Forums › General Discussion › Re: Zincs for heat Westerbeke 58..Where to buy?
- This topic has 11 replies, 8 voices, and was last updated 17 years, 9 months ago by
RichCarter.
January 11, 2009 at 6:13 pm #67297
Quent,How often do you inspect and or replace these?
-Bill<.. snip>
January 11, 2009 at 6:53 pm #71399
ParticipantUsually, once a year. This year more often since we went south and put a lot more water through the system. I replaced the end bolts with stainless steel which seems to be pretty compatable with the bronze heat exchanger.
January 12, 2009 at 2:38 pm #71405
ParticipantAdam, I think I am the only one that got the ketubah joke…….
alan— On Mon, 1/12/09, adam silverstein <> wrote:
January 12, 2009 at 4:23 pm #71406
Participantno, Alan, you weren’t the only one!
Rodd Leeds
WindseekerQuote:
January 12, 2009 at 4:27 pm #71407
Participantok cool 3 then…
January 12, 2009 at 4:29 pm #71408
RichCarterParticipantLinus
I’m very interested in hearing any alternatives ways to clean the V-drive. My new V-drive is about 3 years old now. Its due for a cleaning. I’m not looking forward to the task. Can you provide any more information on your cleaning method below?Rich
January 12, 2009 at 4:29 pm #71409
ParticipantOy, I had to Google it.
January 12, 2009 at 7:01 pm #71411
4
January 12, 2009 at 7:06 pm #71412
ParticipantI went past that….. got the get…..
January 12, 2009 at 7:18 pm #71413
Participantgotta getta get.
The brushes seem nice. Which giant AllClad pot did your wife let you use to boil the muriatic acid through the heat exchanger? I have mine on the workbench downstairs and I am cleaning and repainting it prior to reinstallation. Hoping to run COOL this summer.
(212) 233 4995
(212) 385-4661 (fax)Confidentiality Notice: The information contained in this message and any attachments is privileged and confidential information, intended only for the use of the individual or company named above. If the reader of this message is not the intended recipient, you must not review, retransmit, convert to hard copy, use or disseminate this e-mail mesage or any attachments. If you have received this e-mail in error, please immediately notify the sender by return e-mail or telephone.
January 14, 2009 at 9:33 pm #71440
ParticipantRich
I used a delimer called red line as recommended by the yard manager. It did nothing that I could tell. When I removed the cover it was solid. Out came the screwdriver and shop vac.
I chipped away at the black crud for about two hours. After it was cleaned out the delimer finished the job and made everything shiny.Linus
January 14, 2009 at 10:07 pm #71444
When I cleaned my old V-drive, I think I spent well over 8-hrs chipping away at the crud. I tried all kinds of cleaners from naval-jelly to acid; even teak cleaner. I tried a small bit on a die-grinder and finally settled on chisel and hammer. After cleaning it well, I coated the cooling jacket with marine-tex. I eventually replaced the darn thing. The new v-drive has an oil cooler running through the cooling jacket, so its going to be much harder to clean. I guess I’ll find out later this spring. No way am I going up onto my boat when its below zero….Regards
