Forums › General Discussion › Re: Generators in Lazeretee
- This topic has 3 replies, 2 voices, and was last updated 17 years, 4 months ago by
unabated.
June 25, 2009 at 11:21 pm #67564
ParticipantQuent,
what water maker do you have?
I bought the KUBOTA, 1 cyl 6 HP for 200 bucks. I got it running, it’s pretty particular about bleeding the lines. I bought a CAT 270 HP pump for 150 bucks off of EBay, hoping to make a WaterMaker. I think I can do the whole thing for less than 1K. Althought I have a Pur40 (will need to have new membranes) I like the idea of a bigger capacity WM and not have to have large amounts of gasoline around (except of dink). I have 2 60 solars panels and a MarineX wind genny
alan— On Thu, 6/25/09, quent <> wrote:
June 26, 2009 at 12:05 am #72989
ParticipantAlan,
We have 12 volt diesel genset, bought used for $1200. It was built by Pulsar for Jack Rabbit marine. Has about 300 hours. It came with all the marine features. I’m sure I can get it to run, probably needs an injector and a head gasket, and a valve job. Probably an afternoon’s work, about $100 in parts. Very different from the Westerbeke.
We have a 12 volt motor powered SK watermaker that was the cheapest and most generic on the market. It has a Cat pump and standard sized membrane. With the exception of some of the Bahamas, we’ve not gone anywhere where a watermaker is necessary, but we are still hopeful.
A couple things you might want to consider when locating the genset:
Proximity to the batteries for short cable runs, how to run the water cooled exhaust, including the muffler, and access to other critical systems, like steering.
June 26, 2009 at 12:45 am #72993
ParticipantMy boat lists to Stb with just the batteries…..
June 26, 2009 at 2:18 am #72995
ParticipantThe steering part is a worry for sure.
