Forums › General Discussion › Rebuild Walter V-drive
Viewing 14 reply threads
    • #67423
      Hi Don,
      Thank you so much for your input. It's great to see a manufacturer take an interest in even our small group.  One thing you might want to let us know is how to know the v-drive needs rebuilding.  Or does it make an extraordinary noise?
      Hull #8
    • #72185
      Dear Don C,
      I appreciate your interest in our group, too. However, with respect, your “total average rebuild (cost of) $560” does not include paying a boat yard mechanic a million dollars per hour to remove, ship, and re-install the unit, plus tax, plus the yard’s mark-up on your labor and parts, plus your shipping and handling charges to return same to those of us outside of Jersey City, NJ. Plus tax. Plus tax. I personally thank you for your feedback on this subject – your company builds a fine product and we all benefit by it – but do consider the consumer’s real total expense for these things. I suspect it’s closer to $1,000 than $560.
      Best regards,
    • #72186
      DonC:
      Thank you for your feedback–I boat on Long Island,NY, and can easily remove the vdrive and bring it to your location. I am glad I know of this option now and that the cost is moderate. I will now plan on bringing the unit in next fall after this season.
      Rodd Leeds
    • #72187
      I also appreciate Walters offering their labor rates the cost of the parts kits to our members.  I know if (when) I need a rebuild on my unit I will do my utmost to deal with them directly.
      Tor (and Rich) is correct in his assessment of the cost, if you use a yard to as your interface to Walters.  I had my V-drive rebuilt in 2000 through the local yard/dealer in Solomons, MD.  The cost after paying the yard to de-install, ship, and re-install was about $1,200.  Now I know better.
      On Thu, Mar 19, 2009 at 8:16 PM, Rodd Leeds < ([email][/email])> wrote:
      DonC:
      Rodd Leeds
    • #72188
      You guys might want to respond to Don directly.  I doubt he subscribes to the list.  God forbid he has to read about shower curtians choices and drifter sock management…
      Your comments are right on though, it was very respectable of him to take the time to post some pricing details and manufacturer concerns about such an important component in our boats drive train.
      DonC:
      Rodd Leeds
    • #72189
      patn
      I’ll put all the responses together and send them off to Don
      -pat
      > wrote:
      DonC:
      season.
      Rodd Leeds
    • #72190
      Shower curtain choices?
    • #72191
      Dear Mr. Fine,
      Glad to be of help.
      The most common indications that a V-Drive may be in need of a tear-down / rebuild:
      a) Water in the oil (after being submerged); water in the oil usually appears milky-white or tan or brown
      b) If oil smells burnt
      c) If there is any unusual or increasing noise coming from V-Drive
      d) If there is an oil leakage from lower (output) seal
      e) After an underwater impact to the propeller (which results in a high shock load to the V-Drive)
      Sincerely,
      Don Chatrnuck
      THE WALTER MACHINE COMPANY, INC.
      – Established 1927 –
      84 – 98 Cambridge Ave
      Jersey City, NJ 07307
      USA
      (201) 656-5654 – Main
      (201) 656-0318 – Facsimile
      E-Mail –
      This message from The Walter Machine Co., Inc. and any attachments may contain confidential
      information. This is intended for the company or individual named above. If you are not the
      intended recipient, please notify the sender and then delete it from your system immediately;
      please do not forward, copy, print, use or disclose this communication to others.
      Sent: Thursday, March 19, 2009 7:29 PM
      To: ,
      Subject: Rebuild Walter V-drive
      Hi Don,
      Thank you so much for your input. It’s great to see a manufacturer take an interest in even our small group. One thing you might want to let us know is how to know the v-drive needs rebuilding. Or does it make an extraordinary noise?
      Hull #8
    • #72192
      I think question we all have is the water cooling issue. I know some of the folks have either taken the water off or lined the cooling jacket with epoxy. Do you have any suggestions for cooling and minimizing the cooling jacket being eaten away?
      — On Fri, 3/20/09, Don C., Walter Machine <> wrote:
    • #72193
      patn
      I would like to add that we have the perception that the v-drive was
      built for power boats where one finds prolonged high speed use. On our
      sailboats “high speed” is 6-7 kts and the usual day would be < 2 hrs of
      engine time. It seems that the Walter was way over built for our uses
      ( which is a good thing )
      – pat
      SV Doris E, p424 #178
    • #72194
      Syringa
      Don
      I had some light salt buildup on my dipstick (no water in the oil) so I repaired the cooling chamber with epoxy as instructed in the manual. I also flushed the oil several times and changed the oil from 90W to 30W. I removed the raw water cooling from my v-drive (November 2007 and have over 100 hrs of running time). I installed a temp gauge in the one of the lower drain pulgs. I ran the unit at near hull speed for over 3 hours and the v-drive has never gotten above 130 F. The Walters manual states ” Proper operating temperatures are from 140 degrees to 180 although safe operating temperatures may be as high as 210.” As the waters of Puget Sound never get much above 47 degrees I don’t know if the cold running temps are due to the cold surroundings or because we don’t use the motor when we can sail. Anyway my v-drive is still running smooth, quiet, and cool. I should also say that I left all the fittings on the v-drive cooling so if I need to I can reconnect them.
    • #72195
      I like the one that’s mostly transparent with all the little fishes .
    • #72196
      What, no Popeye and Pluto?
    • #72197
      Pat-
      Please ask Don for similar price quote on a RV-20, the unit in most/all P-424s. Also, do they repair or replace gearboxes that rust and leak.
    • #72199
      Our V-drive blew a seal which we discovered just after leaving Livingston, Guatemala. We returned to port, re-entered, etc., and found a local engine mecahnic who said to replace the oill bath with 90 grade oil. That worked to stop the leak.
      When we returned to Chicago, we had the drive rebuilt by Larson’s Marine in Waukegan, Illlinois. I considered buying a new V-drive, but then went for the yard’s rebuild. The bill was $1,500. ( I was back to consulting and didn’t have time to fuss the with V-drive and many things that needed to be done after a voage of several thousand miles to Central America and back.) Afterwards, I thought it would have been just as smart to buy a new one and avoid all the yard labor costs.
      Norris Larson, Easy Reach, #203
      — On Thu, 3/19/09, John Stevenson <> wrote:
