Forums › General Discussion › Re: Engine shutting down
Viewing 1 reply thread
    • #67230
      I have the W58 and it does indeed have a solinoid valve. It is located on the High Pressure injection pump just below the oil filter. One must be careful when you re-wire the key switch to make sure the solenoid is turned OFF with the key, else the engine will not shut down. mmmmm how do I know that?
      I am thinking it would be a good thing to have a spare.
      — On Wed, 11/5/08, Robert Fine <> wrote:
    • #71008
      howard
      Thanks very much. this is what i had been missing. if the wiring to the solinoid is like the rest of the fuel system this could be causing the intermittent shutdown. i will verify that all the wiring is sound then move on.
