Forums › General Discussion › Refers and freezers
Viewing 8 reply threads
    • #67013
      Last week I finally got my new freezer/refer turned
      on. Well, for a few hours anyhow.
      After about 14 hours, the freezer was down to 25 and
      the refer was 48. (with a cold plate temp of 22 – set
      pt is 20)
      This weekend I’ll have it on longer and see where it
      goes. You can’t hear the compressor and I have yet to
      see it draw more than 4.5 amps. Not sure the duty
      cycle yet havent, had it on longer enough.
      Pictures to follow, when I get the new latches on.
      ap
    • #69953
      What brand is it?
    • #69954
      I put in a SeaFrost. BD50 with 2 thin plates. BUT my
      friend, that is only about 50% of the project.
      The rest is ugly details.
      ap
      — Patrick Walters <> wrote:
      What brand is it?
    • #69955
      I LOVE that part…. do tell. 😉
    • #69956
      With any project, you need to learn the language. In
      this case, refrigeration. This is not a drop in kinda
      thing. The size of your “box” and the requirements for
      food storage, both in time and quantiy will lead you
      down different paths. Also where you plan on saiing.
      High lats or low.
      Check out http://www.kollmann-marine.com/
      Buy his book, commit it to memory.
      Then when your ready to buy, send your specs out to
      all the Marine Refrigertion people. With luck,
      someone might even answer you. In my opinion, Clieve
      Horton from SeaFrost is the only guy to deal with. He
      will spend the time to answer every question, look at
      your drawings, make suggestions and all before you buy
      a thing.
      Besides that Hylas uses SeaFrost…. enough said.
      Before you go too far, you will need to analize your
      electrical storage and renewal capacities.
      Insulate,Insulate,Insulate. My PO did me a favor (only
      one) by having the stock box removed and had 6 inches
      of insulation put in along with a new smaller box. Too
      bad he didn’t put in access to most of the space.
      More to follow, I actually have some work to do.
    • #69957
      I completely agree with your comments about Sea-Frost. I’m the first to complain when I get bad service. It is only fair to complement when we get good service. We should add Sea-Frost to our recommended vendor list.
      The Kollman Marine book is great. I had it out just last weekend. I replaced my compressor over the winter and had to recharge my system.
      Even if you don’t plan to service your own refrigeration, the book is filled with useful information about how they work and suggestions for improvement to existing systems. It’s well worth the cost. They sell two books. I have the do-it-youself book linked below.
      http://www.kollmann-marine.com/book.html
      They have an second volume with information specific to 12v systems.
      http://www.kollmann-marine.com/manual.htm
    • #69958
      You see, marine refrigeration is part art and part
      science. Way too many variables. Before you spend
      upwards of 2-3k on a system, you probably better be
      sure of what heck you are doing or at least close to
      the right thing or have a darn good back-up plan.
      This January, as I was about to put router to counter
      top, I said a little prayer. Either I am a hero, or I
      just made the biggest mistake in my life (no that’s
      not true,I was married once).
      So far I am pretty pleased, but I’ll have to wait for
      the warm weather to get here.
      I now have access to the top thru a top lid. The
      bottom thru a front opening door and access to the
      freezer section thru a 2nd top opening lid.
      4cu ft refer and a 3 cu freezer. Before anyone gets
      their panties twisted, the front opening door is a
      good idea in that I no longer have to take everything
      out to get to the bottom of the cooler. I can now just
      reach in and grab the stuff in the lower part.
      Remember my PO had already modified the box, so it
      does not looks like any of yours.
      It’s only 13 inches wide and 4 feet deep and 48 inches
      long along the top. Too deep for my short arms.
      to 12v systems.
    • #69959
      Do you have the 'U' layout or the 'L' layout?
      just made the biggest mistake in my life (no that's
      So far I am pretty pleased, but I'll have to wait for
      It's only 13 inches wide and 4 feet deep and 48 inches
      — () wrote:
      Sea-Frost. I'm the first to complain when I get bad
      Even if you don't plan to service your own
      improvement to existing systems. It's well worth
      to 12v systems.
    • #69960
      U I am trying to find all the pictures.
      — Robert Fine <> wrote:
      Do you have the ‘U’ layout or the ‘L’ layout?
      be
      to
      counter
      or I
      that’s
      for
      gets
      everything
      just
      inches
      bad
      get
      just
      for
      worth
      specific
      to 12v systems.
