Forums › General Discussion › Rivets or screws
Viewing 8 reply threads
    • #68511
      I am replacing the reefing line cheek blocks on the main boom.
      The replacements are from garhauer and have a four hole pattern.
      The orignal schafer blocks are 2 hole affixed with ss machine screws.
      Aside from serviceability any reason to use threaded fastener over rivets?
      Eric Lorentzon
      EFI Sales Development Manager
      412.352.1941
      Sent from my iPad
    • #78232
      Given they’re Garhauer, I’d go with stainless rivets. My two cents. Either
      is fine, the threaded fasteners are easier to put in without specialized
      equipment.
      Eric Lorentzon
      412.352.1941
      Sent from my iPad
    • #78233
      I was thinking rivets. I have tools for either – so equipment is not the issue.
      Eric Lorentzon
      412.352.1941
      Sent from my iPad
      equipment.
      Eric Lorentzon
      412.352.1941
      Sent from my iPad
    • #78234
      Stainless rivets are the thing, then.
      issue.
      Eric Lorentzon
      412.352.1941
      Sent from my iPad
      Either
      equipment.
      rivets?
      Eric Lorentzon
      412.352.1941
      Sent from my iPad
    • #78235
      Eric,
      Which size (p/n) of the Garhauer block are you using there?
      Eric Lorentzon
      412.352.1941
      Sent from my iPad
    • #78236
      25-22 SB. They are on a curved base that should mate well to the boom profile. These are significantly more substantial than what is currently installed. Would actually trust them in a blow.
      Eric Lorentzon
      412.352.1941
      On Feb 6, 2012, at 7:32 PM, Pete Dubler wrote:
      Eric,
      Eric Lorentzon
      412.352.1941
      Sent from my iPad
    • #78237
      Eric, the stainless and aluminum will eventually bond together. The rivet we know will have to be drilled out, the screw will probably shear off and result in the same situation.
      A professional would tap the boom and use a machine screw with a coating of Tef-Gel to secure the block. It might seem like overkill until you go to remove the hardware to repaint the spar.
      Tef-Gel might work on a self tapping screw but the cutting action of the screw makes it unlikely.
    • #78238
    • #78239
      Ted Elaine
      I used flat based Garhauer blocks.  I cut some cheek block pads out of starboard with a band saw to conform to the angle of the boom.  I used heavy sodering wire to get the pattern of the boom and then traced it on the edge of the starboard.  I then used fine thread machine screws to attach and the holes were tapped out first.  As attaching I applied anti-sieze to the hole to cut down on the corrosion
      between the stainless and the alum.
      Good luck
      Ted Riley
      Bel Esprit II
      Hull# 175
