Forums › General Discussion › Remote Oil Filter Conversion
- This topic has 7 replies, 4 voices, and was last updated 14 years, 4 months ago by
madsailor.
June 18, 2012 at 7:35 pm #68581
SpectatorWhen you pull the oil filter on the W58 there is really no easy way to get
a catch basin under it and being mounted horizontally means a mess is about
to happen if you’re not super carefiul.Has anyone converted their W58 to have a remote oil filter? I see kits out
there for other engines, was thinking this might be a nice upgrade if its
relatively cheap.In other news we’re getting the boat ready to be left in Banderas Bay for
the summer and go back to the states and buy and old RV and play around in
it for the summer. We love a good fixer up! 😉-patrick
@DeepPlaya<http://twitter.com/deepplaya> |
W7PEA
June 18, 2012 at 10:00 pm #78617
ModeratorI’ve been looking at my W58 and if I’m correct, the oil filter is ALREADY a
remote filter – there are two hoses to it, which on a filter means one’s a
goesinta, and the other is a goesouta. Other W58s used as generator motors
have filters on the other side of the engine that are vertical. I’ll have
to look more carefully or if anyone has taken it apart, disabuse me of my
idea…Bob
@DeepPlaya |
W7PEA
June 18, 2012 at 10:05 pm #78618
SpectatorHmm… of course now I just put the housing back on and I can’t see exactly
what you’re talking about. but yes. There are hoses from the oil cooler to
the oil filter.
You can sort of see that here:
http://www.flickr.com/photos/deepplaya/5938042863/I get the gist of what you’re saying, maybe that filter assembly can be
moved…-p
@DeepPlaya |
idea…Bob
On Mon, Jun 18, 2012 at 3:35 PM, Peaboy Walters <
get
about
out
the summer and go back to the states and buy and old RV and play aroundin
-patrick
@DeepPlaya |
W7PEA
June 18, 2012 at 10:17 pm #78619
ModeratorIt looked to me as if the block the filter is screwed into is a remote
mount bolted to the engine. I’ve done remote filters on other engines and
if I had the time, I’d unbolt and see what happens. Just not while the
engine is running…Bob
the oil filter.
moved…-p
@DeepPlaya |
ALREADY a
a
motors
have
idea…Bob
get
about
out
its
relatively cheap.
for
in
-patrick
@DeepPlaya |
W7PEA
June 18, 2012 at 10:38 pm #78620
ParticipantWe have had pretty good luck minimizing the spilled oil using a couple oil napkins and a hd ziplock bag, dropping the filter off the threads and into the bag. IMHO, not messy enough often enough to justify change.
The kit is another example of how something you would think is pretty generic is crazy expensive from Westerbeke, over $500.
Part of the kit, the remote bracket for the filter is on Ebay.
Clairebuoyant #132 -
June 18, 2012 at 10:43 pm #78621
ParticipantForgot to mention that the same remote filter kit number applies to the W-40 and W-50. Might be possible to salvage it from a junked engine.
June 19, 2012 at 3:44 am #78623
ParticipantI am confused.  Why can’t an automotive spin-on adapter replace the filter?  That is what I had on my W58.  Look for Artic Cool brand adapters  they come in all thread sizes and offer both straight out and rigjt angle versions of both the adapters and the filter holders.
Sent from my Android phone with a spell checker programmed to entertain you.
Subject: Re: Remote Oil Filter ConversionPost generated from Pearson424 Forum using Mail2Forum
June 19, 2012 at 9:44 am #78624
ModeratorNo reason at all, and probably the easiest solution.
On Jun 18, 2012 11:44 PM, “Pete Dubler” wrote:Quote:I am confused. Why can’t an automotive spin-on adapter replace the
versions of both the adapters and the filter holders.Pete
you.
