Forums › General Discussion › Replacing galley countertop
Viewing 2 reply threads
    • #67136
      Well, we’ve purchased Lady Leanne (1980 424 ketch #135 lying Waikiki) and want to begin the refit process with the galley. Has anyone replaced the countertop material and, if so, what did you use?
      S/V Lady Leanne II
      Waikiki
    • #70526
      We did. Used Formica laminate over existing surface after removing trim. In retrospect, I’d remove entire top, insulate top of box, and use better material, like Corian.
      Clairebuoyant, #132
    • #70539
      Thanks for the insight. It sounds like it would be an easier job to remove the countertop and then replace the material. Corian sounds like a good move.
      S/V Lady Leanne (#135)
      Honolulu
