades. I sprayed & painted
      my bronze screens inside & out, too.
      Putting zinc anode in between bronze (which I believe contains copper) and
      copper-based bottom paint does seem like a potential electrolysis issue,
      although the zinc is what’s going to go first. Anyway, last haul-out I
      cleaned and re-painted the bronze and saw no problems.
    • #79857
      Good morning ALL – Tor, at the time I met you in the Bahamas, I was not
      using bottom paint over my Pettit Zinc Coat Barnacle Barrier 1792 per
      instructions and with great success. At haul out the follow the following fall,
      growth on the prop was virtually little to none.
      As you know, I work the summers at WEST and this stuff flies off the shelf
      in the spring/fall and has left “Prop Speed” dead in the water. I have
      since learned that it is the same Petit product as their transducer paint,
      simply re-packaged because of its success and marketed as “Barnacle Barrier.”
      Paint your prop as well if you wish, but doing so is superfluous and may
      indeed impede the Barnacle Coat’s effectiveness.
      In a message dated 7/17/2013 4:58:31 A.M. Eastern Daylight Time,
      writes:
      Pettit Zinc
    • #79858
      I use the same Zinc based spray paint on my stainless prop. I follow with a coat of tin based outdrive spray paint. This keeps growth off the prop. The outdrive paint seems to adhere better if I first coat with the zinc spray paint. The zinc paint alone works OK but not as well as the tin paint.
    • #79859
      Good to know. Thanks, Rich!
      paint.
    • #79860
      Phil Fontaine
      Thanks Rich.
      The tin based outdrive paint is the only thing that worked well for me but I
      have not been able to get it in many a moon. Where do you get yours?
      Phil
    • #79861
      Phil,
      It’s sold as outdrive paint at almost any marine outlet. It comes in flat-black which makes my prop look mean and fast 😉
    • #79862
      This just keeps getting better.
    • #79863
      Good info, Bill. Thanks. Next time I’ll do it au natural.
    • #79864
      haha – your mileage may vary!
      Stay safe…
      In a message dated 7/17/2013 5:03:41 P.M. Eastern Daylight Time,
      writes:
