Forums › General Discussion › re boat doc
Viewing 6 reply threads
    • #68903
      Looking at the USCG Documentation for our 424, it shows the gross
      tonnage as “24 GRT” Now really that should be 24,000 pounds and not 24
      tons. (The net tonnage is shown as “22 NGT”. I tried to get the Doc
      Center to change that as I understand that port fees go by tonnage.
      They said since it was originally filed that way that it cannot be
      corrected. What does your doc say and has this been a problem in
      foreign ports?
    • #80911
      None of the islands in the eastern Caribbean even looked that close at the documentation papers.
      On May 8, 2014, at 10:07 PM, Pete Dubler wrote:
      Looking at the USCG Documentation for our 424, it shows the gross tonnage as “24 GRT” Now really that should be 24,000 pounds and not 24 tons. (The net tonnage is shown as “22 NGT”. I tried to get the Doc Center to change that as I understand that port fees go by tonnage. They said since it was originally filed that way that it cannot be corrected. What does your doc say and has this been a problem in foreign ports?
    • #80912
      patn
      I think they were all done that way. Just spot checked using
      https://pearson424.org/tiki/tiki-index.php?page=All+424s+we+know+about
      http://www.st.nmfs.noaa.gov/st1/CoastGuard/VesselByID.html
      – pat
      Pete Dubler wrote, On 5/8/14, 9:07 PM:
    • #80914
      Silverheels’ Certificate of Documentation says 18 GRT
      and 16 NRT. I’ve cleared into a score of countries in
      the Caribbean and the Med, and while some forms ask for
      one or both tonnages, none have ever charged a
      tonnage-related fee. Occasionally there is a big price
      jump for length, such as in the Bahamas over 35′ and in
      Grenada over 40′.
      Tonnage fees might well apply to commercial shipping,
      but not to yachts that I’ve ever seen.
    • #80916
      GRT and NRT refer to volume capacity of a ship not its mass or weight.
      From Wikipedia: “*Gross tonnage* (often abbreviated as *GT*, *G.T.* or *gt*)
      is a unitless index related to a ship’s overall internal volume. Gross
      tonnage is different from gross register
      tonnage
      .[1] Neither gross
      tonnage nor gross register tonnage is a measure of the ship’s displacement
      (mass) and should not be confused with terms such as deadweight
      tonnage
      or displacement .
      Gross tonnage, along with net
      tonnage,
      was defined by *The International Convention on Tonnage Measurement of
      Ships, 1969*, adopted by the International Maritime Organization in 1969,
      and came into force on July 18, 1982. These two measurements replaced gross
      register tonnage (GRT) and net register
      tonnage
      (NRT). Gross tonnage is calculated based on “the moulded volume of all
      enclosed spaces of the ship” and is used to determine things such as a
      ship’s manning regulations, safety rules, registration fees, and port dues,
      whereas the older gross register tonnage is a measure of the volume of
      certain enclosed spaces.”
      I think the one place this value for a yacht will result in a fee is the
      Panama Canal. When I worked in the CZ back in the 70s I remember the
      highest and lowest fees were posted in the observation area of the
      Miraflores lock. I don’t remember what ship was charged the max, but the
      min was for a guy who swam the length of the canal.
      Sarah’s Blog
      Grenada over 40′.
    • #80918
      The rating has nothing to do with the actual weight of the boat. It’s a formula the CG uses to evaluate cargo carrying capacity and is related to the waterline length and beam. I think my doc says gross-17.
      When hauled with empty water tanks, she tips in at 24000 lbs. I think she actually weighs about 22000 with the balance being fuel, ground-tackle and beer.
    • #80923
      Phil Fontaine
      Pete,
      An explanation of the abbreviations GRT and NRT can be found at the
      following link. http://en.wikipedia.org/wiki/Gross_tonnage
      My document has these abbreviatiions also.
      Phil Fontaine
